  • Replies 118
Now it's getting really tough.
You've got to squeeze your brains to receive 3 points.
MstrOfPppts, here's your chance to balance the scoreboard without stealing the points me writing down the wrong numbers. :wink:
(Probably scratching the bottom of the barrel but) the Bricklink part number is 30104, if you add the digits together you will get 8.
3 hours ago, Aredhel said:
The chain is 8cm long (just guessing not measuring)...
:thumbdown:
2 hours ago, Lasse D said:
It is not clear, but if the chain is old dark gray in that picture, then it is in LDraw color #8.
This answer is worth a point!
1 hour ago, Bob De Quatre said:
If you remove 15 links, there are exactly 8 links in the chain! :sweet:
Errr - yes. Still no point. :tongue:
1 hour ago, mechamike said:
You can (Lego legally) create the figure 8 with that part if you snap it together and arrange it nicely on the table
Very creative! 1 point. :thumbup:
It's always good to scratch the bottom of the barrel! :wink:
CONGRATULATIONS!!! 3 Points for you!
It's nice to see that this year's countdown is less of a steamroller affair, three different people have scored the three points so far. :thumbup:
And a bit of a stretch (or a yank perhaps, since it's a chain), but the first year that part was released it was included in 8 different sets in Dark Gray (seems I missed a set where it was included in Black, making my answer worse :wall:) with normal distribution (10 sets in total, but one's a duplicate of another, and one is a Dacta set so not something most of us would see in a store).
What does this piece have to do with 10?! - Before realising that this year it's not about 10s but days remaining :) Why did I have to check the previous countdowns ...
That's why I also included the numbered tiles to the picture.
Quote
Parts, which have a special relation to the days left.
:wink:
... and the 10's were 4 years ago! :laugh:
7 Studs on top are without a molding mark so that you can read a complete "LEGO"
Also 2x4x1 studs if you add these numbers together you get 7
Also 2,32 g weight if you add these numbers together you get 7
Also there are 7 categories for these typ of brick "3001" on Bricklink
Okay, okay it was too easy...
Quote
Right answer, 3 points! :thumbup:
The following answers are also right, making it 5 points altogether.
Quote
Do you mean " This Item is similar in mold type to the following Item(s): "? That would be six.
Total:
Skalldyr: 8 points
Quarry: 3 points
elleana: 3 points
LasseD: 2 point
mechamike: 1 point
Juhu! :sweet:
Actually I think it was kinda difficult to come up with the "studs" idea and I was totally thinking you mean something else... but I won't complain.
For the 3001 molds. There is the regular one plus the 6 other molds. So in total there are 7. :grin:
8 hours ago, MstrOfPppts said:
7 sets from 1984 contain this brick in red (as pictured above).
You diggin' deep, Andrac! :thumbup:
Finally your first point! (this time for real :grin: )
1 hour ago, Holodoc said:
Finnaly your first point!
I was already worried he would not get this going... :cry_happy:
6 cm high while standing as seen in your picture. From feet to ears. (Which is also close to 6 studs.)
Also seems to be 6 cm long while standing extended on his back feet. Measured from front feet to tail. (But I can not tell exactly...)
This is one of six LEGO moulded fully-grown System horses produced: 93083, 4493, 6171, 10352 (this one), Bullseye from Toy Story, and the Scala horse.
It also first turned up in a set six years ago - in 2012.
And - I'm not with my LEGO collection at the moment, so I can't check... but if there's an anti-stud under its left front hoof, it has a total of six stud connection points: One under each hoof, and two for the saddle.
Finally, I think the horse itself might, at the factory, be put together from six different moulds: Left and right side of the head, left and right side of the body, and left and right side of the legs.
13 hours ago, MstrOfPppts said:
I use my joker for tomorrow, if I get the 3 point answer, my points double! :D
Unles @Holodoc f@&#s up with some crazy timings ... BUT there's something else, I can feel it. Will come up with something after some more sleep ...
Edit: Here's all I could come up with:
On BL this piece is listed under one of six Animal categories.
Edited by MstrOfPppts
