Hi Marcus, here's something I just came up with that seems to work pretty well. I used a 98313 and got one end of the clip behind the tile. I then pressed on the inside of the arm out toward the wall of the engine part. It acts as a lever and pries the tile away very easily.
It's not a "purist" solution like Jarren's, but you can also bend the end of a paperclip into a U and use that to hook the underside of the 2x2 anywhere along the lip and once it starts to come up should be easy to pull out.  :wink:
This method worked great! Thanks Jarren!
