Leonardo da Bricki Posted April 1, 2018 Posted April 1, 2018 Mind-blowing build! I've been watching the updates on this build for a really long time now. The finished product is incredible: details, functions, sheer size... Quote
Jurss Posted April 3, 2018 Posted April 3, 2018 Amazing details, amazing model. Engine timing chain is rusty ... :D Quote
Lucio Switch Posted April 3, 2018 Posted April 3, 2018 Finally it's done!! It's epic! Lots of really cool details, but the microwave it's the cherry on the cake. I would have used 2 more XL motors instead the gearbox, I think that it could perform a bit better. But it's just my tought! Hats off! Quote
allanp Posted April 3, 2018 Posted April 3, 2018 2 hours ago, Lucio Switch said: Finally it's done!! It's epic! Lots of really cool details, but the microwave it's the cherry on the cake. I would have used 2 more XL motors instead the gearbox, I think that it could perform a bit better. But it's just my tought! Hats off! But two XL motors are already breaking the universal joint. Wouldn't 4 adequately powered XL motors break the UJ even without a gearbox? Or would you gear it differently ( gear motors up > UJ > gear down) or would you build a custom UJ? Besides even ONE XL motor can cause the 20 tooth double bevel gear to slip on the differential gear. Quote
Lucio Switch Posted April 3, 2018 Posted April 3, 2018 15 minutes ago, allanp said: But two XL motors are already breaking the universal joint. Wouldn't 4 adequately powered XL motors break the UJ even without a gearbox? Or would you gear it differently ( gear motors up > UJ > gear down) or would you build a custom UJ? Besides even ONE XL motor can cause the 20 tooth double bevel gear to slip on the differential gear. I would gear them differently. I don't know how is geared in this MOC, but I would increase the rpm of the whole transmission (decreasing the transmitted torque accordingly) and I would decrese the speed only in the portal hubs, this is how my Crane Truck worked. It weight 8.6kg. Quote
Sariel Posted April 3, 2018 Author Posted April 3, 2018 4 XL motors and a custom-built u-joint would be a good option. The downside is that 2 more XLs means 1 additional battery with 1 additional IR receiver. Quote
