jorgeopesi Posted April 2, 2018 Posted April 2, 2018 It looks very good, I have not done enough to be mentioned everything is your great job . Quote
1gor Posted April 2, 2018 Author Posted April 2, 2018 (edited) 1 hour ago, jorgeopesi said: It looks very good, I have not done enough to be mentioned everything is your great job . Thanks, you give me importing arguments to stay on 1:17.5 - 1:18 scale and that's something (Even the smallest things can start greatest changes) On 2. svibnja 2017. at 1:07 PM, IA creations said: This topic doesn't have the attention it needs ! Great build ! The front axle looks great ! Maybe tweak the front for a smother design :) On today's update you can see smoother front bull-bar design. CAb images will be uploaded asap (and cab is much smoother now) Due to lack of parts I had to wait for months to start developing smoother design for front part Edited April 2, 2018 by I_Igor Quote
Paul B Technic Posted April 2, 2018 Posted April 2, 2018 It has been really great to see your progress with this. Quote
1gor Posted April 3, 2018 Author Posted April 3, 2018 6 hours ago, Paul B said: It has been really great to see your progress with this. Thanks Paul, I hope to upload cab images today, but I'll see how much time there will be Quote
1gor Posted April 6, 2018 Author Posted April 6, 2018 Update time; as I already mentioned here is 90% finished tilting cab with open-able doors and bonnet, but need few stickers and need to finished right beacon light. I had to make changes to chassis as well so instead of frame 11 x 5 there are double bent liftarms and additional beams to make front chassis part more stiffer specially in area of lower suspension arms connection where it was not sturdy enough. Now let images speak for itself... Quote
BrickbyBrickTechnic Posted April 6, 2018 Posted April 6, 2018 Can we have a head-on view of the cab? I think something is off, though I'm not sure what. Keep up the good work Quote
1gor Posted April 6, 2018 Author Posted April 6, 2018 I'll try to take additional photo(s) later today or at folowing weekend. BTW angled of cab and ozher key positions fit perfectly printed "blueprint" that I have posted page earlier. Thanks for any kind of comment Quote
1gor Posted April 6, 2018 Author Posted April 6, 2018 1 hour ago, BrickbyBrickTechnic said: Can we have a head-on view of the cab? I think something is off, though I'm not sure what. Keep up the good work hope that this helps Quote
1gor Posted April 7, 2018 Author Posted April 7, 2018 (edited) @BrickbyBrickTechnic what is a bit out of place is front part of the roof (place where licence plate goes) which is 2 studs thick instead of just one stud, but then (because of raised front part) interrier part would look stupid...or to make some kind of Sun shield like this Edited April 7, 2018 by I_Igor Quote
BrickbyBrickTechnic Posted April 7, 2018 Posted April 7, 2018 3 hours ago, I_Igor said: or to make some kind of Sun shield like this I believe a sun shield is needed. The DBG panel inside doesn't look right. You should remove that and make the roof 1 stud thick with a sun shield IMO. Quote
1gor Posted April 7, 2018 Author Posted April 7, 2018 44 minutes ago, BrickbyBrickTechnic said: I believe a sun shield is needed. The DBG panel inside doesn't look right. You should remove that and make the roof 1 stud thick with a sun shield IMO. That two things crossed my mind. "Orange" structure fits "blueprint" very well, but as you noticed this two points are problem area. Thanks Quote
1gor Posted April 7, 2018 Author Posted April 7, 2018 9 hours ago, BrickbyBrickTechnic said: I believe a sun shield is needed. The DBG panel inside doesn't look right. You should remove that and make the roof 1 stud thick with a sun shield IMO. For dbg panel I have an idea for replacement with two smaller panels that would be at both ends but have to order them in dbg color. I'm writting about this parts https://www.bricklink.com/v2/catalog/catalogitem.page?P=11946&idColor=85#T=C&C=85 https://www.bricklink.com/v2/catalog/catalogitem.page?P=11947&idColor=85#T=C&C=85 There is also an issue with cab stifness when I replace 11 x 3 dbg panel... Sun shield could be made with above mentioned panels in black and in the middle to put licence plate holder... Quote
1gor Posted April 8, 2018 Author Posted April 8, 2018 (edited) On 4/7/2018 at 12:29 PM, BrickbyBrickTechnic said: I believe a sun shield is needed. The DBG panel inside doesn't look right. You should remove that and make the roof 1 stud thick with a sun shield IMO. This is preliminary version of sunshield but I think I'll have to change curved panel 11 x 3 in ordinary 11 x 3 and make it higher for about half a stud at the front Edited April 9, 2018 by I_Igor Quote
BrickbyBrickTechnic Posted April 8, 2018 Posted April 8, 2018 Looks good! 44 minutes ago, I_Igor said: but I think I'll have to change curved panel 11 x 3 in ordinary 11 x 3 and make it higher for about half a stud at the front I agree. You should do that. Quote
1gor Posted April 8, 2018 Author Posted April 8, 2018 (edited) 17 hours ago, BrickbyBrickTechnic said: Looks good! I agree. You should do that. Hope to find some time to do it (this week) Edited April 9, 2018 by I_Igor Quote
1gor Posted April 10, 2018 Author Posted April 10, 2018 On 4/8/2018 at 7:27 PM, BrickbyBrickTechnic said: Looks good! I agree. You should do that. here are two versions; one with sun shield and one without. I have managed to make a bit angled front part of the roof, and two blur pins indicate where licence plate will be (actually one white tile 1 x 4) question is: which one do you prefer? Quote
BrickbyBrickTechnic Posted April 10, 2018 Posted April 10, 2018 I believe the first version looks better. Quote
1gor Posted April 10, 2018 Author Posted April 10, 2018 2 minutes ago, BrickbyBrickTechnic said: I believe the first version looks better. Deal Now I have to wait for parts for cockpit in dark bluish gray BTW when I see your 42054 C models, then I wish you had 5 more of them Quote
BrickbyBrickTechnic Posted April 10, 2018 Posted April 10, 2018 53 minutes ago, I_Igor said: I wish you had 5 more of them Haha, thanks I may start making them again soon. Quote
1gor Posted April 10, 2018 Author Posted April 10, 2018 4 minutes ago, BrickbyBrickTechnic said: Haha, thanks I may start making them again soon. I have 3 of them but mainly for parts and future projects. Sorry for off-topic Quote
1gor Posted April 10, 2018 Author Posted April 10, 2018 8 hours ago, BrickbyBrickTechnic said: Haha, thanks I may start making them again soon. ...and I have to finish this Unimog because today this topic celebrates it's first birthday Quote
1gor Posted April 29, 2018 Author Posted April 29, 2018 On 10. travnja 2018. at 12:08 PM, BrickbyBrickTechnic said: I believe the first version looks better. Parts have arrived and result is here... I think cab looks better now but had to make cab 1 stud longer to fit the scale if any of image can be properly seen, there is always this "gallery" https://bricksafe.com/pages/igor.ipsa/trucks/mercedes-benz/unimog-u423-short-wheelbase Quote
Leonardo da Bricki Posted April 29, 2018 Posted April 29, 2018 Looks pretty darn good, Igor! And it's just my personal preference, but I would make those red pins on the front black. Quote
1gor Posted April 30, 2018 Author Posted April 30, 2018 8 hours ago, Leonardo da Bricki said: Looks pretty darn good, Igor! And it's just my personal preference, but I would make those red pins on the front black. I think about same thing, both ftont and rear. Thanks. Now I have to see how attachment will behave after I order arches for rear mudguards Quote
