Very good, I like the presentation and apparent function of the machine.
To improve it further, could you add a gate just before the balls enter the mold? It should close when the mold is opened, and only open again when the mold has fully shut. When the mold opens and a ball runs straight through it looks a bit odd, e.g. the yellow ball at 0:08 that comes out after the red and black ones have. That might also address @Captainowie's issue.
Apart from that, I love the idea behind this module. Well done!
14 hours ago, Captainowie said:
Nice. What happens if a ball comes in just as the mould closes, as nearly happens at 0.23? Does the whole machine bind up?
Thanks! The Archimedes screw is timed so that it never happens, as it rotates exactly 4 times for every time that the gray part opens. If one does get stuck somehow then the arm attached to the grey part slides along the axle and avoids any serious damage. (This happened quite a lot during the building process)
Thank you! I might try that, good idea :)
