So in between doing other things I finally got around to building the pimped up version plus adding a few of my own mods.
Experimented by changing the hood to the 17/18 panels and moving the hinges closer to the middle. This allowed the outside 5/6 panels to be changed to the larger 17/18 ones as well. Filled the remaining gaps the best I could. It's the best thing I could come up with given the colour limitations and the parts I had on hand... but I feel like it closes everything in a lot better.
Also reworked the door hinges to add multiple connection points, whilst also getting rid of that stupid LBG bush.
I think I've had enough of this model for now and its at the point where I'm happy with it :classic:
  • Replies 589
Posted Images
  • 4 months later...
Hi Guys,
I just finished building this awesome car with my 10-year old son. Off course he would like to play with it so we soon realized we missed the hand of god steering. After googling around on the internet for solutions i found this thread with some amazing mods, great! However....i found the link to all the bricks needed to realize all the mods, but i can't seem to find a link to the needed parts for specific mods. Did i miss something, or is this just not there?
I would like to mod the car with the following mods:
- hand of god steering in the dash
- hand of god changing gears from the dash
- hand of god easy moving the spoiler
- the mod for changing the door hings and closing of the doors.
The other mods look great, but when buying all the parts...it gets a bit very expensive.
I'm just looking for the extra parts of the mods above, but i can't find which parts i need to realize them. Is there anyone who could help me with that?
Thank you very much in advance,
Greetings from the Netherlands
15 minutes ago, Celeri said:
Meukie, I think you should check out this MOD : https://rebrickable.com/mocs/MOC-16181/jb70/42083-pimp-up-my-bugatti/#details : it is the one which we refer as "pimped up version" of the Chiron.
It includes all that you mention and more, and only needs a moderate number of parts (276 precisely).
Hi, thanks a lot for your reply. That’s the big mod i found indeed…looks awesome, but perhaps i just don’t get it right, These parts cost more than €500,00, don’t they?
Or should I use the compare module which says the 276 parts? Any idea what the costs of these 276 parts to make all the mods from the updated booklet (great work btw!) are in total?
Hey @Meukie,
You have to click on compare and there you can export the parts from the left -> for me it was showing around 55 euro right now, but you can always play with the stores (some may have a bigger min. buy, so by adding a few parts you can order all parts from one store).
Exactlly, if you have the original set, then you only need the 276 "unique" parts of the MOD.
I have made a quick try on BrickLink: you should be able to get them for 25-30€ + shipping fees.
Ah great! Thanks a lot. I’ll give that bricklink a try…is there a way to upload the csv or something to import the parts i need?
UPDATE: got it and ordered! €40 incl shipping…looking forward to modding! Thanx a lot peeps!
Edited by Meukie
@langko would you mind showing how you did the front in more detail? It looks clean AF and would love to improve mine!
@ernestomn98
I did all the changes while I built the pimped up version. Since the chassis is different and I changed other things as I went along I couldn’t possibly tell you every change from the stock version.
But if you wanted to improve your model I’d encourage you to just have a go yourself and see what you come up with.
  • 6 months later...
  • 2 months later...
Hi fox, hope you doing well.
It's been a year I built my Chiron by following the Pimp up my Bugatti instructions (big thanks to @jb70)
However I have an issue now with the gearbox in drive mode.
The 4th gear pass smootlhy but the next 4: impossible. Pedal shifter seems to be not strong enough or something happen inside the gearbox.
To pass the 4th last gear, I hade to turn manually the gear wheel (normally operated by the pedal shifter) to pass on the 5th gear. After that, I can re use again pedal shifter.
The issue seems to be around the gear block.
I don't know if I have to disassemble everything or not (I hope nop).
  • 7 months later...
