DWJ2018 Posted May 14, 2018 Posted May 14, 2018 That’s great work; I’ve been building the new UCS Y Wing today as a bit of light relief! Need to catch up a bit now. Quote
muhkuh Posted May 20, 2018 Posted May 20, 2018 So this my current progress... I have huge problems with the front. Brickvault too, ill just w8 for you other guys:) Max Quote
bricksmarlin Posted May 20, 2018 Posted May 20, 2018 Yes, I saw the brickvault video too!I've finished all sections now, I'll start assembling tomorrow! Quote
Fuppylodders Posted May 21, 2018 Posted May 21, 2018 I have to say, I'm totally envious! Its a really nice looking build that I'd love to do and am sooo tempted! Quote
muhkuh Posted May 22, 2018 Posted May 22, 2018 So I tried some mods... But dont know if this works for me... too many gabs..:/ @cavegod: Can you help us out? Brickvault has the same problem, if you watch their latest stream at the end, they explain the problem: https://www.twitch.tv/videos/262421422 - startin at 2:45h :) Thanks for your help!!! Max Quote
DWJ2018 Posted May 23, 2018 Posted May 23, 2018 Looks like you’ve done well so far to be honest. Quote
DWJ2018 Posted May 23, 2018 Posted May 23, 2018 https://www.flickr.com/photos/127267303@N04/27427836477/in/dateposted/ What’s going on with the double hinge plates here? Looks like there meant to be protruding but in the various Flickr shots, they look combined with the structural sides? Quote
cavegod Posted May 23, 2018 Posted May 23, 2018 Hi, Your missing 1x2 ball joint connector with socket and ball at opposit ends. https://www.bricklink.com/v2/catalog/catalogitem.page?P=14419#T=C Quote
muhkuh Posted May 23, 2018 Posted May 23, 2018 4 hours ago, cavegod said: Hi, Your missing 1x2 ball joint connector with socket and ball at opposit ends. https://www.bricklink.com/v2/catalog/catalogitem.page?P=14419#T=C Ahhh thanks for your help Will try this out :) Quote
cavegod Posted May 23, 2018 Posted May 23, 2018 The inverted cheese slopes are missing aswell, they are held in with 1/2 technic pins Quote
muhkuh Posted May 23, 2018 Posted May 23, 2018 Do you have an id or number;) ty a lot:) 9 minutes ago, cavegod said: The inverted cheese slopes are missing aswell, they are held in with 1/2 technic pins Quote
cavegod Posted May 23, 2018 Posted May 23, 2018 you should have the parts as they are in the ldd file. Quote
muhkuh Posted May 24, 2018 Posted May 24, 2018 20 hours ago, cavegod said: you should have the parts as they are in the ldd file. sry but i tried to look it up... dont know what you mean exactly:/ Quote
cavegod Posted May 24, 2018 Posted May 24, 2018 2 hours ago, muhkuh said: sry but i tried to look it up... dont know what you mean exactly:/ 1x1 slope 30 degrees (cheese slopes) Quote
bricksmarlin Posted May 26, 2018 Posted May 26, 2018 (edited) Some work in progress pictures! All power functions are running, I have fixed a few small details, and made a few changes! At the moment I am working on a third floor in the interior! Edited June 3, 2018 by bricksmarlin Quote
DWJ2018 Posted May 26, 2018 Posted May 26, 2018 Great work, plus excellent photos too. I’m working on the front interior but I need to order more parts as I’m short some how. I look forward to seeing how you attach the first forward side panels. Quote
bricksmarlin Posted May 27, 2018 Posted May 27, 2018 (edited) On 27.5.2018 at 12:41 AM, DWJ2018 said: Great work, plus excellent photos too. I’m working on the front interior but I need to order more parts as I’m short some how. I look forward to seeing how you attach the first forward side panels. Thanks! Which ones do you mean? These ones? There should be no problems, I have replaced all 1x2 plates by 1x1! Edited June 3, 2018 by bricksmarlin Quote
DWJ2018 Posted May 27, 2018 Posted May 27, 2018 Yeah, I’m now doing the same, they just seem to prevent the alignment of the sides against the frame. Did you notice the use of the the plate hinge on both the side panel and the main part of the body? Seem to get in the way of each other? Quote
bricksmarlin Posted May 27, 2018 Posted May 27, 2018 (edited) On 27.5.2018 at 1:22 PM, DWJ2018 said: Yeah, I’m now doing the same, they just seem to prevent the alignment of the sides against the frame. Did you notice the use of the the plate hinge on both the side panel and the main part of the body? Seem to get in the way of each other? Yes, I noticed that! I think that's just a "careless mistake"! I'm pretty sure it has to be 1 hinge plate at the top and one at the bottom! There are a few small "mistakes" in the instruction! Example: The step where you fill up the little gap at the sidewall is missing at one side! Also missing at one side are this 1x2 tiles! other side so just add the tiles! Here you have to change the posotion of the plates like it's shown in the picture (you need the cutout for the wire in the back!)! Otherwise the caterpillar drive is mounted incorrectly! Edited June 3, 2018 by bricksmarlin Quote
KevinMD Posted May 27, 2018 Posted May 27, 2018 @bricksmarlin you are a treasure of SW MOC info. Quote
bricksmarlin Posted May 27, 2018 Posted May 27, 2018 (edited) On 27.5.2018 at 5:01 PM, KevinMD said: @bricksmarlin you are a treasure of SW MOC info. Thanks Added the front walls for testing! Edited June 3, 2018 by bricksmarlin Quote
muhkuh Posted May 28, 2018 Posted May 28, 2018 On 23.5.2018 at 2:33 PM, cavegod said: Hi, Your missing 1x2 ball joint connector with socket and ball at opposit ends. https://www.bricklink.com/v2/catalog/catalogitem.page?P=14419#T=C Hey cavegod i tried this, but this doenst wortk at :/ do you have some picture of the front of your "live" model? If the angels for the lower front works the top doesnt fit right..:/ Thanks Max Quote
muhkuh Posted May 30, 2018 Posted May 30, 2018 done :) had to do some other connections for the front, cause I was not rly happy with result of the instructions. Now I will add some more details:) Quote
DWJ2018 Posted May 30, 2018 Posted May 30, 2018 Well done, it looks great from here. Now it’s finished, what do you think of the build? Quote
