Chromed chimney is very nice addition. Just one thing - due to scale based on tires (1:15.5; tires on real CASE IH 6388 are some 1676mm "big"), front bonnet should be about 6 studs wide, so what is your idea how to achieve it (with liftarm or panel thickness of 1 stud since you have l-motor caged within 5 studs wide structure)?
Plan is to use large tiles.. Not sure if these are available and/or will work though.
Also I want to change the cab, the beams look to 'open' for my taste.. Just want to try some options and go from there I guess.. :grin:
since beams are "to open", I suggest you to use panels :wink:
(there is a bunch of panels in 42029 set - just example)
I'll start working on bonnet as soon as I finish cab; but for cab I need some extra parts which should arrive to me at the end of next week (8th February) and perhaps I could you give some idea... I'm sad that even smallest ever Steiger stx (275) uses bigger tires, so I can not make it because it uses Group 46 tires (1855mm in overall dimater); 480/80R42, 520/85R38, 650/65R38...) and we do not have LEGO tires with 123mm overall diameter, just 107mm...but there is another red tractor that I'll start building right after I finish Fastrac...
Regards
Edited by I_Igor
I'm not sure if panels are an option. Most of them are pretty big and don't come in the right shape. But like I said; I'll try some different options to see what looks best.42029 is a good suggestion. I was already looking at 42082 for parts (and awesome set ofcourse) but since I just bought 42055 my LEGO budget pretty much evaporated.
I am certainly going to check on the solutions you will come up with for your JCB. Especially because i'm still pretty new to the studless/panel building method.
The remark about the Steiger I don't quite understand. When using the 107mm tires can't you just adjust the scale accordingly to make the wheels fit the tractor? I saw that @eric trax with these wheels made a beautiful John-Deere which is in the same HP/size range I think?
Edited by Sjoemie himself
typo
1 hour ago, Sjoemie himself said:
The remark about the Steiger I don't quite understand. When using the 107mm tires can't you just adjust the scale accordingly to make the wheels fit the tractor? I saw that @eric trax with these wheels made a beautiful John-Deere with twhich is in the same HP/size range I think?
But they are out of my scale; my mocs will be the same scale (1:15) :wink:
You are welcome to follow my tread :thumbup:
53 minutes ago, Sjoemie himself said:
Aha I see. I didn't know that you only build in this one scale.
Already done!
:classic:
Cool, but to make it more like real thing, you can replicate (a bit smaller) solution from 42069; it used technic triangle type 2, and drive wheel and idler wheels are held together with triangle shaped structure.
33 minutes ago, Sjoemie himself said:
Great suggestion! I knew I saw those tracks in LEGO form somewhere but funnily enough I couldn't remember where :wacko:
That is why humans invented forums like this one :wink:
Right @I_Igor. My John Deere is on a scale of 1:18, which is a bit smaller than it usually builds and because the tires have 107 mm.
@Sjoemie himself like working on your model. You chose an interesting tractor to build. I am waiting for the final result :)
@I_Igor thank you, you are right. I was on several forums before this one. Unfortunately they kind of bled out because of people resorting to Facebook to post and share. Since I don't use that I'm glad that this forum has many members who are active.
@eric trax thank you very much. I've looked at your models for inspiration many times. I especially like that you combine technic and system elements so well.
I'm hoping to post a new update tomorrow or sunday.
