Posted April 17, 20186 yr Hello all! I'm back with another fun model! This one is meant to be a midsize compact excavator, sort of like the CAT 320D or Komatsu PC210. Tracks Slewing (by hand) Boom elavation Stick + bucket Cabin + seat Opening engine compartment Hope you like it, video soon! Thanks for looking!
April 18, 20186 yr I like the contrast with your colors and being compact you did a good job on the use of your panels!! Great job overall
April 18, 20186 yr Looks great! Nice use of studded pieces on the back too - much better than panels (which you also did a good job of) It would be good to see more of the insides (gearing) though, as it's not very clear how they work...
April 18, 20186 yr Author 9 hours ago, sirslayer said: I like the contrast with your colors and being compact you did a good job on the use of your panels!! Great job overall Thank you, I loved making this project. 9 hours ago, mocbuild101 said: Looks great! Nice use of studded pieces on the back too - much better than panels (which you also did a good job of) It would be good to see more of the insides (gearing) though, as it's not very clear how they work... Thank you, I have been using studded a lot more recently. Ok, I will take a unbodied picture.
April 18, 20186 yr Wow! I really like this. So much function in such a small size. Could you show a video of it in action? Andy D
April 18, 20186 yr Author Just now, Andy D said: Wow! I really like this. So much function in such a small size. Could you show a video of it in action? Andy D Yes, hopefully later today. I also am going to try adding a slewing gear.
April 18, 20186 yr Neat! The arm looks quite good despite being hollow, and the body paneling is excellent. My only criticism is that I think the cab looks to small for this size of machine; however, it's shaping is nice. I reckon just 1 or 2 studs larger in each direction should do it. I would also suggest moving it backwards, but that's not possible given the panels. Good work overall though.
April 18, 20186 yr Author Thank you Collet. The arm was really hard to make. I don't really want to change the cab, it really gives character. @mocbuild101 here are pictures: Video is filmed, just needs upload.
April 19, 20186 yr Great little model. I like the intricate arm mechanism and the fact that you managed to put that many functions in such a small body. My only criticism would be that the closed bodywork clashes a bit with the skeleton arm. It feels like two designers have been working on this model, loosing a bit of coherence in the process. But other than that, well done
April 19, 20186 yr Author 5 hours ago, Jeroen Ottens said: Great little model. I like the intricate arm mechanism and the fact that you managed to put that many functions in such a small body. My only criticism would be that the closed bodywork clashes a bit with the skeleton arm. It feels like two designers have been working on this model, loosing a bit of coherence in the process. But other than that, well done Thank you, but it didn't look great with any other way. The arm would be at loss of functions.
April 19, 20186 yr 4 hours ago, Aventador2004 said: Thank you, but it didn't look great with any other way. The arm would be at loss of functions. Looks like there are some liftarms you might be able to attach long tiles to using 1/2 pins with hollow studs. Possibly the uppermost horizontal one and the outer sides of the two going down from that to the bucket. I can see how most other areas would block functionality.
April 19, 20186 yr Author 2 hours ago, NeilJam said: Looks like there are some liftarms you might be able to attach long tiles to using 1/2 pins with hollow studs. Possibly the uppermost horizontal one and the outer sides of the two going down from that to the bucket. I can see how most other areas would block functionality. Interesting idea, I will try that!
April 21, 20186 yr Looking at the photos of your gearing makes this little model all that much more interesting. Now if I could just figure out how it actually works... BTW: I can't find your video. Andy D
April 21, 20186 yr Author 22 minutes ago, Andy D said: Looking at the photos of your gearing makes this little model all that much more interesting. Now if I could just figure out how it actually works... BTW: I can't find your video. Its way less complex than it looks, take a look at this: Video is to be uploaded.
April 21, 20186 yr Thanks for the diagram, that is sort of what I was thinking, but I also thought... nah, that's too easy. Also I missed the control for the red line section. Thanks for the explanation. I just makes me appreciate it more! Andy D
April 21, 20186 yr Author 7 minutes ago, Andy D said: Thanks for the diagram, that is sort of what I was thinking, but I also thought... nah, that's too easy. Also I missed the control for the red line section. Thanks for the explanation. I just makes me appreciate it more! Andy D I wanted simple, so that's what I did. You're welcome.
