Phoxtane Posted November 18, 2017 Posted November 18, 2017 This summer I acquired a 3D printer, and it only just recently crossed my mind that I could make parts that I've been wanting - even those that don't exist yet. This will be the thread I throw all that into. For the first post, here's my first version of the standard straight track: First, I started off by drawing the track profile, using the dimensions I found on the L-gauge wiki: http://l-gauge.org/wiki/index.php?title=Track_Geometry I used Autodesk Fusion 360 for the modelling portion (it's free to students, makers, hobbyists, and businesses making less than 100k USD a year!). Then, I extrude the profile out by 128mm to get the 'blank' for a piece of straight track: I then make another drawing on the top of the base which represents the ties present on the Lego track: Finally, I take every other section of the blank and extrude them downwards to the bottom of the blank, this time using a 'cut' operation instead of a 'new body' operation: I now have something that looks quite a bit like a piece of Lego track! It's obviously missing studs, the snap-together connectors, and the cutouts on the ends of the rails. However, it will do for a first print test. I then export from Fusion 360 as a .STL and load that into my slicing program of choice, Cura. I'm looking at the model in the layer view after applying my 'strong' settings - this lets me see the model layer-by-layer and I can see how it should look. I can also see a cross-section by using the slider in the upper right: Here we're seeing the interior of the rails, but not the ties. Here we can see inside the ties, as well as the supports - these are temporary structures that will be removed once the print is completed. They hold up the overhangs in the model that may otherwise sag or distort excessively - I'll need to change the support orientation before I commit to a print for better results. Unfortunately, it's too late at night for me to kick off a print - I know the time estimate given is somewhat of an underestimate, so one of these very basic track pieces will actually take a bit over three hours instead of the two and a half that's given by my slicer. I'll be doing that tomorrow. Quote
JopieK Posted November 18, 2017 Posted November 18, 2017 Autodesk fusion is great, you can even model your electronics right inside the 3D models. Quote
dr_spock Posted November 18, 2017 Posted November 18, 2017 Which 3D printer did you get? I've been looking at getting one and there are so many. I've been using the local public library but they limit you to PLA, colors on hand, and maximum print time. Quote
Phoxtane Posted November 18, 2017 Author Posted November 18, 2017 (edited) 4 hours ago, dr_spock said: Which 3D printer did you get? I've been looking at getting one and there are so many. I've been using the local public library but they limit you to PLA, colors on hand, and maximum print time. I got myself the Monoprice Maker Select V2 - it has a build volume of 200x200x180mm (X, Y, Z respectively), has a heated build plate, and can handle either PLA or ABS. I've never used ABS as it can be tricky to print, especially when you tend to have strong drafts in the area (like my space). I've added a Z-brace to the tower to eliminate back-and-forth motion on the Z axis, which would decrease the quality of prints I can get out of it: My print material of choice is PLA, as it's easier to print and less prone to warping than ABS. In my slicer I have my printer set to 200C and 55C for the extruder and heated bed, respectively. I also use a .2mm layer height with a .3mm initial layer (this helps to take up any uneven spots in the print surface). After I've loaded the output from Cura onto a microSD, I wiped down the print bed with a paper towel to get rid of any dust that may have settled since I last used the printer. After a short preheat for both the heated bed and the extruder, we're off to the races. Here's an in-progress shot: Turns out it's somewhat difficult to get a good shot because the subject is moving back and forth! I let the print bed cool for a bit before I attempt to remove the part. Usually for small pieces I can remove them immediately, but large parts cool slower and I don't want to remove them too early for fear of warping. I managed to coax the part off the bed and leave behind just about all of the supports. The last one that stuck to the part popped off without any tools whatsoever. Then we have the final product! In the second image you can clearly see the difference in surface finish between portions of the model that sat directly on the print bed, and portions that were built on top of supports. I've also got some sort of lighter gray splotches on the bottom, which I've not seen before - maybe it's because I didn't wait long enough for the part to cool? I'm not sure. The next step for this model is to add studs, the clip-on connectors, the rail end cutouts, and the empty spaces on the underside of the ties to allow for connecting this to real Lego parts. Edited November 18, 2017 by Phoxtane Quote
Phoxtane Posted December 4, 2017 Author Posted December 4, 2017 I finally have a 3d printed piece of track that attaches to Lego bricks! This is the fifth print for this part, so so far have I've spent between 12 and 15 hours on printing. The next step is to set up the flanges and such that allows each track piece to connect to other ones. Quote
splatman Posted December 4, 2017 Posted December 4, 2017 On 11/18/2017 at 9:13 AM, dr_spock said: I've been using the local public library but they limit you to PLA Do they allow you to bring your own filament? 2 hours ago, Phoxtane said: I finally have a 3d printed piece of track that attaches to Lego bricks! This is the fifth print for this part, so so far have I've spent between 12 and 15 hours on printing. You should have taken the opportunity to design and test the connection points as well. I guess, when you do, test by designing a 4-stud-long piece, to cut down on material usage. Quote
dr_spock Posted December 4, 2017 Posted December 4, 2017 16 hours ago, splatman said: Do they allow you to bring your own filament? I think that may depend on the library. My local library doesn't. They probably want to keep things simple as most library staff aren't 3d printing experts. There can be a lot of tweaking to get a different brand filament to print correctly. Quote
