Jantayg Posted June 12, 2018 Posted June 12, 2018 (edited) Hi Didumos, I like your idea about reducing friction. I build mainly rc mocs, and I have the same goal there too. I tried to use the new parts to build something simple, and efficient, but I found an issue with positioning the orange selector parts. The half stud distance from the line of the axles does not work, as it is too small, and there is a lot of friction between the orange part and the grey driving ring. I made a bad quality picture at the time I was testing, and you can see, that the frame I made has not the pins fully in, so the gearbox can work. So what I am trying to say, that in your setup you would have the same problem. I made a working setup just to see and feel the friction, but the orange part needs to be mounted just a bit more than half stud from the line of the axles. As you see this is out of system, so very hard to achieve, when proper bracing, and the rotation of the selector axle has to be done. I hope this helps, and I wonder with what kind of idea you will come up with to solve this:) Edited June 12, 2018 by Jantayg Quote
allanp Posted June 12, 2018 Posted June 12, 2018 Didumos has his drive rings placed further apart. Yours are too close together. Quote
Didumos69 Posted June 12, 2018 Posted June 12, 2018 (edited) 19 hours ago, Jantayg said: ... 18 hours ago, allanp said: Didumos has his drive rings placed further apart. Yours are too close together. What he said. They are placed one stud more apart. Actually the wave selector has a 2.12L distance from the driving rings (center-to-center), where it ideally should have a 2L distance. It would be great if you could test if this works, because I don't have the wave selectors yet. I want them desperately, but I'm going to wait until I can order them via bricklink. Edited June 13, 2018 by Didumos69 Quote
BusterHaus Posted June 12, 2018 Author Posted June 12, 2018 @Didumos69 My parts are in the mail, I'll be able to test designs soon. I'm also following the LDraw parts tracker, but the wave selector is not there yet. Quote
Paul Boratko Posted June 12, 2018 Posted June 12, 2018 (edited) 2 hours ago, Didumos69 said: What he said. They are placed one stud more apart. Actually the wave selector has a 2.12L distance from the driving rings (center-to-center), where it ideally should have a 2L distance. It would be great if you could test if this works, because I don't have the wave selectors yet. I want them desperately, but I'm going to wait until I can order them via bricklink. I played around with a 1/2 stud offset like that a few days ago.. It does work.. Maybe not quite as perfectly as having the wave selector in the standard 2 stud position, but I think it is acceptable.. Only difference now is that the selector has to be at a 45 degree angle to engage the driving rings and of course having to deal with controlling that wave selector with the 1/2 stud difference somewhere down the road.. Edited June 12, 2018 by Paul Boratko Quote
Didumos69 Posted June 12, 2018 Posted June 12, 2018 (edited) 34 minutes ago, Paul Boratko said: Only difference now is that the selector has to be at a 45 degree angle to engage the driving rings and of course having to deal with controlling that wave selector with the 1/2 stud difference somewhere down the road.. Thanks for the info @Paul Boratko! To deal with the half stud difference and the 45 degree angle I was thinking of meshing the selector axle with a control axle using two 12t gears. I will then apply a 90 degree limiter to that control axle. Edited June 12, 2018 by Didumos69 Quote
Jantayg Posted June 12, 2018 Posted June 12, 2018 I have not seen it properly in your design, yes your axles are 4 studs from eachother, in my case 3, so yours should work. My parts are from bricklink too, I can test it later too. Quote
1963maniac Posted June 12, 2018 Posted June 12, 2018 9 hours ago, Didumos69 said: LXF-file here. Thanks, Didumos69 for all your posts and work on this forum. I'm trying to understand these Lego gearboxes. If anyone is interested I made a BI for Didumos69 LXF file above. I also made my own 20t gears w/ clutch. Using a Dremel tool I removed the center of a 20t gear and the teeth off of a 16t clutch until they fit together. Surprisingly, they turned out great. Quote
