Tcm0 Posted January 15, 2020 Posted January 15, 2020 Is there a reason why you use the speed control and not the motor power control? Do both of your motors have rotation sensors? It might help to put a delay of about 0.2 seconds after the motor block because the program might cause too many reads. Quote
Lok24 Posted January 15, 2020 Posted January 15, 2020 1 hour ago, Tcm0 said: Is there a reason why you use the speed control and not the motor power control? Yes, because I wand to control the speed 1 hour ago, Tcm0 said: Do both of your motors have rotation sensors? Sure. Type of motor doesn't change behaviour 1 hour ago, Tcm0 said: It might help to put a delay of about 0.2 seconds after the motor block because the program might cause too many reads. 1.) it doesn't help 2.) as I wrote it works without problems on technic hub or move hub 3.) no matter what useless programm, motor have to stop when program is cancelled. It doesnt. 4.) Hub looses connection Quote
Tcm0 Posted January 15, 2020 Posted January 15, 2020 3 hours ago, Lok24 said: Sure. Type of motor doesn't change behaviour The "dumb" motors (train motor and wedo 2.0/ batmobile) motor can't measure their speed so you can't control them via speed. You can only control them via power. The program works for me with 1x Hub v4 and 2x boost medium linear motors. Quote
Lok24 Posted January 15, 2020 Posted January 15, 2020 (edited) Thanks for testing. I tried with boost, L and XL, all the same. But not with two boost motors. Doesn't work with hub No. 4, works with move hub and technic hub. FW is 1.1.02.0000, SW is 3.0.0 As you can see there are two icons for tacho motors. You should regulate the speed of A when turning motor B by hand. According to "Power": You can set the max power per motor, but this is something different. All other icons set "speed" from -100 to 100 (percent) , which is not the real speed, cause it depends on battery voltage. The real speed can set i.e. with micro python and EV3, you can set rpm there. Edited January 15, 2020 by Lok24 Quote
Tcm0 Posted January 15, 2020 Posted January 15, 2020 I'm not sure about the FW; it should be the current one. Powered Up SW is 3.0.0. But yeah, you're right. Boost motor + Control+ XL Motor don't work. 2x Boost however do work Quote
Lok24 Posted January 16, 2020 Posted January 16, 2020 Thanks. If SW is 3.0.0. your hub should have been automatcally updatet to 1.1.02.0000 You can easily install Brick Controller 2 App and with "devices" and "search" find out FW versions of your hubs. Quote
Bartosz Posted January 16, 2020 Posted January 16, 2020 I'm wondering what are the semantics of such block configuration. Is it: a) PU app reads back the value from motor B from the hub, then feeds the hub with the "set speed" command with value obtained b) the hub is instructed to maintain such "dependency" between the value produced from B and value feed to A Now, the advantage of b) would be that it wouldn't suffer from the BT latency, but I think it's unlikely it's implemented this way (I think it would hard thing to do?). Why am I mentioning this? Well, that's something I've been wondering after I saw your blocks, and it's something that would kinda explain why it wouldn't work with one hub and work with others...but really, this seems to be far fetched, correct me if I'm (terribly) wrong. :) Quote
Lok24 Posted January 16, 2020 Posted January 16, 2020 (edited) Hi, b.) doesn't work, the commands are always trasferred to the app. The purpose of the programm is very simple: assume a merry-go-round with a motor, then you can regulate the speed with the second motor, using it as a sensor. This is for stationary modells. Of course you still need the app running. (not with Large Hub, for other hubs this is expected: compiling a prog and load it permanently into the hub and start it without smart device) The original program has much more blocks and can be used for mobile and remote usage, setting some parameters (hub No, port no) , but didn't work, reducing to only one block showed this strange behavior. It calibrates the input motor, sets it to 0, here is a version with two hubs for mobile use, the white box is sender with the wheel and a switch for forward, reverse and stop, the technic hub is the receiver: Edited January 16, 2020 by Lok24 Quote
PF Remote Posted January 30, 2020 Posted January 30, 2020 Hi, finally my Powered Up app alternative is done. You can now download it from Google Play Store. Here is the link: https://play.google.com/store/apps/details?id=com.pfremote.putools Hope you will like it:) Just ask me if you have ideas? Quote
Jetro Posted January 31, 2020 Posted January 31, 2020 OK, so here's my first question: why would I pay for an app when there is already a great free alternative available? Quote
