Posted March 20, 20186 yr I'm getting a little behind on posting some of the projects I have finished. Either way, here is a mid sized manual tractor, based (can't we get some red medium sized wheels) of the Claas Atos. A full gallery may be found on Flickr, and much more at thirdwigg.com. Features: Rear wheel drive Steering 3 cylinder engine Front PTO Front Drawbar Rear PTO with on/off Rear Drawbar a couple of implements, more coming (probably) Edited March 20, 20186 yr by Thirdwigg
March 20, 20186 yr It is a nice change to see a tractor moc, but you need red rims (at least there are dark red) and front wheels are to big. In order to mantain correct tire proportions, you should use 56 tires at front. Other things are good
March 21, 20186 yr Nice, I do agree with @I_Igor that it would be better with red rims, but I think green looks good too. 8 hours ago, Thirdwigg said: I'm getting a little behind on posting some of the projects I have finished. So am I...
March 21, 20186 yr I think yellow rims would look good.. check out this google link https://www.google.com/search?q=green+tractor&newwindow=1&rlz=1C1CHBD_enUS768US768&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjCqJzt7_zZAhVK8WMKHYj-CxUQ_AUICigB&biw=1455&bih=734 I almost forget, Your model is very detail, full of functions and a good looking tractor!!! Very good job!!! Edited March 21, 20186 yr by sirslayer spelling
March 21, 20186 yr 1 hour ago, sirslayer said: I think yellow rims would look good.. check out this google link https://www.google.com/search?q=green+tractor&newwindow=1&rlz=1C1CHBD_enUS768US768&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjCqJzt7_zZAhVK8WMKHYj-CxUQ_AUICigB&biw=1455&bih=734 I almost forget, Your model is very detail, full of functions and a good looking tractor!!! Very good job!!! It's meant to be a CLAAS, not a John Deere, so yellow rims wouldn't be overly accurate. White rims might work if you take inspiration from FS17 mods... However, these only ever came in two sets, so hope you've got 'em in reserve, @Thirdwigg...
March 21, 20186 yr Here is a short technical specifications sheet about Atos...there are 3 models (220-230-240) with 3 cylinder engine and have 540/65R30 at rear (1487mm diameter) and 360/70R24 at front (1074mm diameter), so if you use 1:18 measurement to fit it 81,6 x 38 tire, ideal will be some 60mm front tire... http://www.claas.co.uk/blueprint/servlet/blob/543742/8a475ddf88af5a253c27cca264632138/241563-dataRaw.pdf Edited March 21, 20186 yr by I_Igor
March 21, 20186 yr Author I didn’t think the wheels would be such a point of conversation. I tried the dark red, but they looked a little too heavy. I’ll post a photo when I am back home. I consider myself an avid brick link browser, but the white wheels are new to me. I didn’t even think about that as an option. I may need to try that. @I_Igor I made the choice for the larger front wheels and tires consciously. The 56s looked too small, as it seems to convey a larger series tractor. It also took away the ability for front PTO and drawbar as it would lower the wheel center by a stud.
March 22, 20186 yr 11 hours ago, Thirdwigg said: I didn’t think the wheels would be such a point of conversation. I tried the dark red, but they looked a little too heavy. I’ll post a photo when I am back home. I consider myself an avid brick link browser, but the white wheels are new to me. I didn’t even think about that as an option. I may need to try that. @I_Igor I made the choice for the larger front wheels and tires consciously. The 56s looked too small, as it seems to convey a larger series tractor. It also took away the ability for front PTO and drawbar as it would lower the wheel center by a stud. Kyle, perhaps you can fit one 68.7 tire in 81,6 tire to make it a bit bigger or even use 94,8 tire...proportions on classic tractors are something like on my brickshelf folder (which could help you in some way...) http://www.brickshelf.com/cgi-bin/gallery.cgi?f=365315
October 25, 20195 yr Author I have completed instructions for this tractor. You may find the album here. I guess it took me a while to disassemble it because I was having so much fun playing with it. Enjoy.
