ColletArrow Posted January 17, 2018 Posted January 17, 2018 (edited) After seeing the prelinary pictures for 60198 on Reddit/Imgur, I decided to have a go at building a MOC based on them, albeit only in LDD as I have no access to real bricks. Sticking to the original colour scheme, and using some designs posted by @creator_hun and @BrickMusher in the 2018 topic, I came up with this: Now, the doors are not the same as the pictures as I wanted them to be recessed rather then just have a handrail sticking out. I also added some more detailed pantographs than the standard 3-piece ones LEGO tends to use, and the underframe detail is entirely freelance too. Overall though, I think it looks pretty good. Then I thought: this loco is based off the SNCF BB 22200, which seems mainly used on passenger trains. So what would it look like in 60051 colours, with some of the carriages in tow? The answer is pretty neat: If one were to build this IRL the glass in the windows would have to be trans-brown rather than clear. I coloured the window frames dark grey to match the surrounds on the coaches, and the ends yellow because I'm British and that's what I'm used to seeing. My final thought was "what if one of these was used to rescue a broken-down 60051?" This is a scene inspired by the East Coast Main Line, where a couple of Class 67 "Thunderbird" locos are held ready to haul failed Class 91 trains. This required a little modification of the underside of 60051's nose to get a coupling in, but it works. All these come with the disclaimer that as I have only built them in LDD I have no idea if all the parts exist in the relevant colours. I am sure most of them do, and if not they could easily be replaced by similar parts or different colours. I will probably not be building these in bricks anytime soon, but anyone is welcome to have a go. They're really not hard to reverse engineer. Overall, what do you think? Are there any other colour schemes I should try? Edited January 19, 2018 by ColletArrow Re-inserted pictures Quote
M_slug357 Posted January 17, 2018 Posted January 17, 2018 Those dark grey 2x6x2 windows did exist at one point, and since I happen to have a pair lying around, I might have to give this build a try! Thanks! Quote
scottwb2010 Posted January 17, 2018 Posted January 17, 2018 A nice rendition of this loco. Do you have the file to share? Quote
ColletArrow Posted January 17, 2018 Author Posted January 17, 2018 Thanks! If anyone does build it, I would be interested to see how it comes out. I've realised the window in the door doesn't exist in DBG, so it's been replaced by 60032. 87552 is another alternative. The 1x2x2 panel just behind the cab windows also don't exist in green or DBG, but could easily be replaced by bricks. The 1x2 inverted bracket under the nose exists in white but not yellow, but could be replaced by the train end piece anyway. I think everything else is fine. Here's the Bricksafe folder, with more pictures and the .lxf files: https://bricksafe.com/pages/Collet22/train-mocs. Quote
LEGO Train 12 Volts Posted January 17, 2018 Posted January 17, 2018 The magnet for the 60051 is a brilliant idea! Quote
Capparezza Posted January 18, 2018 Posted January 18, 2018 Very nice Maybe you can mash-up the release version too? Have you seen the latest pictures? Quote
ColletArrow Posted January 18, 2018 Author Posted January 18, 2018 (edited) Thank you both!@LEGO Train 12 Volts The coupling was inspired by the BR Class 43 HST couplings, where a hatch in the nose fairing has to be opened and a long bar inserted in order to couple us to anything. This was similar, except because I couldn't open up the top of the nose I had to in from beneath. I have no idea how well it would perform in curves, it may need to be longer depending on how far the nose swings out.@Capparezza I have; the loco in them is very small, so it's mainly guesswork, but here you go. In original colours, as close as possible: It feels very BR Class 37/40/55 -ish now I have built one, despite the pantographs. I think the preliminary model looked better, but this is just as good a set. Here's the "Preliminary replica" and "As close to actual release as I can manage" buffer-to-buffer. They're clearly very different locos, despite all that I've changed is the nose and cab shape. I've kept the detailed underframe on the new version, as I can't see what it is from the picture, and I still quite like it. Here it is in 60051's colours, with the better pantographs: ...And finally, in 60051 colours with coaches: Not bad, but I'll let you make your own judgments. I'll probably put the new .lxf on the bricksafe page soon. Edited January 19, 2018 by ColletArrow Re-inserted pictures Quote
scottwb2010 Posted January 18, 2018 Posted January 18, 2018 On 17/01/2018 at 2:40 PM, ColletArrow said: Thanks! If anyone does build it, I would be interested to see how it comes out. I've realised the window in the door doesn't exist in DBG, so it's been replaced by 60032. 87552 is another alternative. The 1x2x2 panel just behind the cab windows also don't exist in green or DBG, but could easily be replaced by bricks. The 1x2 inverted bracket under the nose exists in white but not yellow, but could be replaced by the train end piece anyway. I think everything else is fine. Here's the Bricksafe folder, with more pictures and the .lxf files: https://bricksafe.com/pages/Collet22/train-mocs. Cheers ColletArrow Quote
Dav1d Posted January 18, 2018 Posted January 18, 2018 I liked your original design - I think it looks better than the real set - we will have to wait and see. Quote
ElectroDiva Posted January 18, 2018 Posted January 18, 2018 (edited) Great work @ColletArrow - thanks for sharing. Love the look of this: On 17-1-2018 at 12:23 PM, ColletArrow said: Images are missing? I think I might have to have a bash at building that in the white and yellow colour scheme (if the parts are available) Edited January 21, 2018 by JopieK Images were not found Quote
