pagicence Posted July 5, 2018 Posted July 5, 2018 Ok, Didumos is clearly bored. Give him something to do. Quote
TechnicRCRacer Posted July 7, 2018 Posted July 7, 2018 (edited) Here is the spoiler for the project. I forgot to delete the old one outside the car, but the new system is in the car already. Can somebody test-build it? https://bricksafe.com/pages/TechnicRCRacer/randomfiles Edited July 7, 2018 by TechnicRCRacer Quote
mocbuild101 Posted July 7, 2018 Posted July 7, 2018 1 hour ago, TechnicRCRacer said: Here is the spoiler for the project... Is your post missing something...? Quote
TechnicRCRacer Posted July 7, 2018 Posted July 7, 2018 13 hours ago, mocbuild101 said: Is your post missing something...? Whoops, forgot to paste the link! Adding now. Quote
BrickbyBrickTechnic Posted July 7, 2018 Posted July 7, 2018 Hey everyone, just a question: I managed to order some of the new 20z cutch gears and wave selector. Does anyone want a redesign of the gearbox which contains both parts? Also, shifter redesign will come in a few days. Quote
Alex Ilea Posted July 7, 2018 Posted July 7, 2018 Don't redesign it! Not all of us have those pieces but still want to build the whole xar in the end! Quote
KikoTube Posted July 7, 2018 Posted July 7, 2018 Just now, IA creations said: Don't redesign it! Not all of us have those pieces but still want to build the whole xar in the end! Yes, please dont use them. Those will be rare Quote
BrickbyBrickTechnic Posted July 8, 2018 Posted July 8, 2018 4 hours ago, KikoTube said: Yes, please dont use them. Those will be rare Ok, I won't. I was just throwing around a suggestion Quote
BrickbyBrickTechnic Posted July 8, 2018 Posted July 8, 2018 Shifter time! After tampering with several designs, I settled on one of @Didumos69's designs. I took the essential concept and built a compact housing for it which fits the renders of the chassis. The 9l and 13l beams represent those of the chassis as it is now. Hope this works. Quote
Didumos69 Posted July 9, 2018 Posted July 9, 2018 21 hours ago, BrickbyBrickTechnic said: Shifter time! After tampering with several designs, I settled on one of @Didumos69's designs. I took the essential concept and built a compact housing for it which fits the renders of the chassis. The 9l and 13l beams represent those of the chassis as it is now. But how does this connect to the gearbox? The control axle was moved to the back as much as possible - and tied to the gearbox with 6l links - to create space for the seats. Quote
BrickbyBrickTechnic Posted July 9, 2018 Posted July 9, 2018 (edited) 14 minutes ago, Didumos69 said: 6l links Are 9l links possible? If so, there should be enough room to stick in the shifter. EDIT: I checked the renders again and using 9l links means ample space for the shifter. If that fails, I have 1 more idea. Edited July 9, 2018 by BrickbyBrickTechnic Quote
Didumos69 Posted July 14, 2018 Posted July 14, 2018 (edited) On 7/9/2018 at 8:00 PM, BrickbyBrickTechnic said: Are 9l links possible? If so, there should be enough room to stick in the shifter. EDIT: I checked the renders again and using 9l links means ample space for the shifter. If that fails, I have 1 more idea. Even if we would revert to 9L links, which I think would be a pity, the main problem I see is that the shift lever would be more or less behind the seats. I think the shift lever and the control axle should somehow be split. The lever nicely in-between the seats and the control axle behind the seats. Edited July 14, 2018 by Didumos69 Quote
BrickbyBrickTechnic Posted July 14, 2018 Posted July 14, 2018 4 hours ago, Didumos69 said: Even if we would revert to 9L links, which I think would be a pity, the main problem I see is that the shift lever would be more or less behind the seats. I think the shift lever and the control axle should somehow be split. The lever nicely in-between the seats and the control axle behind the seats. I can work on changing it in the next few days. Quote
pagicence Posted July 28, 2018 Posted July 28, 2018 I need to poke the bear on more time. I know that TC14 is in full swing, but damn... there hasn't been a progress here in 2 weeks. Maybe the summer vacations are to blame.. who knows. Anyway @letsbuild how are thing? What's going on? Quote
Aventador2004 Posted August 12, 2018 Posted August 12, 2018 I assume we are at a point of slow progress? Because I made some ideas of a finished bodywork. Are you done @BrickbyBrickTechnic? Where is @letsbuild? Quote
BrickbyBrickTechnic Posted August 12, 2018 Posted August 12, 2018 29 minutes ago, Aventador2004 said: Are you done @BrickbyBrickTechnic? I've been working on the shifter in the background of my current project. It will be ready soon. Quote
Aventador2004 Posted August 12, 2018 Posted August 12, 2018 2 minutes ago, BrickbyBrickTechnic said: I've been working on the shifter in the background of my current project. It will be ready soon. Okay. Thanks. Quote
mocbuild101 Posted August 13, 2018 Posted August 13, 2018 9 hours ago, Aventador2004 said: Where is @letsbuild? No idea, he hasn't been on Eurobricks since June... 8 hours ago, BrickbyBrickTechnic said: It will be ready soon. Great! I really want to see this finished, especially considering how far we have come... Quote
BrickbyBrickTechnic Posted August 13, 2018 Posted August 13, 2018 4 hours ago, mocbuild101 said: Great! I really want to see this finished, especially considering how far we have come... It's done now. I just have to post pictures. Quote
BrickbyBrickTechnic Posted August 13, 2018 Posted August 13, 2018 Shifter: I have 2 options given here. One uses idler gears to distance the shifter from the gearbox, the other a liftarm. The latter may not fit the specifications. More idler gears can be added as needed to the first, and the liftarm length can be extended on the latter. If you need more pictures, I am at your service. I was in a rush today Quote
Jeroen Ottens Posted August 14, 2018 Posted August 14, 2018 I vote for the liftarm solution. Those knobwheels do not work well when there are three in a row. You can avoid that problem by using normal gears, but than the automatic alignment is not there anymore. Quote
Didumos69 Posted August 21, 2018 Posted August 21, 2018 On 8/13/2018 at 6:46 PM, BrickbyBrickTechnic said: Shifter: I have 2 options given here. One uses idler gears to distance the shifter from the gearbox, the other a liftarm. The latter may not fit the specifications. More idler gears can be added as needed to the first, and the liftarm length can be extended on the latter. If you need more pictures, I am at your service. I was in a rush today On 8/14/2018 at 4:42 PM, Jeroen Ottens said: I vote for the liftarm solution. Those knobwheels do not work well when there are three in a row. You can avoid that problem by using normal gears, but than the automatic alignment is not there anymore. Thanks @BrickbyBrickTechnic! I agree with @Jeroen Ottens. I will try to fit the liftarm version in the rest of the chassis. Quote
letsbuild Posted September 1, 2018 Author Posted September 1, 2018 Hello everyone! I am back, and ready to reanimate this project. I just read through the last few weeks of progress, which, needless to say, there wasn't much, but I did see a tilted steering wheel (awesome job, @IA creations), a new shifter (which looks good, I hope it works good too!), and a picture of the car up to now. I'm impressed! Could I get a report from everyone working this project on the status of their job, please? Cheers, Let's Build! Quote
TechnicRCRacer Posted September 1, 2018 Posted September 1, 2018 Job: Rear spoiler Status: Finished (I think) Quote
BrickbyBrickTechnic Posted September 1, 2018 Posted September 1, 2018 Job: gearbox, shifter. Status: new shifter made, up to @Didumos69 to integrate it. Gearbox finished ages ago. Quote
