Posted February 26, 20187 yr This lego great ball contraption miniloop uses a Cardan mechanism to lift the marbles up, after that they role down the strings and back to the start again. It is very reliable and can be powered by a motor or a hand crank. If you want the free video instructions they are here. Â
February 26, 20187 yr Author 4 hours ago, JonathanM said: The action is mesmerising - nice work! Thank you!
February 26, 20187 yr really compact mechanism! definitely the smallest Cardan Lift I've seen! wonder what several of these chained together might look like?
February 26, 20187 yr Author 11 hours ago, RohanBeckett said: really compact mechanism! definitely the smallest Cardan Lift I've seen! wonder what several of these chained together might look like? Thank you! Unfortunately I don't have enough of the pieces used to offset the 12 tooth gear by half a stud to build more of them.
February 27, 20187 yr I never know what to say about GBCs, the idea, the development and especially the final adjustment process have to be exhausting, is the idea the most difficult part of a GBC?.
February 27, 20187 yr A great Mini GBC, found your YouTube building instructions but they are a bit hard to follow. Can you post the link so others can easily find them. Doug
February 27, 20187 yr 8 hours ago, jorgeopesi said: I never know what to say about GBCs, the idea, the development and especially the final adjustment process have to be exhausting, is the idea the most difficult part of a GBC?. I have not found that to be the case. I have a list of ideas as long as your arm. Rather, I've found that the hardest bit is making those ideas standards-conformant and reliable. Of course, if you're doing standalone things like this one, then standards conformance is not an issue. Owen.
February 28, 20187 yr Ditto... I have about 20-30 ideas I want to build... some are copies of others.. some are originals.. yet to be tested in real life just not enough time!!
February 28, 20187 yr Author 18 hours ago, Doug72 said: A great Mini GBC, found your YouTube building instructions but they are a bit hard to follow. Can you post the link so others can easily find them. Doug Yes, they are here: Sorry they are so hard to follow, I have never been very good at making instructions. 18 hours ago, Captainowie said: I have not found that to be the case. I have a list of ideas as long as your arm. Rather, I've found that the hardest bit is making those ideas standards-conformant and reliable. Of course, if you're doing standalone things like this one, then standards conformance is not an issue. Owen. I think it depends on who you ask, I personally find coming up with new ideas the hardest part.
February 28, 20187 yr Very nice. Instructions seem to take the fun out of reverse-engineering it. Â
February 28, 20187 yr I don't care too much for GBC instructions... just a few, nice clear, well lit photos from all angles are usually enough to reproduce 'enough' to get you by... and yes.. Reverse Engineering is fun!
March 1, 20186 yr Building Instructions on Planet GBC:Â http://www.planet-gbc.com/?p=2736 once again, awesome work Sawyer !Â
March 1, 20186 yr Author 1 hour ago, turbopolofr said: Building Instructions on Planet GBC: http://www.planet-gbc.com/?p=2736 once again, awesome work Sawyer ! Thank you! I am amazed how good you are at making the instructions :)
March 2, 20186 yr Very nice mechanism! I understand the neck brace to create room between the Technic cam and the liftarm L5 but it lets the gears slip in my build. Nevertheless I would like to use the liftarm mechanism in a somewhat modified way to make a serie of arms passing on balls if you permit. Of course I'll give you credit for the arm mechanism.
March 3, 20186 yr Very nice mini GBC! Thanks for the instructions, it is definitely on my to do list. Andy D
March 3, 20186 yr Author 4 hours ago, Andy D said: Very nice mini GBC! Thanks for the instructions, it is definitely on my to do list. Andy D Thanks! I would love to see photos if you do make one :)
March 3, 20186 yr 19 hours ago, Berthil said: Very nice mechanism! I understand the neck brace to create room between the Technic cam and the liftarm L5 but it lets the gears slip in my build. Nevertheless I would like to use the liftarm mechanism in a somewhat modified way to make a serie of arms passing on balls if you permit. Of course I'll give you credit for the arm mechanism. Thanks Sawyer for an amazing Mini GBC  module - which I am now building. Had to rob a Lego train for the spacer ! Mine will be multi coloured due to a limited range of parts. Built as per instructions but gears slip / drop as arm rotates back down to collect the next ball. I may have found the reason. There is a possible error in the instructions at page 27. Sea photo At page 28 Instructions show the link arm with the bachkpack spacer attaching BELOW the axle for the swinging 24T gear whereas the photo shows it is ABOVE the axle. Which is correct ? Tried in both positions with & without spacer and seems best with spacer and ABOVE axle and now appears to be working OK when tested by hand. Edited March 3, 20186 yr by Doug72
March 3, 20186 yr Hi Doug72, thanks for noticing the mistake. I'll fix the building instructions to have it ABOVE, which should indeed be the correct position. regards
March 3, 20186 yr 22 minutes ago, turbopolofr said: Hi Doug72, thanks for noticing the mistake. I'll fix the building instructions to have it ABOVE, which should indeed be the correct position. regards Many thanks for the excellent instructions,
March 3, 20186 yr This is a cool little module. Aside from the spacer no rare or difficult parts as far as I can tell. Just need to get me some balls   Thanks for sharing!
