Posted March 16, 20186 yr Hi everyone, I am currently working on the Downtown Diner and received a window screen that is not clear: LEGO milky window by randomboy, on Flickr Has anyone else gotten one of these? Curious if this is common as it has never happened to me before. Thanks, randomboy
March 16, 20186 yr 3 hours ago, Forresto said: I've never seen this before but its a cool defect. Would work very well in MOCs. Agreed Boy that is random, I've not seen one like that, even though they are rarely totally without some sort of anomaly.
March 16, 20186 yr Lego can send you a replacement, if this is a mismould then it might be worth something, i suspect that there was some white ABS left on the nozzle leading to the milky effect when it mixed with the clear plastic. Edited March 16, 20186 yr by Agent Kallus
March 16, 20186 yr 33 minutes ago, Agent Kallus said: Lego can send you a replacement, if this is a mismould then it might be worth something, i suspect that there was some white plastic left on the nozzle leading to the milky effect when it mixed with the clear ABS. Transparent parts are made from acrylic, but still I indeed think that that was the reason for this to happen indeed.
March 16, 20186 yr 1 minute ago, JopieK said: Transparent parts are made from acrylic, but still I indeed think that that was the reason for this to happen indeed. Ah yes sorry.
March 19, 20186 yr On 3/16/2018 at 6:52 PM, JopieK said: Transparent parts are made from acrylic, but still I indeed think that that was the reason for this to happen indeed. Actually, transparent Lego parts are made from Polycarbonate, which looks similar to acrylic but is more resistant to heat and breakage.
March 20, 20186 yr Shame you receive just one like that, it would be great to use them in a winter theme house.
March 22, 20186 yr You can get old 7026 (Bricklink number) 2x2 windows in their frames by the thousands in very used condition... for only 3 cents each. They were made from 1956-2003 and there are over 20 thousand available in red alone in used condition at various prices. Edited March 22, 20186 yr by LEGO Historian
