sawyer klegr Posted April 22, 2018 Posted April 22, 2018 This lego great ball contraption module uses a three sided wheel with "forks" to lift the marbles to the next module. The module is surprisingly reliable but it can take some time to get it running well. The stepper used to load the main mechanism works fairly well but it could still use some work, as you can see at 0:50 in the video it does not always work perfectly. The instructions, LDD file and part list are here. I used 1x3 technic half beams instead of the correct 1x5 ones in the instructions becuase LDD does not have them. The differential gear is not essential, it is only to make it easier to set the timming of the loading mechanism. Quote
Frequenzberater Posted April 23, 2018 Posted April 23, 2018 As always a really nice mechanical solution. I like it al lot! Quote
dtoerien Posted April 23, 2018 Posted April 23, 2018 Thank you - another one to add to the list. I have now built both the Lifting Cup Miniloop and Cardan Lift Miniloop, but have yet to get either to work as consistently as yours do. The LEGO GBC club that I started at school is now up and running, so perhaps the students can help me figure it out. Regards, Darryl Quote
sawyer klegr Posted April 23, 2018 Author Posted April 23, 2018 48 minutes ago, dtoerien said: Thank you - another one to add to the list. I have now built both the Lifting Cup Miniloop and Cardan Lift Miniloop, but have yet to get either to work as consistently as yours do. The LEGO GBC club that I started at school is now up and running, so perhaps the students can help me figure it out. Regards, Darryl Thanks! I hope you can get them running well soon :) Quote
sawyer klegr Posted April 26, 2018 Author Posted April 26, 2018 On 4/23/2018 at 9:33 PM, Frequenzberater said: As always a really nice mechanical solution. I like it al lot! Thank you :) Quote
TechnicRCRacer Posted April 26, 2018 Posted April 26, 2018 Clever! As others have said, I really like the mechanical solutions in your GBCs! It proves that not everything needs motor controllers to be synchronized correctly. Quote
sawyer klegr Posted April 27, 2018 Author Posted April 27, 2018 22 hours ago, TechnicRCRacer said: Clever! As others have said, I really like the mechanical solutions in your GBCs! It proves that not everything needs motor controllers to be synchronized correctly. Thanks! I find it more fun to build them with only one motor :) Quote
