Carsten Svendsen Posted April 6, 2018 Posted April 6, 2018 I will sign up for the building team. I have heaps of time during the day as I'm home from work at 15:00 Quote
letsbuild Posted April 6, 2018 Author Posted April 6, 2018 (edited) 8 hours ago, IA creations said: I guess within the design process we also need to build a real life model to test if it actualy works, right? @letsbuildwill do my best! OffroadCreat1ons answered your question. 7 hours ago, Didumos69 said: @letsbuild, well, that is quite a challenge for such a small scale! One question, do the axles need to have suspension? And differentials? Does the gearbox need a center differential? Or is that all up to the specific designers? All features are up to the designers. It would be really nice if you could make your section as packed as possible, seeing as that's all you have to build. 7 hours ago, BrickbyBrickTechnic said: #2- BrickbyBricktechnic I like the idea of a modular truck. The bar isn't too high, and the result ends being pretty awesome. Sounds good, although you know we aren't building a truck, right? 6 hours ago, Aventador2004 said: Suspension or not @letsbuild? The first is being difficult with regular pieces. It's up to you, but it would be nice to have some. 4 hours ago, TechnicRCRacer said: I would do this, but I am not sure if my building skills are up to par with you guys’. If there is a very small roll, I would be happy to help. I put you in for the pop-up headlights. 3 hours ago, Aventador2004 said: If you need a section builder / tester, I can be one. I am home all day. Are you sure you have time in the next few weeks? This project won't take one day. 1 hour ago, Carsten Svendsen said: I will sign up for the building team. I have heaps of time during the day as I'm home from work at 15:00 Okay, I've put you down. I'm still looking for an interior designer. Edited April 6, 2018 by letsbuild Quote
Didumos69 Posted April 6, 2018 Posted April 6, 2018 @letsbuild, perhaps seats could be mentioned as a separate topic, apart from the rest of the interior. Quote
Aventador2004 Posted April 6, 2018 Posted April 6, 2018 9 hours ago, letsbuild said: I'm still looking for an interior designer. I can, but someone else may also. My first draft of suspension (Making LXF.) Quote
letsbuild Posted April 6, 2018 Author Posted April 6, 2018 10 hours ago, Didumos69 said: @letsbuild, perhaps seats could be mentioned as a separate topic, apart from the rest of the interior. I figured the rest of the interior wouldn't be very difficult, so I lumped it all together 6 hours ago, Permo said: I'll be Statler and Waldorf... Please do! 27 minutes ago, Aventador2004 said: I can, but someone else may also. My first draft of suspension (Making LXF.) Looks good! Don't rush it, though. Take your time, make it good! Quote
Aventador2004 Posted April 6, 2018 Posted April 6, 2018 Just now, letsbuild said: I figured the rest of the interior wouldn't be very difficult, so I lumped it all together Please do! Looks good! Don't rush it, though. Take your time, make it good! It is #5 draft ATM. I Just wanted to see what others thought. Quote
Alex Ilea Posted April 6, 2018 Posted April 6, 2018 @Aventador2004I think we should work together because I am the engine guy Quote
offroadcreations Posted April 6, 2018 Posted April 6, 2018 I've started the doors. They aren't really butterfly doors because they don't swing up and out at an angle, and they aren't a dihedral synchro-helix linkage, because they don't swing out. What they do is, as they rotate up, the gear meshes the rack to push the door outwards. I'll have to refine the linkage and the doors themselves once more of the car is built. Here's a render: Quote
Aventador2004 Posted April 6, 2018 Posted April 6, 2018 16 minutes ago, IA creations said: @Aventador2004I think we should work together because I am the engine guy I will make a preliminary LXF and send it to you. Dont forget Didumos needs a Chassis ready first (Absolutely no pressure.) Quote
