1963maniac Posted July 24, 2018 Posted July 24, 2018 (edited) Here are two files for Crowkillers Gearboxes. https://bricksafe.com/files/1963maniac/Crowkillers 2018 Lego Technic 4 Speed AWD Gearbox.pdf https://bricksafe.com/files/1963maniac/Crowkillers HD AWD 4 speed Sequential gearbox LPUB.pdf Edited June 19, 2020 by 1963maniac updated again-new instructions Quote
Hrafn Posted July 25, 2018 Posted July 25, 2018 I am still working on my 7+r but here is an improved version. This is the top view. Red is control, input is green, output is white (barely visible below the red). Here is the bottom view. The shaft with two 20z gears next to each other is for reverse. The two outermost shafts (not counting the reversing one just mentioned) go all the way through the gearbox; the other shafts do not. Returning to the top view: The orange rotary drum on the left controls the R-2-4-6 gearbox, the one on the right controls 1-3-5+7. The gearbox is in reverse here (-12/20). Turning the control 180 degrees clockwise rotates the right rotary drum 90 degrees counter clockwise, and selects the 1-3-5-7 gearbox, so the whole thing is now in 1st gear. Turning the control another 180 degrees clockwise turns the left rotary drum 90 degrees counter clockwise and puts the gearbox in 2. R-2-4-6 has speeds of 12/20, 1, 36/20, 3. 1-3-5-7 has the same speeds except multiplied by 20/14. 20/16 would have given a smoother gear ratio curve but this is more compact, and the relative ratios end up reasonably near what, say, the real Veyron uses. The gearbox still needs limiters and something to prevent shifts from 7 to R, and the structure is still evolving, but hopefully you get the idea. Quote
1963maniac Posted July 25, 2018 Posted July 25, 2018 That's getting better. Keep going. I like that you're using the older style driving rings, takes up less real estate. Quote
bekesizoltan Posted July 25, 2018 Posted July 25, 2018 9 hours ago, Hrafn said: I am still working on my 7+r but here is an improved version. The gearbox still needs limiters and something to prevent shifts from 7 to R, and the structure is still evolving, but hopefully you get the idea. Hi,am I right if I would say that the 7+R is easily changeable to 6+N+R? Quote
Hrafn Posted July 25, 2018 Posted July 25, 2018 11 minutes ago, bekesizoltan said: Hi,am I right if I would say that the 7+R is easily changeable to 6+N+R? Sure, but N is easily achieved by just turning the control shaft 90 degrees instead of 180. Controlling that would be tricky though. 23 minutes ago, 1963maniac said: That's getting better. Keep going. I like that you're using the older style driving rings, takes up less real estate. Thanks! Yes, the old driving rings do save some space. I need to get more old 16z clutch gears, though - the red ones do seem to generate some increased friction. Quote
BusterHaus Posted July 25, 2018 Author Posted July 25, 2018 @Hrafn Nice work! Are you planning to build in some locks to keep in place l the selectors driven by knob gears? Quote
Hrafn Posted July 25, 2018 Posted July 25, 2018 23 minutes ago, BusterHaus said: @Hrafn Nice work! Are you planning to build in some locks to keep in place l the selectors driven by knob gears? Thanks! Yes, that is what I meant by limiters - something to lock the sub gearbox control axles at 90 degree increments and the main control axle at 180 degrees. It occurs to me I could hard couple the sub gearbox control axles with a 45 degree offset (and switch gears by rotating both 45 degrees at a time) but then I would need a precise clutch mechanism to deal with the resulting double engagement during gear shifts. Quote
1963maniac Posted July 25, 2018 Posted July 25, 2018 Check out how Didumos69 did his limiter on his transmission tunnel (back a page). Quote
Talles Posted July 31, 2018 Posted July 31, 2018 Hi! Anyone has a file with the new orange selector for 3d print? I purchased some parts, but here in Brazil the things no functions like should and I'm anxious to wait. Quote
1963maniac Posted July 31, 2018 Posted July 31, 2018 50 minutes ago, Talles said: Hi! Anyone has a file with the new orange selector for 3d print? I purchased some parts, but here in Brazil the things no functions like should and I'm anxious to wait. How you will use it will help with how to answer your question. These parts are available for LDRAW library. A few pages back Philo talks about them. Part # 35188. Quote
Talles Posted July 31, 2018 Posted July 31, 2018 43 minutes ago, 1963maniac said: How you will use it will help with how to answer your question. These parts are available for LDRAW library. A few pages back Philo talks about them. Part # 35188. Thanks Quote
Talles Posted August 1, 2018 Posted August 1, 2018 On 6/13/2018 at 1:50 PM, Philo said: @BusterHaus No problem with DXF. DWG should be OK too, but I've not tried often. Thanks in advance! @Philo Can you share the DXF or DWG with me? I would like to print in 3D. Thanks. Quote
Philo Posted August 2, 2018 Posted August 2, 2018 @Talles I started the LDraw model from photos sent by @BusterHaus then completed it when I received the part form s@h, so I have no DXF/DWG. But you can try to export the LDraw model to .stl (using LDView). No guaranty that the exported model will be perfectly exact (should come close) and it will certainly not be "watertight", which is a requirement for 3D printing (but your printer software may be smart enough to figure the proper shape anyway). Quote