Didumos69 Posted June 12, 2018 Posted June 12, 2018 3 hours ago, 1963maniac said: Thanks, Didumos69 for all your posts and work on this forum. I'm trying to understand these Lego gearboxes. If anyone is interested I made a BI for Didumos69 LXF file above. I also made my own 20t gears w/ clutch. Using a Dremel tool I removed the center of a 20t gear and the teeth off of a 16t clutch until they fit together. Surprisingly, they turned out great. You're welcome! So you couldn't wait for the new parts either, haha. Feel free to share the BI, you're making me curious. People should only know that it's not a finished gearbox, it lacks a shifter and a 90 degree limiter. Quote
Philo Posted June 13, 2018 Posted June 13, 2018 23 hours ago, BusterHaus said: My parts are in the mail, I'll be able to test designs soon. I'm also following the LDraw parts tracker, but the wave selector is not there yet. I am eagerly waiting for good photos in cartesian directions (top/bottom/left/front) and dimensions (diameters, height) to make the LDraw model! Quote
BusterHaus Posted June 13, 2018 Author Posted June 13, 2018 @Philo I can make a drawing when I receive the parts. Can you open DXF or DWG files, or is a drawing annotated with dimensions better? Quote
Philo Posted June 13, 2018 Posted June 13, 2018 @BusterHaus No problem with DXF. DWG should be OK too, but I've not tried often. Thanks in advance! Quote
Paul Boratko Posted June 13, 2018 Posted June 13, 2018 (edited) Here is another AWD Gearbox... Edited June 13, 2018 by Paul Boratko Quote
Didumos69 Posted June 13, 2018 Posted June 13, 2018 (edited) @Paul Baulch, I think this is exactly what I posted about two weeks ago. Nice to see it being buit! It uses all new parts! Only the use of 16t gears for the rotary catches is not perfect. But it could use knob wheels if the control axle could have a 45 degree angle.@ I especially like the fact that when one idler gear is engaged, all the other plain idler gears making dummy rotations. They are not involved in transferring drive. On 5/31/2018 at 2:02 PM, Didumos69 said: Or move the input axles up a layer: Btw, this layout is quite similar to what I did in my rugged supercar: Edited June 13, 2018 by Didumos69 Quote
Paul Boratko Posted June 13, 2018 Posted June 13, 2018 (edited) 32 minutes ago, Didumos69 said: @Paul Baulch, I think this is exactly what I posted about two weeks ago. Nice to see it being buit! It uses all new parts! Only the use of 16t gears for the rotary catches is not perfect. But it could use knob wheels if the control axle could have a 45 degree angle.@ I especially like the fact that when one idler gear is engaged, all the other plain idler gears making dummy rotations. They are not involved in transferring drive. Yeah, that looks like the same gear set up, this one just has the gears in different places and has the motor input going the entire way through to the other side... It's not quite as practical as the previous one that I did, but it feels more solid(Then again it has a lot more parts). I was originally using yellow knob wheels, but 3 of them in a line didn't seem to work smoothly 100% of the time... I was also using this idea which worked out ok, but then I switched to the 16 tooth gears... Once thing that I have discovered is that even if the 16 tooth gear is slightly off center, the rotary wave selector is completely engaged and cannot go in any further even if they were centered... Edited June 13, 2018 by Paul Boratko Quote
LvdH Posted June 13, 2018 Posted June 13, 2018 If anyone needs the new gearbox parts, you can already order them from LEGO Bricks and Pieces. Part numbers; 35185 for the blue clutch 35186 for the yellow driving ring extension 35188 for the gear selector Quote
suffocation Posted June 13, 2018 Posted June 13, 2018 The price of the driving ring extention is extorsionate. Quote
TheHypaaa Posted June 13, 2018 Posted June 13, 2018 Is there any advantage to the new yellow driving ring extension other than the reduced slack? Quote
