lcvisser Posted May 18, 2018 Posted May 18, 2018 For a while I thought I was looking at renders, but I was wrong. This is coming together great, really cool to see the progress! Quote
Sebeus I Posted May 18, 2018 Author Posted May 18, 2018 (edited) Thanks a lot for the encouraging feedback 7 hours ago, Jim said: You will be needing a Car Expert tag soon The rear axle doesn't look like what I'm going for, the wheels are simply attached to two technic bricks, I want something that kind of looks like double-wishbone independent suspension. I came up with an alternative last night. Rear axle lower subframe: The black frame will attach to the underside of the gearbox, the tan cross axle pins are what the wheels attach to and the upper holes will provide attachment points for the rear subframe. This means that I'll be adjusting the rear subframe next, in order to fit the new rear axle installation. I will give the skeleton structure a little bit more thought this time, considering I'll have to connect air intakes and exhausts. But I will get there eventually . Edited May 18, 2018 by Sebeus I Quote
Permo Posted May 18, 2018 Posted May 18, 2018 This is looking really slick ! It's not so technic, but I like it a lot, the interior is simply beautifull Quote
LM71Blackbird Posted May 18, 2018 Posted May 18, 2018 This is turning out great! All the little details are coming together really nice! Keep up the great work. Can't wait to see the finished product! Quote
Sebeus I Posted May 21, 2018 Author Posted May 21, 2018 Rear Subframe: This new subframe will make it easier to route the exhaust pipes through the dense chassis structure. I'll have to make some modifications to the underside of the engine and transmission though, in order to fit in the new subframe. But I'm sure it will work out this time . Fuel Tank: I almost forgot this rather indispensable component. It will be located behind the seats, just in front of the engine. I should still attach the filler necks (one on each side) though. I might have the next update ready by tomorrow. Quote
Jeroen Ottens Posted May 21, 2018 Posted May 21, 2018 The rear suspension looks great, but it is a bit flimsy... It is only the friction on the stud of the jumperplates that prevents the whole assy from rotating, right? I do love that slight taper in the grey beams Quote
Johnny1360 Posted May 21, 2018 Posted May 21, 2018 I really dig these Model Team type builds and this is no exception. Great work so far, following with great interest, so many good ideas here. Look forward to seeing it finished. Quote
Sebeus I Posted May 21, 2018 Author Posted May 21, 2018 2 hours ago, Jeroen Ottens said: The rear suspension looks great, but it is a bit flimsy... It is only the friction on the stud of the jumperplates that prevents the whole assy from rotating, right? At the moment, yes. But the construction will become more sturdy once the gearbox is in place as that one will connect to both lower suspension frame and upper subframe. Quote
Sebeus I Posted May 22, 2018 Author Posted May 22, 2018 (edited) Electronic Control Unit: The ECU, in a plastic case ofcourse, to protect it from water and dirt. This one goes underneath the dashboard. The main wiring harness attached to it. these wirings are often referred to as 'cuttlefish' in an assembly area. Battery: Located in the lower front of the vehicle. Normally it should have some warning stickers. I didn't bother to make a fuse box, not really relevant on this scale, besides, I haven't foreseen any airconditioning, windscreenheater or any other device that might need a fuse anyway. Oil reservoir: Assembly: Everything comes together... To be honest I have no Idea what the welding kit is supposed to represent, just a meaningless detail I guess The only thing that remains now before I can start on the bodywork are the exhaust and air intake pipes. Edited May 22, 2018 by Sebeus I Quote
zux Posted May 22, 2018 Posted May 22, 2018 2 hours ago, Sebeus I said: To be honest I have no Idea what the welding kit is supposed to represent, just a meaningless detail I guess Hydraulics for suspension? Power steering fluid? Engine coolant? I know, last one sounds a bit odd, but radiator could still be in the front, so it would make sense. Quote
bombcar Posted May 22, 2018 Posted May 22, 2018 If it were near the engine it'd be the nitrous boost; perhaps it's a tank for air-assisted braking or something? Quote
Sebeus I Posted May 26, 2018 Author Posted May 26, 2018 Interesting suggestions . I've completed stage 1: Complete Chassis: Exhaust mufflers, air intakes and intercoolers added. (in some pictures I changed the intercoolers). The air intakes may still be relocated, it kind of depends on the bodywork I will add. The sand red grill tiles are supposed to be parts of the air filter, which should normally not be visible. The complete engine package fits barely on the chassis, it was quite the challenge to route exhausts and air pipes through the installation. I added protection for the steering cylinder, while this is accurate to the real thing my chassis could use the extra reinforcement (the front crash structure crashed a bit too easely ). The exhaust pipes are insulated near the rear suspension ( the ribbed metallic hoses) as they pass through the wishbone installation. The actual exhaust tips will be determined as I build the rear bumper. That's it for now, the bodywork will be something entirely different, I don't know yet what functionality I want to integrate (opening doors, hood, etc.) as my main focus will be the esthetics. At the same time I want to keep the chassis modular in that sense that it should be easy to swap bodywork. I do have some other projects to attend to first though so for now it will stay as it is. Thank you all for the nice comments. Quote
Exetrius Posted May 26, 2018 Posted May 26, 2018 Love the complicated look of the suspension, engine and framework at the rear! And the ECU under the dashboard is a true highlight of your dedication to the model. You madman! Quote
Brick_Sticker Posted June 9, 2018 Posted June 9, 2018 Any updates on this moc? I'd love to see the completed bodywork and how it all fits together! Quote
Sebeus I Posted June 16, 2018 Author Posted June 16, 2018 On 9 juni 2018 at 4:48 PM, Brick_Sticker said: Any updates on this moc? I'd love to see the completed bodywork and how it all fits together! At the moment I'm moving to a new place but it's the 1st project on my list to continue once I'm settled . Quote
Seasider Posted June 16, 2018 Posted June 16, 2018 Only just found this thread and I just love how you’re building this as a car would with detail to each and every sub assembly. It’ll almost be a shame to clad it in a body. Quote
Sebeus I Posted July 8, 2018 Author Posted July 8, 2018 It's not much but it's something; I intend to make the bodywork so that it would be easy to remove, that way the inner works can still be accessed. Quote
Aventador2004 Posted July 8, 2018 Posted July 8, 2018 This has style! Can't wait for the finished thing. Quote
Sebeus I Posted August 1, 2018 Author Posted August 1, 2018 (edited) The body work is challenging. I decided to leave functionality for what it is and focus on the overal shape of the vehicle. So no opening doors on this one. I was happy with this at first but half an hour later I looked at it and thought the lines were too straight, the design too static. I might still change it completely later. Not so sure about the headlights, maybe they look better if I add some vent below them. Edited August 1, 2018 by Sebeus I Quote
Aventador2004 Posted August 1, 2018 Posted August 1, 2018 It's okay right now, looks too futuristic for me ATM though. Quote
BusterHaus Posted August 2, 2018 Posted August 2, 2018 Nice progress on the body, although the nose looks to be too long. Maybe shorten it by a stud? Quote
Bartybum Posted August 2, 2018 Posted August 2, 2018 Nah the nose length is fine, it’s the hood. It needs to be curvier Quote
pagicence Posted August 2, 2018 Posted August 2, 2018 My suggestion is to use the driver's side A pillar (the black one). To me the straight shape of it looks better than the curved (red) one. Quote
