This happens when you think you had a hard challenge today. :hmpf:
18 hours ago, Skalldyr said:
6 cm high while standing as seen in your picture. From feet to ears. (Which is also close to 6 studs.)
Also seems to be 6 cm long while standing extended on his back feet. Measured from front feet to tail. (But I can not tell exactly...)
First answer is right! *huh*:thumbup:
The second is wrong.
Still 3 points!
18 hours ago, L@go said:
This is one of six LEGO moulded fully-grown System horses produced: 93083, 4493, 6171, 10352 (this one), Bullseye from Toy Story, and the Scala horse.
It also first turned up in a set six years ago - in 2012.
And - I'm not with my LEGO collection at the moment, so I can't check... but if there's an anti-stud under its left front hoof, it has a total of six stud connection points: One under each hoof, and two for the saddle.
Finally, I think the horse itself might, at the factory, be put together from six different moulds: Left and right side of the head, left and right side of the body, and left and right side of the legs.
I love your answers and your first two are correct, but the horse is missing your front hoof - anti stud.
We'll ask somebody official in Billund about your six-mould theory. :wink:
So all in all 2 well deserved points!
10 hours ago, MstrOfPppts said:
Unles @Holodoc f@&#s up with some crazy timings ... BUT there's something else, I can feel it. Will come up with something after some more sleep ...
Edit: Here's all I could come up with:
On BL this piece is listed under one of six Animal categories.
What can I do for you besides laying the ball on the penalty spot? Maybe posting and then immediately going to bed is not the wisest of all things... :tongue::laugh:
Your answer is strechting the limit, this is 1 point.
10 hours ago, Redhead1982 said:
So I'm up and online before 8, and I'm already late to this guessing game.
Well, be prepared I say. :devil:
Skalldyr: 12
Quarry: 3
elleana: 3
L@go: 2
MstrOfPppts: 2
LasseD: 2
mechamike: 1
  • Replies 118
The number 40344 is a multiple of 5 (15).
The brick 40344 is (was) available in sets in 5 non-transparent colors (black, dark azzure, LBG, LG, yellow). The part weighs 5 g.
There's 5 of this brick in dark azzure in BOOST Creative Toolbox set.
Edited by Redhead1982
It's also one of the 5 technic bricks with open center (Technic, Brick 4 x 4 Open Center, Technic, Brick 4 x 6 Open Center, Technic, Brick 6 x 8 Open Center, Technic, Brick 4 x 6 Open Center with 2 Fixed Rotatable Friction Pins on End, Technic, Brick 6 x 8 Open Center with 2 Fixed Rotatable Friction Pins on 3 Sides).
The part appeared in yellow only in 2005.
Now you're in the game!
Everything is right and the red answer is worth 3 points!
I do count the first answer here, but not the last.
Making it 10 points altogether! Well done! Seems to be your time, right? :grin:
This day slingshots you on place 2! :oh:
Skalldyr: 12
Redhead: 10
Quarry: 3
elleana: 3
L@go: 2
MstrOfPppts: 2
LasseD: 2
mechamike: 1
Also there are 5 of this brick in light bluish grey in the Silent Mary set. :grin:
Skalldyr: 12
Redhead: 10
Quarry: 3
elleana: 3
L@go: 2
MstrOfPppts: 2
LasseD: 2
mechamike: 1
I used to be good at maths, but I might have lost my counting skills. I think I should get only 8 points for 6 answers (or are there some double points?).
To be honest atlogether it's just 7 points: 5 correct answers including the one with 3 points. :wall:
But your honesty makes it 8 again. :blush: Thank you very much for clarifying it! :thumbup:
On to "day 4":
This part is available in 4 sets in this reddish brown color.
Also this part in reddish brown appears in 4 themes (Elves, Ghostbusters, Dimensions and Modular buildings).
There are 4 in Set Ferry 60119 in white
There are 4 in Ocean HQ 70173 in white
There are 4 in Ninjago City 70620in dark bluish grey
There are 4 in 3817 Flying Dutchman in green
(Which means 4 sets with 4 inside.)
There are 4 notches inside of the pin hole of this part, which allows it to grip onto a pin without making it impossible for children to separate the parts again.
4 minifigs can stand in a circle, all holding the part as shown in the picture.
There are 4 standard connections: Stud (above), antistud (below), pin hole and clip (the last connection type is shown in the picture).
26 minutes ago, Bob De Quatre said:
There are 4 posts with answers regarding that particular part in the EB Event countdown topic.
Errr, no? :tongue:
But nice try! :grin:
3+1 point.
2 hours ago, Quarryman said:
And disregarding colour it appears in 4 sets in 2018 (so far).
I shouldn't have started giving pints for that. :sadnew:
Yet I did: 4 points.
Note to all: From today on no more points for these answers! :tongue:
*huh*
Okay: I have to figure out if the first two answers are correct. :wacko: This will take until tomorrow. :blush:
The last one is perfect: 1 point.
Skalldyr: 16
Redhead: 12
Quarry: 4
LasseD: 3 (4/5 yet to be confirmed)
elleana: 3
L@go: 2
MstrOfPppts: 2
mechamike: 1
Thanks. You can actually see the notches in your pic. The circle of minifig is easy to do, while I personally can't make 5 stand in the same circle and all hold the part.
This part clearly forms a figure of eight in your picture - which is dividable by 4! :grin:
It also has the four letters L E G O clearly visible in the picture...
...aaaaand the thickness of the ring itself, measured across the top, is roughly 4 millimetres.
This part was introduced in 1999 when it came in 4 sets.
What trickery is this now? Me and Skalldyr are loosing points for no reason - or is it bad sportsmanship?
Haha true I did not even realize :laugh:
Since there are two holes in that part, a minifig could go number 2 in both, which of course adds up to AND multiplies to 4. Bazinga!
(Oh ok, I promise I will stop... mostly).