Meatman Posted June 13, 2018 Posted June 13, 2018 (edited) 3 hours ago, Paul Boratko said: Yeah, that looks like the same gear set up, this one just has the gears in different places and has the motor input going the entire way through to the other side... It's not quite as practical as the previous one that I did, but it feels more solid(Then again it has a lot more parts). I was originally using yellow knob wheels, but 3 of them in a line didn't seem to work smoothly 100% of the time... I was also using this idea which worked out ok, but then I switched to the 16 tooth gears... Once thing that I have discovered is that even if the 16 tooth gear is slightly off center, the rotary wave selector is completely engaged and cannot go in any further even if they were centered... That is actually a pretty simple, yet clever idea. I have noticed too in my Bugatti model that there is a few degrees of swing both ways with the orange shifting parts where they are still engaged. 2 hours ago, suffocation said: The price of the driving ring extention is extorsionate. Yeah, that price is insane. Edited June 13, 2018 by Meatman Quote
deehtha Posted June 14, 2018 Posted June 14, 2018 Here is a version of @Paul Boratko's 4 speed that I added an automatic lock to the central diff. The differential should lock in 1st gear. Blue is shifter input, yellow is drive input, and red is drive output. The orange wheels are the new orange selector. The yellow 12 tooth gears are the new extension ring. For some reason LDD would not let me mate the old style extension with the differential. It would also only let me use the white gear shifter connectors with ridges on the shifter, I could not use the red ones without ridges. The shifter input can come from either side. 1 Quote
Ivan_M Posted June 14, 2018 Posted June 14, 2018 (edited) 9 hours ago, TheHypaaa said: Is there any advantage to the new yellow driving ring extension other than the reduced slack? old extension cannot mesh with double sided clutch gears (red 16 tooth and new blue 20 tooth), only with older single sided 16 tooth Edited June 14, 2018 by Ivan_M Quote
TheHypaaa Posted June 14, 2018 Posted June 14, 2018 10 hours ago, Ivan_M said: old extension cannot mesh with double sided clutch gears (red 16 tooth and new blue 20 tooth), only with older single sided 16 tooth Oh, thank you. Quote
1963maniac Posted June 14, 2018 Posted June 14, 2018 (edited) On 6/12/2018 at 1:10 PM, 1963maniac said: Thanks, Didumos69 for all your posts and work on this forum. I'm trying to understand these Lego gearboxes. If anyone is interested I made a BI for Didumos69 LXF file above. I also made my own 20t gears w/ clutch. Using a Dremel tool I removed the center of a 20t gear and the teeth off of a 16t clutch until they fit together. Surprisingly, they turned out great. You're welcome! So you couldn't wait for the new parts either, haha. Feel free to share the BI, you're making me curious. People should only know that it's not a finished gearbox, it lacks a shifter and a 90 degree limiter. On 6/12/2018 at 3:08 AM, Didumos69 said: LXF-file here. (from 1 page earlier) the file is called "4-speed - Centered_Didumos69_LPUB.pdf" at https://bricksafe.com/pages/1963maniac This is not my best work, I just made the BI quickly so I could build it. It is now updated.(6/15/2018) Now, I've ordered the parts from Lego bricks and pieces. I didn't know one could do that. So, I too am anticipating the new parts coming in the mail. YEA! BTW, Paul Boratko, I am offering to make building instructions from your above mentioned designs too. Edited June 15, 2018 by 1963maniac update Quote
Paul Boratko Posted June 15, 2018 Posted June 15, 2018 9 hours ago, 1963maniac said: BTW, Paul Boratko, I am offering to make building instructions from your above mentioned designs too. Go right ahead.. I sure don't know how to do them.. Lots of people have been asking for them on facebook, so they'll be quite happy... Quote
1963maniac Posted June 15, 2018 Posted June 15, 2018 7 hours ago, Paul Boratko said: Go right ahead.. I sure don't know how to do them.. Lots of people have been asking for them on facebook, so they'll be quite happy... Do you have more pictures showing internal sections? Quote
