The aim of this build is to make an RC car with a "useful" gearbox. I hope it will reach full speed faster by using both gears.
So far I have a gearbox in the 1:10 chassis. It has dual clutch working on the 2 outputs from the buggy motor. Full "throttle" shifts are (almost) instant especially from 1st to 2nd.
The gear change servo is operated by the buwizz "light button". On is 1st, off is second.
I gearbox works perfectly while driving, there is no pause between gears, but the car is light enough to set off in 2nd. If this car becomes too heavy I have a smaller car in reserve.
Edited by JamesJT
details added
Under load situation can (will) be different.
No, the test chassis is only 610g and it works perfectly. When it gets too heavy I will either reduce the size or lower the gearing.
2 hours ago, zweihander said:
That panelling has a real good "speed racer" vibe to it :thumbup:
Thanks. If I don't use it on this MOC I will use it later.
5 hours ago, brickless_kiwi said:
Very nice use of panels has that jaguar ď type feel to the build
Thanks. There are bits of C and D type in there, I also thought it looked a bit mid/rear engine like a porsche RS-61.
I need to make a modern car with this gearbox, it would be nice to have a visual clue (such as a pop up spoiler) to show which gear is being used.
The car does reach full speed quicker when using both gears. I have not yet tested it against a version of the car with the high gearing and all gearbox parts removed.
