nick97 Posted December 31, 2017 Posted December 31, 2017 Hey all, At the last day of the year I want to show you my build for the bull-back contest. The motor is winded-up using the wheel and relaesed by pusing the axle beside it. From the motor to the clutch it is geared using a 12/36 and a 8/40 combination. After the clutch there is also a 12/36 reduction. If I turn the wheel 4 times around and release it, then the second 36 tooth gear turns almost half around. That is enough for lifting the road completely. I added the clutch for some kind of safety. In neutral I won't wind-up the motor when lowering the bridge. And a video: Next step is building something to slow down the motor. Comments are welcome! https://bricksafe.com/pages/nick97/tc13 Quote
Aventador2004 Posted December 31, 2017 Posted December 31, 2017 Interesting, I wouldn't have thought of it. Quote
mocbuild101 Posted December 31, 2017 Posted December 31, 2017 I like it! - It's a great idea, and very different. Quote
Didumos69 Posted December 31, 2017 Posted December 31, 2017 Very original! I like it. You could use some sort of clock escapement to slow it down. Quote
Jurss Posted December 31, 2017 Posted December 31, 2017 Interesting, and also slowing down would be better, more realistic. Quote
nick97 Posted December 31, 2017 Author Posted December 31, 2017 Thanks for the great comments! 2 hours ago, Didumos69 said: You could use some sort of clock escapement to slow it down. Thanks for the advise. I'll try to figure out something tomorrow Quote
WvG_853 Posted January 1, 2018 Posted January 1, 2018 Indeed very original idea, but also well executed with the black bricks for the road separated by a white line and the blue panels for the water. I like it! Quote
SaGo Posted January 1, 2018 Posted January 1, 2018 How about connecting the pull back motor output axle to a disconnected (from power supply) PF motor. It takes a lot force to turn a PF motor that is not moving. I have not tried this out myself but this idea occurred to me. Quote
Didumos69 Posted January 1, 2018 Posted January 1, 2018 Just now, SaGo said: How about connecting the pull back motor output axle to a disconnected (from power supply) PF motor. It takes a lot force to turn a PF motor that is not moving. I have not tried this out myself but this idea occurred to me. A more simple way would be to connect the pullback output to an axle-pin with friction ridges, which is inserted into a secured pinhole. Quote
nick97 Posted January 2, 2018 Author Posted January 2, 2018 On 1-1-2018 at 10:03 AM, WvG_853 said: Indeed very original idea, but also well executed with the black bricks for the road separated by a white line and the blue panels for the water. I like it! Thanks! On 1-1-2018 at 12:18 PM, Didumos69 said: A more simple way would be to connect the pullback output to an axle-pin with friction ridges, which is inserted into a secured pinhole. I tried it, but this way the pull-back motor (I use) won't turn the axle at all. I did found another system to slow it down, a small clock escapement I've seen in this video: This system slows the motor down perfectly. After winding-up completely, the bridge raises much slower than without. I will take some pictures tomorrow. Quote
Didumos69 Posted January 2, 2018 Posted January 2, 2018 10 minutes ago, nick97 said: This system slows the motor down perfectly. After winding-up completely, the bridge raises much slower than without. I will take some pictures tomorrow. Quote
nick97 Posted January 3, 2018 Author Posted January 3, 2018 (edited) Hey all, Here are some pictures of the (almost) finished bridge: I added a small clock escapement to slow down the pull-back motor. In the video you can see it is much slower now: And one with view of the clock escapement: Edited January 15, 2018 by nick97 Quote
1gor Posted January 3, 2018 Posted January 3, 2018 Very original idea. My only complain goes to very colorfull display Quote
nick97 Posted January 15, 2018 Author Posted January 15, 2018 In my last post (from 3 January) I said almost finished build, as I wanted to build a small bridge house beside the bridge. The bridge would be controlled in such a building in real life. But I haven't had much time to do that, so I skip it. It already looks good enough to me. On 3-1-2018 at 3:50 PM, I_Igor said: My only complain goes to very colorfull display I can easily explain all the colors with a little imagination Blue is water, black and white represents the road. Yellow represents wood, as it is a smal old bridge. I don't have brown in my collection so I used yellow for it. Grey represent concrete. This part of the construction got damaged and is rebuild with concrete to reduce the change of breaking down again. Quote
1gor Posted January 15, 2018 Posted January 15, 2018 2 minutes ago, nick97 said: I can easily explain all the colors with a little imagination Blue is water, black and white represents the road. Yellow represents wood, as it is a smal old bridge. I don't have brown in my collection so I used yellow for it. Grey represent concrete. This part of the construction got damaged and is rebuild with concrete to reduce the change of breaking down again. Quote
Jurss Posted January 15, 2018 Posted January 15, 2018 How is it closed/lowered? Is there some reverse gearbox? Quote
Aventador2004 Posted January 15, 2018 Posted January 15, 2018 5 minutes ago, Jurss said: How is it closed/lowered? Is there some reverse gearbox? I think he has a neutral gear to lower it. Quote
nick97 Posted January 15, 2018 Author Posted January 15, 2018 2 hours ago, Jurss said: How is it closed/lowered? Is there some reverse gearbox? As you can see in my video I'm moving two levers before releasing the pull-back motor. The first lever is for the clock-escapement, as it stalls when turned backwards. The second lever is for the lifting mechanism. When winding-up the motor I have to turn the wheel 7 times around. If I wind the motor with the bridge lever engaged, the bridge lowers only half of its way. Quote
Jim Posted January 23, 2018 Posted January 23, 2018 On 31-12-2017 at 2:52 PM, mocbuild101 said: I like it! - It's a great idea, and very different. Exactly how I feel about it. Quote
BrickbyBrickTechnic Posted January 23, 2018 Posted January 23, 2018 If I could describe this entry with one word, this thing is ingenious! Amazing use of the pullback motor. Quote
