Ngoc Nguyen Posted May 25, 2018 Posted May 25, 2018 I've just thought that maybe this time the hazard light won't control the steering, but instead the tilting. And the exhaust pipe is the actual HOG steering knob. Quote
Maaboo the Witch Posted May 25, 2018 Posted May 25, 2018 33 minutes ago, Ngoc Nguyen said: I've just thought that maybe this time the hazard light won't control the steering, but instead the tilting. And the exhaust pipe is the actual HOG steering knob. Interesting! Quote
Kaanere Posted May 25, 2018 Posted May 25, 2018 3 hours ago, Ngoc Nguyen said: I've just thought that maybe this time the hazard light won't control the steering, but instead the tilting. And the exhaust pipe is the actual HOG steering knob. Good catch! However, I think that the beacon controls the raising (there's indeed a shaft under it) and the small lever on the side the tilting (what else could it be for?). Quote
Ngoc Nguyen Posted May 29, 2018 Posted May 29, 2018 On 5/26/2018 at 3:01 AM, Kaanere said: Good catch! However, I think that the beacon controls the raising (there's indeed a shaft under it) and the small lever on the side the tilting (what else could it be for?). My bad. I meant the hazard light is for lifting the fork, and the exhaust pipe is for steering. Tilting is most likely done with the side lever of course. Quote
Ivan_M Posted May 29, 2018 Posted May 29, 2018 Don't know if it was mentioned already, but it seems like diffrential on front axle Quote
Aventador2004 Posted May 29, 2018 Posted May 29, 2018 4 hours ago, Ivan_M said: Don't know if it was mentioned already, but it seems like diffrential on front axle I don't think it was mentioned, but implied by putting a engine. Quote
1gor Posted May 29, 2018 Posted May 29, 2018 36 minutes ago, Aventador2004 said: I don't think it was mentioned, but implied by putting a engine. correct, you can see what it looks like 2 cylinder engine at the back behind cab on first leak images of 2018 summer catalog months ago Quote
Ngoc Nguyen Posted May 29, 2018 Posted May 29, 2018 I find it weird that the front arch is close to the front wheel, but the rear ach isn't to the rear wheel. Quote
agrof Posted May 29, 2018 Posted May 29, 2018 It is because the rear wheels need some extra space for steering. Quote
Bartybum Posted June 18, 2018 Posted June 18, 2018 So like no travel on the forklift. What a damn shame Quote
Aventador2004 Posted June 18, 2018 Posted June 18, 2018 26 minutes ago, Bartybum said: So like no travel on the forklift. What a damn shame Yeah, you're right, I thought it went up more. Quote
Bartybum Posted June 18, 2018 Posted June 18, 2018 (edited) 1 hour ago, Aventador2004 said: Yeah, you're right, I thought it went up more. It’s good that it doesn’t appear to use any special pieces I don’t have yet, so I could MOC this with a proper forklift arm. I suspect it was done like so for the B model to have an arm. Edited June 18, 2018 by Bartybum Quote
Maaboo the Witch Posted June 18, 2018 Posted June 18, 2018 57 minutes ago, Fabiuz said: travel is 15-16 studs, am I right? That's not bad. Quote
GoldVillage Posted June 18, 2018 Posted June 18, 2018 16 hours ago, Aventador2004 said: Yeah, you're right, I thought it went up more. Maybe its possible to make it go up about 3 studs more by removing the little 2l red axle that locks the rack Quote
Aventador2004 Posted June 18, 2018 Posted June 18, 2018 41 minutes ago, GoldVillage said: Maybe its possible to make it go up about 3 studs more by removing the little 2l red axle that locks the rack Thats what i was thinking, it just keeps the rack steady. Quote
Lipko Posted June 18, 2018 Posted June 18, 2018 1 hour ago, Fabiuz said: travel is 15-16 studs, am I right? read back. it's been puzzled out earlier. Quote
Bartybum Posted June 18, 2018 Posted June 18, 2018 5 hours ago, Maaboo35 said: That's not bad. It’s pretty bad... it only travels like halfway up Quote
arijitdas Posted June 19, 2018 Posted June 19, 2018 (edited) I am really looking forward to build this set using my existing lego part provided it does not use any special parts. I am sure it will be interesting to build both the A and B model of this set. I have a feeling that the B model might turn out to be more fun that building the A model. Edited June 19, 2018 by arijitdas Quote
Bartybum Posted June 19, 2018 Posted June 19, 2018 Might be worth a try to hook up the winch to a cable drum powered by the worm gear that that winds up as the fork rises. Quote
N-4K0 Posted June 19, 2018 Posted June 19, 2018 The B-model looks surprisingly good for what it is, I think. My original plan was to buy 42080 and MOC the forklift since I have more parts than I really need already, but I keep getting more tempted to just buy the forklift as well, as usual Quote
Ngoc Nguyen Posted June 19, 2018 Posted June 19, 2018 (edited) Edited June 19, 2018 by Ngoc Nguyen Quote
