This is my first WIP post on EuroBricks where I will show my progress on my newest build, an EV3-powered 1:8 replica of Lexus' newest flagship coupe, the LC500.
The car will most likely be a combination of both the standard and the V6 hybrid LC, but it will have a V8. The body will also be orange.
Here's a photo I found of an LC that looks a lot like the one I am shooting for.
Features I'm planning to add:
  • Four or six-speed paddle-shift transmission
  • Retractable spoiler
  • Detailed interior
  • Fake V8 engine (but I would like to achieve moving pistons)
  • Full independent suspension
All I built so far was the rear axle for the LC. It's exactly like the one in the Porsche 911 GT3 RS set but more reinforced.
I also made the V8 engine using Lego Digital Designer.
I plan to build the paddle-shifting mechanism used in Didumos' Ultimately Playable Porsche 911 GT3 RS (the one with the tilted wheel) and pair it up with a gearbox. I currently am having trouble whether to motorize his gearbox with the EV3 motors or to pick a different one with less gears and friction.
I also am having a little bit of trouble finding the right front axle, though I like the one that Didumos put his Porsche because of the fact that is has two shocks for each wheel. However, I find it very difficult to fit the V8 engine in the middle since the axle is made for a rear-engine car.
Here's a poorly drawn render I made of what I'm trying to achieve with the front axle.
And here's the chassis in the real LC and the measurements for the LC Lego model.
Overall, I'm excited about the build. I would welcome some helpful comments about the V8 engine, axles, and the gearbox I planned to use before I order pieces on BL. Once I start working on the body and aesthetics, I would appreciate some input with that as well.
I can also give you the download for the .lxf file of the engine if you'd like to check it out.
I look forward to replying to your comments and sharing my progress. Thank you.
Edited by StudRobotics