letsbuild Posted April 6, 2018 Author Posted April 6, 2018 17 minutes ago, Offroadcreat1ons said: I've started the doors. They aren't really butterfly doors because they don't swing up and out at an angle, and they aren't a dihedral synchro-helix linkage, because they don't swing out. What they do is, as they rotate up, the gear meshes the rack to push the door outwards. So, you've basically built the doors for a koegnigsegg. I was talking about something like from a Mclaren. Quote
Didumos69 Posted April 6, 2018 Posted April 6, 2018 (edited) 2 hours ago, Aventador2004 said: I will make a preliminary LXF and send it to you. Dont forget Didumos needs a Chassis ready first (Absolutely no pressure.) Nice work on the axles! A floating diff house, I was already thinking that would be the only way to make it 23 studs wide. Might as well share your LXF here, so I can use it too. Btw, don't wait for me with sharing axles and engine. My idea is to tie everything together. Can't make a chassis if I don't know the axles or engine. With rear axles and engine, integrated or not, I can make a start. Edited April 6, 2018 by Didumos69 Quote
BrickbyBrickTechnic Posted April 6, 2018 Posted April 6, 2018 @letsbuild , please clarify for me: what exactly do the builders do? Also you added me to the list right? Quote
offroadcreations Posted April 6, 2018 Posted April 6, 2018 2 hours ago, letsbuild said: So, you've basically built the doors for a koegnigsegg. I was talking about something like from a Mclaren. Ok. How about this? It hinges up and out at the same time. Pretty simple though. Quote
Aventador2004 Posted April 6, 2018 Posted April 6, 2018 31 minutes ago, Didumos69 said: Nice work on the axles! A floating diff house, I was already thinking that would be the only way to make it 23 studs wide. Might as well share your LXF here, so I can use it too. Btw, don't wait for me with sharing axles and engine. My idea is to tie everything together. Can't make a chassis if I don't know the axles or engine. With rear axles and engine, integrated or not, I can make a start. Ok, it is in progress now. Quote
Aventador2004 Posted April 6, 2018 Posted April 6, 2018 @Didumos69 : Here is a prelim LXF: https://bricksafe.com/files/aventador2014/CollaborationSupercarSuspensionRearLXF.lxf Quote
Alex Ilea Posted April 6, 2018 Posted April 6, 2018 @Offroadcreat1onsI'd say go for a combination between 42069 doors and sheepo's i8 doors, that seems a tad to basic tbh Quote
TechnicRCRacer Posted April 6, 2018 Posted April 6, 2018 This is looking sweet so far! After I see the final model, I might consider building it. Quote
letsbuild Posted April 6, 2018 Author Posted April 6, 2018 4 hours ago, BrickbyBrickTechnic said: @letsbuild , please clarify for me: what exactly do the builders do? Also you added me to the list right? The builder a take virtual models and build them in real life to see if they work. 4 hours ago, Offroadcreat1ons said: Ok. How about this? It hinges up and out at the same time. Pretty simple though. Sometimes the simplest mechanism's the best. Try some other stuff, maybe try a dihedral door. Quote
letsbuild Posted April 7, 2018 Author Posted April 7, 2018 @Aventador2004 I built your LDD axle, and I recommend you try a different design. The one you uploaded isn't very smooth when the suspension is compressed. This is undesirable. Quote
Aventador2004 Posted April 7, 2018 Posted April 7, 2018 19 minutes ago, letsbuild said: @Aventador2004 I built your LDD axle, and I recommend you try a different design. The one you uploaded isn't very smooth when the suspension is compressed. This is undesirable. Try without the 4L axles, that may improve it. The axles stabilize, but are not needed. Quote
letsbuild Posted April 7, 2018 Author Posted April 7, 2018 2 hours ago, Aventador2004 said: Try without the 4L axles, that may improve it. The axles stabilize, but are not needed. Even without them, the problem persists, but worse. Quote
Aventador2004 Posted April 7, 2018 Posted April 7, 2018 8 minutes ago, letsbuild said: Even without them, the problem persists, but worse. Ok, I will rework it. Quote
letsbuild Posted April 7, 2018 Author Posted April 7, 2018 1 hour ago, Aventador2004 said: Ok, I will rework it. Ok, thank you Quote
Aventador2004 Posted April 7, 2018 Posted April 7, 2018 Well, can we do without a differential? Quote