PF Remote Posted January 31, 2020 Posted January 31, 2020 @Jetro Yes, I am sure about it that you have a great alternative from LEGO, but I can understand when somebody likes a different design, add custom tunes, be able to control the speed more flexible through moving the seek bars in an easier way than the LEGO app and connecting faster than with the standard LEGO app. I have also realized that the standard LEGO app has problems with connection. You also have Volume-Button-Control option that let's taking control over the hub by pressing volume buttons of your phone. You can run the app easily in background so this also a feature that does not always work in the android PU app. Why do I want to get money for it? The main reason is that I am a 15 years old android app developer and want to earn some pocket money. I would never do it when LEGO would not be my hobby. Hope you understand it. Quote
AVCampos Posted January 31, 2020 Posted January 31, 2020 I'm also a bit put off by the price. I'm sure Jetro wasn't comparing your app with the official Control+ and PU from TLG, but rather third-parties like BrickController 2 (which uses a gamepad, which means physical controls) and BuWizz (which was made to control BuWizz bricks but also works with PU), both of which are free. Quote
PF Remote Posted January 31, 2020 Posted January 31, 2020 @AVCampos Hi, yes I understand what you mean. I will think about reducing the price or make the app completely free, maybe even Opensource. Thanks for your feedback BTW:) Quote
Philo Posted January 31, 2020 Posted January 31, 2020 I am not against some payment, but I'd like to be able to test it first! Quote
PF Remote Posted January 31, 2020 Posted January 31, 2020 (edited) @Philo Thanks for this great idea. I will post a demo version, for example with a watermark so you will be able to test it out. If you like it than you will be able to download the full version. What do you think about posting an apk on Google Drive and sharing the link for this test version than. Edited January 31, 2020 by PF Remote Quote
GianCann Posted January 31, 2020 Posted January 31, 2020 @PF Remote take a look on my free App ;) https://play.google.com/store/apps/details?id=appinventor.ai_mtbike_rider71.PuTrains Quote
PF Remote Posted January 31, 2020 Posted January 31, 2020 @GianCann Like it, although the design on bigger screens could have a better resolution. Quote
Phil B Posted January 31, 2020 Posted January 31, 2020 2 hours ago, PF Remote said: @Jetro Yes, I am sure about it that you have a great alternative from LEGO, but I can understand when somebody likes a different design, add custom tunes, be able to control the speed more flexible through moving the seek bars in an easier way than the LEGO app and connecting faster than with the standard LEGO app. I have also realized that the standard LEGO app has problems with connection. You also have Volume-Button-Control option that let's taking control over the hub by pressing volume buttons of your phone. You can run the app easily in background so this also a feature that does not always work in the android PU app. Why do I want to get money for it? The main reason is that I am a 15 years old android app developer and want to earn some pocket money. I would never do it when LEGO would not be my hobby. Hope you understand it. I am very appreciative of you building a functional Android App at age 15. Well done. Don't let the feedback here discourage you from continuing to build your skills as a programmer. That said the world of apps is a tough place, and just like when building your professional career you sometimes have to start with doing work for free (internships, volunteering etc) to build up your credentials. Especially since there are already other apps out there that do PU control and are free (either because the publisher decided to give the app away for free, or because the app is tied to a paid product (e.g. BuWizz)), your hands are basically tied. Now if your app has some unique capabilities that others dont have, you could put those behind a paid subscription, while keeping the rest of your app free (the so-called "freemium" model). Good luck! Quote
PF Remote Posted January 31, 2020 Posted January 31, 2020 @Phil B Thank you for your tips and motivation to make other cool projects;) I think that "freemium" is a great idea to make my app marketing. Although I think that first I will try to sell it and make a free version with a watermark for testing. You are right, there are many competitors when you look at PU software. Quote
PF Remote Posted February 3, 2020 Posted February 3, 2020 Hi, I have made a demo now with a watermark. You can download the test version now from google drive:https://drive.google.com/file/d/1x75Fquqs26aOHplBXKrtNT8S-5tFEEA6/view?usp=sharing This version has all features of PUTools in the Play Store. The only difference is the watermark. If you like it you can download the normal version from Play Store: https://play.google.com/store/apps/details?id=com.pfremote.putools When there are some bugs please report me about them so I can fix them. Quote
PF Remote Posted February 6, 2020 Posted February 6, 2020 Hi, I have decided to move from this thread. So if you want to get some more informations about PUTools read here: Quote