ColletArrow Posted January 18, 2018 Author Posted January 18, 2018 Go ahead! Most of the parts should be there. The grey parts around the cab may need to be altered, such as different door-windows and trans-brown glass. The yellow bumper beneath the nose should really be replaced by 6583, it both looks better and actually exists. Everything else should be there to some degree, and I'm reasonably confident of its structural integrity. I'd love to see this built in real bricks! Quote
CDM Posted January 18, 2018 Posted January 18, 2018 Really great stuff...thanks for posting this. I really like the white / gray versions, especially of the prototype. Quote
BrickMusher Posted January 18, 2018 Posted January 18, 2018 Jep, also love this colour scheme. I replaced some parts due to availability. Think it should be buildable in this variation. Did a quick render in stud.io Full credits to ColletArrow. Try to build it as soon as I get the missing parts (have not erverything in stock ) http://NS1600 by Brick Musher, auf Flickr ( @ColletArrow P.S. Hope my text under flickr-pic is ok for you... otherwise please send me a message with your wishes) Quote
ColletArrow Posted January 18, 2018 Author Posted January 18, 2018 (edited) That's AWESOME! Thanks! The credit-ing is fine, I suppose it should really go to the LEGO designers as it was their model originally. EDIT: I've re-organised my Bricksafe pages, so here's the new link for more pictures and .lxf files: https://bricksafe.com/pages/Collet22/train-mocs/60189-preliminary-replica Edited January 18, 2018 by ColletArrow Quote
Capparezza Posted January 19, 2018 Posted January 19, 2018 Thanks man, you're the best! Great looking models, both of the locos, even if I do prefer the prelim version too Quote
Younge Posted January 19, 2018 Posted January 19, 2018 That looks so damned good! @ColletArrow, is there anything you came across during the build that might have dissuaded TLG to not go with this design? A step too difficult for (today's) kids to handle. Quote
ElectroDiva Posted January 19, 2018 Posted January 19, 2018 Right - after spending a couple of hours playing around with the design based on parts availability - this is what i've come up with: I think it looks rather rakish :) Parts ordered for about £50 for the lot and i should have them in the next few days. Will post some pictures of the finished build as soon as I've built it. Quote
ColletArrow Posted January 19, 2018 Author Posted January 19, 2018 @ElectroDiva I like the yellow rails along the top, they complement the ends nicely. Really looking forward to it in real bricks! @Younge Thanks! Apart from the front window, not really. I just guessed on this design, TLG probably would have come up with a better solution. The nose might be a bit weak too, I'm not sure. Quote
Paperinik77pk Posted January 19, 2018 Posted January 19, 2018 Great creation, it really feels as a "broken nose" French locomotive! Really nice and clean looking Quote
*thomas* Posted January 19, 2018 Posted January 19, 2018 This is what LEGO should've released, instead of that ugly double cab... well done to you, sir! Quote
Murdoch17 Posted January 19, 2018 Posted January 19, 2018 Just to let you know @ColletArrow, your pictures are no longer working in the first post. Quote
ColletArrow Posted January 19, 2018 Author Posted January 19, 2018 @Murdoch17 I thought that should happen when I re-organised my Bricksafe page, but they still showed fine for me. Are they any better now? Quote
zephyr1934 Posted January 21, 2018 Posted January 21, 2018 On 1/17/2018 at 6:23 AM, ColletArrow said: My final thought was "what if one of these was used to rescue a broken-down 60051?" This is a scene inspired by the East Coast Main Line, where a couple of Class 67 "Thunderbird" locos are held ready to haul failed Class 91 trains. This required a little modification of the underside of 60051's nose to get a coupling in, but it works Not being familiar with the UK locomotives, I googled "Class 67 Thunderbird" and 2/3's of the photos had them pulling Class 91 trains (saving me another google, grin). These are great builds, and the trick with the wagon end is brilliant. Quote
BrickMusher Posted January 21, 2018 Posted January 21, 2018 (edited) Preliminary Train [MOC] in new colour-scheme Took me some time, but here it is in the suggested colour-scheme I did also a modified version (indeed I just modified ONE side, so the engine is different on left and right ) I exspect your judgement about wich modification you like, and wich one I should rebuild. So here it is. As always, you will find more pictures on my flickr-account Started with this LDD-render http://NS1600 by Brick Musher, auf Flickr This is how it looks in real life: http://NS1600 MOC by Brick Musher, auf Flickr And here the modified second side: http://NS1600 MOC by Brick Musher, auf Flickr modification: black rail under Front-window, nose shortened one plate, red lights added, 1x1 tiles under front-window changed to round-slope 1x2 (no grooves), changed side-windows (60032 instead of 60592), white step at door instead of red, white grille in middle of body, handrails beside doors, doors with levers, small changes on undercarriage. Let me know what you think about. BrickMusher P.S. Yes, I need a new camera. This is the best result I could get so far. Sorry Edited January 21, 2018 by BrickMusher added P.S., typos Quote
ColletArrow Posted January 21, 2018 Author Posted January 21, 2018 Perfect! I think all the modifications you made to the nose look better, I was only trying to replicate the pictures we saw. I'm still not decided on the handrails; I prefer not to include them as they look over-scaled, but that's probably just me. All the other mods are so small they're barely noticeable. I think the 1x1 tile groove could also be solved by using older parts, that also won't have the groove, but your method is pretty neat. Incidentally, how well do the pantographs hold up? Quote
