brickless_kiwi Posted January 2, 2018 Posted January 2, 2018 Love the work, however just to throw a curve ball how hard would it be to do a day cab or the 48" low sleeper? Quote
efferman Posted January 2, 2018 Author Posted January 2, 2018 with or without RC? @igor why 7 studs? Quote
brickless_kiwi Posted January 2, 2018 Posted January 2, 2018 (edited) 1 hour ago, efferman said: with or without RC? @igor why 7 studs? RC of course If you remove the mp8 from under the hood, there is room, though the wheel base needs to be shrunk, it just seems to me lego missed a great opportunity to produce a C model with all those parts. Edited January 2, 2018 by brickless_kiwi kiwi doddling in LDD Quote
M_longer Posted January 2, 2018 Posted January 2, 2018 4 hours ago, brickless_kiwi said: it just seems to me lego missed a great opportunity to produce a C model with all those parts. Yeah... like with Unimog, Arocs and Xerion... Quote
efferman Posted January 2, 2018 Author Posted January 2, 2018 (edited) @brickless_kiwi, my aproach Should a daycab not have a shorter wheelbase? edit: everything is inside Edited January 2, 2018 by efferman Quote
1gor Posted January 2, 2018 Posted January 2, 2018 14 hours ago, efferman said: @igor why 7 studs? So you have to modify only rear part of the trailer (49.5 tires are about 6 studs + one stud for distance between wheels). BTW Mack with day cab looks better for this container transport. If it could have double rear wheels that would be great Sorry for late response, had a busy day... 8 hours ago, M_longer said: Yeah... like with Unimog, Arocs and Xerion... But as you see there is always a room for modifications, improovement so mocers have fun and develop creativity like @efferman in this topic....and LEGO did it on purpose Quote
brickless_kiwi Posted January 2, 2018 Posted January 2, 2018 I like your approach @efferman though yes the day cab wheelbase should be shorter for the life of me I can't find any information on the wheelbases though I have taken a guess and removed 4 studs out of the wheelbase to get a better look ( I know @M_longer will beat me with a scale rule ) at the moment this is allpurely digital for me until my set's arrive and then getting time to build them is another thing. I will probably keep the skin of the anthem but completely change the frame. Quote
1gor Posted January 3, 2018 Posted January 3, 2018 13 hours ago, brickless_kiwi said: I like your approach @efferman though yes the day cab wheelbase should be shorter for the life of me I can't find any information on the wheelbases though I have taken a guess and removed 4 studs out of the wheelbase to get a better look ( I know @M_longer will beat me with a scale rule ) at the moment this is allpurely digital for me until my set's arrive and then getting time to build them is another thing. I will probably keep the skin of the anthem but completely change the frame. It is nice un blue and daycab version is really good. Original looks a bit as a sleeper on steroids Quote
aminnich Posted January 3, 2018 Posted January 3, 2018 13 hours ago, brickless_kiwi said: I like your approach @efferman though yes the day cab wheelbase should be shorter for the life of me I can't find any information on the wheelbases though I have taken a guess and removed 4 studs out of the wheelbase to get a better look ( I know @M_longer will beat me with a scale rule ) at the moment this is allpurely digital for me until my set's arrive and then getting time to build them is another thing. I will probably keep the skin of the anthem but completely change the frame. This is very similar to what I would do with the MACK. I love it! Also, idk why, but I tend to like the red frame on trucks. Quote
1gor Posted January 3, 2018 Posted January 3, 2018 1 hour ago, aminnich said: This is very similar to what I would do with the MACK. I love it! Also, idk why, but I tend to like the red frame on trucks. That would be interesting - red frame, but newer models have all black frames. Perhaps they decided to paint them (red and gray are usually base colors) Quote
efferman Posted January 3, 2018 Author Posted January 3, 2018 (edited) As long wheelbase with fifth wheel the daycab lxf is done Edited January 3, 2018 by efferman Quote
Phantom59 Posted January 4, 2018 Posted January 4, 2018 (edited) On 1/3/2018 at 2:18 AM, efferman said: @brickless_kiwi, my aproach Should a daycab not have a shorter wheelbase? edit: everything is inside Keep the long frame and day cab to use the area for a crane eg: logging truck or do a updated version of 8258 Crane truck https://brickset.com/sets/8258-1/Crane-Truck Edited January 4, 2018 by Phantom59 Quote
camaudio Posted January 5, 2018 Posted January 5, 2018 On 12/31/2017 at 2:08 AM, efferman said: only a small american style flatbed Cant wait to get the set. I plan on building a drop deck, or van trailer for it. Quote
Aleh Posted January 5, 2018 Posted January 5, 2018 Looks cool! I wonder does anybody build Mack with this my trailer: https://rebrickable.com/mocs/moc-5326/OleJka/trailer/#info ??? Quote
efferman Posted January 6, 2018 Author Posted January 6, 2018 @I_Igor inspired me for duallys on the mack. hopefully it is stable enough http://www.doktor-brick.de/index.php/Attachment/34257-42078-Mack-Anthem-Day-cab-dually-lxf/ Quote
1gor Posted January 6, 2018 Posted January 6, 2018 Michael thank you for recognition, hope that this solution would work Quote
Thirdwigg Posted January 6, 2018 Posted January 6, 2018 What will keep the 7L axles from pulling out of the differential gears? Quote
efferman Posted January 6, 2018 Author Posted January 6, 2018 There is a half bush between tthe liftarm which holds the diff, and the part which supports the axle ext to the rim. Quote
steph77 Posted January 6, 2018 Posted January 6, 2018 I do not think that a double back wheel is a must have. But your IR integrated day cab version definitively is. Thanks for ldd file. Quote
efferman Posted January 7, 2018 Author Posted January 7, 2018 Something speedy based on the daycab in a early work in progress Anthem Super Boss by Michael Wirth, auf Flickr Quote
brickless_kiwi Posted January 7, 2018 Posted January 7, 2018 Mr @efferman You area very talented Lego builder, its not till you have both files side by side until you see the suttle differences in the hood and front apron. In the next day or so I should be able to start building my frame in real life ( but I have enjoyed the LDD build of which I have used your K100 front end so this Mack does have Ackerman steering and I like the look of trident wheels ( I have them on my Super Mack in real life ). The frame is the correct wheelbase according to sariels scale calculator, I just wanting too finish the tanks and steps. Powered by twin L motors Quote
Aventador2004 Posted January 8, 2018 Posted January 8, 2018 How long does it take before you mod a set @efferman? Quote
Aleh Posted January 8, 2018 Posted January 8, 2018 Hey guys! Does anybody thinking about 8x4 or even 10x4 MOD? I do. But only after buong the set. It will be not in the near future :( Quote
