The IGV-55 is a intel modification of the gozanti class. Pictures are rare on this one, i found different Versions of the ship.
The wings are too thick right now - 3 plates high should be mor than enough. Need to make a different greebling.
Overall the ship has plenty of different angles. Not sure how far i go with the angles, because of the stability.
Partcount is 469 right now.
Part count 527Bricks estimated part prices 60€
The wings are thinner now, rebuilt the engines a bit. And the light gray wedges behind the cockpit.
Edited by Midlife-crisis
indeed it looks goofy. :)
did roof and tail again, which reduced the part count, and make the model more accurate. I also changed some uncommon parts to common ones.
- Engines Mod
- 2nd cannon on the underside
- Overall high is 1plate less.
I think it´s time to order some parts. (Part count: 547)