ruppie Posted February 10, 2020 Posted February 10, 2020 Hello. actually apps are not my primary interest, for that reeason i build a Bluetooth Car control, that i am using with LEGO Rally car as shown here at the end of review comments. Feel free to ask whatever you lie, if you like . Quote
Toastie Posted February 12, 2020 Posted February 12, 2020 Dear All, I have a question regarding the Technic hub (4I/O, Control+, whatever) - the one that has 4I/O ports and comes with e.g. the Liebherr 42100 Monster: What are the port IDs / hub properties for the internal tilt sensor? The LEGO Wireless Protocol 3.0.00 Documentation (r17) on Github is simply static - nothing much has changed there since the initial publication. This document tells me that the internal tilt sensor is of type 0x0028. The bare Technic Hub replies during discovery etc. with: Port Type 0F 00 04 | 32 | 01 | 17 00 | 00 00 00 10 00 00 00 10; Type = LED light 0F 00 04 | 3B | 01 | 15 00 | 00 00 00 10 00 00 00 10; Type = Current 0F 00 04 | 3C | 01 | 14 00 | 00 00 00 10 00 00 00 10; Type = Voltage 0F 00 04 | 3D | 01 | 3C 00 | 00 00 00 10 00 00 00 10; Type = ??? 0F 00 04 | 60 | 01 | 3C 00 | 01 00 00 00 01 00 00 00; Type = ??? 0F 00 04 | 61 | 01 | 39 00 | 01 00 00 00 01 00 00 00; Type = ??? 0F 00 04 | 62 | 01 | 3A 00 | 01 00 00 00 01 00 00 00; Type = ??? 0F 00 04 | 63 | 01 | 3B 00 | 01 00 00 00 01 00 00 00; Type = ??? 0F 00 04 | 64 | 01 | 36 00 | 01 00 00 00 01 00 00 00; Type = ??? I simply can't find any information on the ??? types. How can I retrieve the 3D tilt and acceleration data Any help is appreciated! Best Thorsten Quote
AlecDGeneric Posted February 12, 2020 Posted February 12, 2020 @Toastie You can ask the devices for their capabilities. This is shown in 6.3.1 of the doc (connection info) though admittedly not quite as clearly as one would like. Basically the process would be: send 05 00 21 [port] 01 (3.15. Port Information Request) it replies with 43 (3.19. Port Information), of which byte 7 (counting the first as 1) denotes the number of modes, note this for each mode (or until you're satisfied) ask for the name with 06 00 22 [port] [mode] 00 (3.16. Port Mode Information Request; mode are [0 - number of modes) ), the reply 44 has the mode's name as ascii starting at byte 7 (not \0 terminated, 3.20.Port Mode Information); asking for the symbol (06 00 22 [port] [mode] 04) may also help since it would be relevant to the data (like probably g for accelerattion or DEG for tilt) with this you should now also have the relevant mode to subscribe to for your 41 message I used this method recently to map out the modes of the color/distance sensor, so this should work. Hope that helps. Quote
Mr Hobbles Posted February 12, 2020 Posted February 12, 2020 1 hour ago, Toastie said: Dear All, I have a question regarding the Technic hub (4I/O, Control+, whatever) - the one that has 4I/O ports and comes with e.g. the Liebherr 42100 Monster: What are the port IDs / hub properties for the internal tilt sensor? The LEGO Wireless Protocol 3.0.00 Documentation (r17) on Github is simply static - nothing much has changed there since the initial publication. This document tells me that the internal tilt sensor is of type 0x0028. The bare Technic Hub replies during discovery etc. with: Port Type 0F 00 04 | 32 | 01 | 17 00 | 00 00 00 10 00 00 00 10; Type = LED light 0F 00 04 | 3B | 01 | 15 00 | 00 00 00 10 00 00 00 10; Type = Current 0F 00 04 | 3C | 01 | 14 00 | 00 00 00 10 00 00 00 10; Type = Voltage 0F 00 04 | 3D | 01 | 3C 00 | 00 00 00 10 00 00 00 10; Type = ??? 0F 00 04 | 60 | 01 | 3C 00 | 01 00 00 00 01 00 00 00; Type = ??? 0F 00 04 | 61 | 01 | 39 00 | 01 00 00 00 01 00 00 00; Type = ??? 0F 00 04 | 62 | 01 | 3A 00 | 01 00 00 00 01 00 00 00; Type = ??? 0F 00 04 | 63 | 01 | 3B 00 | 01 00 00 00 01 00 00 00; Type = ??? 0F 00 04 | 64 | 01 | 36 00 | 01 00 00 00 01 00 00 00; Type = ??? I simply can't find any information on the ??? types. How can I retrieve the 3D tilt and acceleration data Any help is appreciated! Best Thorsten Type 3C is a temperature sensor (there are two of them, don't know where they're located), 39 is the accelerometer, 3A is the gyro, 3B is the tilt sensor, and 36 is the gesture sensor. I added support for the accelerometer, gyro, and tilt sensor modes node-poweredup, here's the code. It may help you parse them: https://github.com/nathankellenicki/node-poweredup/blob/master/src/devices/technicmediumhubaccelerometersensor.ts https://github.com/nathankellenicki/node-poweredup/blob/master/src/devices/technicmediumhubgyrosensor.ts https://github.com/nathankellenicki/node-poweredup/blob/master/src/devices/technicmediumhubtiltsensor.ts I haven't added the temperature sensor as I haven't gotten around to it yet (and wasn't sure of its usefulness given we don't know its location or what it represents). Same for the gesture sensor. As @AlecDGeneric suggested, this was figured out by querying the devices for their metadata. The documentation hasn't been updated in a while (and I'd be surprised if it gets an update any time soon!) Quote
