Techniccrack Posted May 12, 2018 Author Posted May 12, 2018 Update Building the supportframe Iam working on the dressup the underframe. 5 staircases and a little spiderweb decoration. A few progress photos: to be continued! Quote
Techniccrack Posted May 15, 2018 Author Posted May 15, 2018 A little update: progress of building the stage Quote
Carsten Svendsen Posted May 16, 2018 Posted May 16, 2018 It looks good, but I wish your pictures were bigger because I can barely see anything. Quote
Techniccrack Posted May 16, 2018 Author Posted May 16, 2018 1 hour ago, Carsten Svendsen said: It looks good, but I wish your pictures were bigger because I can barely see anything. sry :) next pictures will be bigger Quote
Frequenzberater Posted May 17, 2018 Posted May 17, 2018 Looks promising! What I dont like is the use of Technikbeams for stairs and Control/Cash Cabin. From my point of view a creator style build of those areas would fit much better. Quote
Techniccrack Posted May 17, 2018 Author Posted May 17, 2018 (edited) 2 minutes ago, Frequenzberater said: Looks promising! What I dont like is the use of Technikbeams for stairs and Control/Cash Cabin. From my point of view a creator style build of those areas would fit much better. I knew it! Same here. it turned out not as i hoped it be. and i will change the cabin. (stairs i will think about) but lack of "normal" bricks is the issue. i will change it. thnx for the comment! Edited May 17, 2018 by Techniccrack Quote
Techniccrack Posted May 17, 2018 Author Posted May 17, 2018 (edited) Update. a little change of the staircases i change the look of the staircases a little. i cover the holes with dark blue tiles. i have to order the tiles for the remaining holes, but it looks better then the holes exposed. Also the beginning of the fences are done now with the walk through for buying the tickets.... (cashcabin will be changed, but that parts i have to order) to be continued... Edited May 17, 2018 by Techniccrack Quote
Techniccrack Posted May 19, 2018 Author Posted May 19, 2018 Little update Groundplates and stagelights A little progress The groundplates. 16 pizzapieces with in between a dark grey plate "line". on photo they are yellow, but that willl be dark grey still in progress because i have to order the plates a stagelight with leds (controlled by a chaser /running light sequencer) to be continued! Quote
wimpie3 Posted May 20, 2018 Posted May 20, 2018 Nice! But why are the steps white? Most of the time they are in steel, wouldn't grey be a better color? Keep up the good work, this must already have cost to a fortune! Quote
Techniccrack Posted May 20, 2018 Author Posted May 20, 2018 Impression of the stagelights: Simple how its light up: ] To be continued... Quote
Techniccrack Posted May 20, 2018 Author Posted May 20, 2018 Update. Lighting the model;. I activated the first stagelights to test how it turns out.. i it turns out awesome... to be continued! 12 hours ago, wimpie3 said: Nice! But why are the steps white? Most of the time they are in steel, wouldn't grey be a better color? Keep up the good work, this must already have cost to a fortune! why i used white? lack of grey parts! :) Quote
pagicence Posted May 20, 2018 Posted May 20, 2018 Awesome! Are those lights going to flash like on the real thing? Because that would be even more awesome. Quote
Techniccrack Posted May 20, 2018 Author Posted May 20, 2018 13 minutes ago, pagicence said: Awesome! Are those lights going to flash like on the real thing? Because that would be even more awesome. they will be controlled by a led chaser/ running sequencer and yes, they will be flashing including strobelights and lights on model. Still working on it Quote
Frequenzberater Posted May 20, 2018 Posted May 20, 2018 As the Icing on the cake, you definetely need to put a small ultrasonic smoke generator in it! Quote
Techniccrack Posted May 20, 2018 Author Posted May 20, 2018 3 minutes ago, Frequenzberater said: As the Icing on the cake, you definetely need to put a small ultrasonic smoke generator in it! Haha! I seriously thought about that. But smoke generators are expensive..:) Quote
doggo Posted May 20, 2018 Posted May 20, 2018 I'm sure a smoke generator would cost much less than this amazing creation. Quote
Frequenzberater Posted May 21, 2018 Posted May 21, 2018 Cheapest ones at Amazon are around five euro :) Quote
Techniccrack Posted May 21, 2018 Author Posted May 21, 2018 2 hours ago, Frequenzberater said: Cheapest ones at Amazon are around five euro :) Really? I will look for it! Thnx Quote
Techniccrack Posted May 21, 2018 Author Posted May 21, 2018 I searched for a smoke generator. And i found one:) So..soon the smoke will be added to the model.. Quote
Bublehead Posted May 21, 2018 Posted May 21, 2018 Next, you will need to clone tiny little people to ride it. Quote
Techniccrack Posted May 26, 2018 Author Posted May 26, 2018 On 21-5-2018 at 5:41 PM, Bublehead said: Next, you will need to clone tiny little people to ride it. to bad. the project failed.. I borrowed the shrinking machine from the movie :"Honey, i shrunk the kids". but that technology was too old and i could not hook up the usb connecton to my computer to make it work...so sad :) Kidding.... Quote
