YamaLP Posted November 9, 2017 Posted November 9, 2017 I have build a dump truck withe the 8258. But my problem is That the linear actuator isn't strong enouth with a down geard XL motor. Is there a diference when I use two LA's? or are there LA's who where stronger? Quote
Void_S Posted November 9, 2017 Posted November 9, 2017 Do you mean that LA is sliping and doesn't move the arm, right? I don't remember the all details, but there were a couple of white clutch (slipping actually) 24T gears, so may be they slips and doesn't rotate the LA shaft... Quote
M_longer Posted November 9, 2017 Posted November 9, 2017 1 hour ago, YamaLP said: I have build a dump truck withe the 8258. But my problem is That the linear actuator isn't strong enouth with a down geard XL motor. Is there a diference when I use two LA's? or are there LA's who where stronger? Post some pictures of your build. I think that LA is wrongly placed and that's the reason of not working properly. Quote
Technonsense Posted November 9, 2017 Posted November 9, 2017 1 hour ago, YamaLP said: are there LA's who where stronger? No, 8258's LA's are the strongest. Two would work if it is not the 24t clutch gears that are slipping. Quote
YamaLP Posted November 9, 2017 Author Posted November 9, 2017 I have fix the problem by replace the one LA with two LA's. Quote
1gor Posted November 10, 2017 Posted November 10, 2017 Well since you managed to fix your problem, can you please show your MOC? Quote