Talles Posted August 2, 2018 Posted August 2, 2018 (edited) 19 hours ago, Philo said: @Talles I started the LDraw model from photos sent by @BusterHaus then completed it when I received the part form s@h, so I have no DXF/DWG. But you can try to export the LDraw model to .stl (using LDView). No guaranty that the exported model will be perfectly exact (should come close) and it will certainly not be "watertight", which is a requirement for 3D printing (but your printer software may be smart enough to figure the proper shape anyway). It worked out. Thanks. Edited August 3, 2018 by Talles Quote
Hrafn Posted August 5, 2018 Posted August 5, 2018 (edited) I am still working on the 7+R, albeit very infrequently. How large is too large for use in a supercar? Right now the gearbox is about 15 studs long, 15 wide (11 without structure), and 3 tall, but it is missing the 90 and 180 degree limiters, and a motorized or manual shifter, so it will get bigger. FYI, gear ratios range from 5 (for reverse) to .7 (for 7) in a fairly smooth curve. Edited August 5, 2018 by Hrafn Quote
T Lego Posted August 15, 2018 Posted August 15, 2018 (edited) Hi, I want to share my 7+R gearbox here. The main idea was to design an advanced gearbox for 1:10 scale supercars, so it had to be compact. The gearbox consists of two of @Didumos69's 4 speed gearboxes. I modified the first one to substitute first gear with a reverse and I geared up the second 4 speed gearbox by 1.2. I geared up Reverse gear by 1.2 as well, so that first gear and reverse have the same ratio. R) 0.72 1) 0.72 2) 0.75 3) 0.9 4) 1 5) 1.2 6) 1.25 7) 1.5 So this gearbox is basically a dual clutch gearbox, since it has a gearbox for odd and even speeds. Actually the gearbox has no clutches (yet). The shifting meganism has a 90 degree limiter hidden inside and it is connected to two rotary catches by a 12- and 24 teeth gear. Every time you shift, the rotary catches rotates 45 degrees. I was hoping that when the rotary catch is at a 45 degree angle, no gears are engaged, so that when the other rotary catch is in a normal 90 degree position I can connect output 1 and 2 without dual clutch. In reality though, this is not a reliable solution. When the rotary catch is at a 45 degree angle, the driving rings can move 2 mm toward the driving ring and engage a gear. When I tested the gearbox with a motor, I found that sometimes only one output rotates and sometimes two. Conclusion: I still need a dual clutch meganism. (I will try to integrate it into above the rear axle) Let me know what you think. Sugestions for improvements are apreciated! Edited August 15, 2018 by T Lego Quote
1963maniac Posted August 15, 2018 Posted August 15, 2018 I would like to build this. Do you have a digital file or building instructions? Quote
T Lego Posted August 15, 2018 Posted August 15, 2018 8 minutes ago, 1963maniac said: I would like to build this. Do you have a digital file or building instructions? I don't, but I can PM you some more detailed pictures so you can reverse engineer it if you want. Quote
1963maniac Posted August 15, 2018 Posted August 15, 2018 3 minutes ago, T Lego said: I don't, but I can PM you some more detailed pictures so you can reverse engineer it if you want. Would you be willing to post them somewhere free like "bricksafe" and post a link here? Quote
T Lego Posted August 15, 2018 Posted August 15, 2018 27 minutes ago, 1963maniac said: Would you be willing to post them somewhere free like "bricksafe" and post a link here? https://bricksafe.com/pages/T_Antonie/ Done Let me know if you have any questions. Quote
1963maniac Posted August 15, 2018 Posted August 15, 2018 Thank you! And, I'm sure I will have questions sometime. Quote
Isamudyson Posted August 16, 2018 Posted August 16, 2018 23 hours ago, T Lego said: https://bricksafe.com/pages/T_Antonie/ Done Let me know if you have any questions. Do you have a close up view of where the band is for the gear selector? curious how it is done as i'm building it LDD Quote
T Lego Posted August 17, 2018 Posted August 17, 2018 20 hours ago, Isamudyson said: Do you have a close up view of where the band is for the gear selector? curious how it is done as i'm building it LDD Thank you for building it in LDD! I can’t take a picture yet beceause I am on vacation. I will be home within a week, so then I can send you a close up. Are you able to finish the gearbox itself (without limiter) without that info? Quote
Isamudyson Posted August 17, 2018 Posted August 17, 2018 2 hours ago, T Lego said: Thank you for building it in LDD! I can’t take a picture yet beceause I am on vacation. I will be home within a week, so then I can send you a close up. Are you able to finish the gearbox itself (without limiter) without that info? I believe i have and can share what i have. I'm sure i made mistakes somewhere. https://bricksafe.com/pages/isamudyson/random Quote
T Lego Posted August 24, 2018 Posted August 24, 2018 (edited) On 8/16/2018 at 8:21 PM, Isamudyson said: Do you have a close up view of where the band is for the gear selector? curious how it is done as i'm building it LDD Here you go. I have taken a look at the LDD file and as far as I am concerned, you did not make any mistakes Note: I am almost done with the dual clutch system and rear axle integration Edited August 24, 2018 by T Lego Quote
