camellia Posted December 24, 2017 Posted December 24, 2017 (edited) Strandbeest is designed by Theodorus Gerardus Jozef who is a great Dutch artist. Today I make my droid with Strandbeest's legs. Each leg in this contraption has 11 movable rods and 2 fixed rods which form 8 joints. Camellia Servo Strandbeest droid model is controlled by CAPPUCCINO controller with ARM technology. Each body part of this droid has an individual LEGO motor to drive its moving speed, distance, time and direction. As 8 LEGO motors are used, droid's head, body, left leg, right leg, left arm, right arm, left hand and right hand are able to be controlled cooperatively! Left and right by two motors, each has 2 front and 2 rear legs. Upper body Left arm Right arm Left hand Right hand Head and eyes, One eye is a camera to record its view. Waist Back 40th LEGO Technic nameplate 1977-2007 Just make you own droid at home. Welcome to Camellia Café Edited December 24, 2017 by camellia Quote
Aventador2004 Posted December 24, 2017 Posted December 24, 2017 Seems to shake around alot, does this happen alot? Quote
camellia Posted December 25, 2017 Author Posted December 25, 2017 11 hours ago, Aventador2004 said: Seems to shake around alot, does this happen alot? Yes, the body will shake a little when walking. On one hand, it is impossible to void shaking thoroughly as legs are based on joints, not hard connection. On the other hand, I lower the barycenter as possible as the space allowed to reduce shaking. Now there are 8 legs. If more legs are used, it is more stable. But more legs need more motors to keep power and a very firm crankshaft is need. Why use more legs is because the body is so large. If only legs walking without upper body, it is good with less legs. If any more suggestion, please say to me.Thank you very much! Quote
KikoTube Posted December 25, 2017 Posted December 25, 2017 Realy good moc and presantation! May i ask which program you used for the mechanics? Quote
camellia Posted December 25, 2017 Author Posted December 25, 2017 2 hours ago, KikoTube said: Realy good moc and presantation! May i ask which program you used for the mechanics? The hardware controller is designed by myself. And programs are coded by myself with C. It can be controlled by WiFi with Visual Studio and mobile Bluetooth with Java. Quote
Boulderer Posted December 25, 2017 Posted December 25, 2017 How did you create the animations of the leg motion? Quote
camellia Posted December 25, 2017 Author Posted December 25, 2017 1 hour ago, Boulderer said: How did you create the animations of the leg motion? The legs motion is real. I recorded its motion with video recorder. Quote
