Posted June 14, 20186 yr Here's my latest MOC, a C model for the 4x4 Crawler (9398) set. Features: 4x4 drive achieved by 2 hard coupled L motors, with an overall 1:1 gear ratio 1 Servo motor for steering Pendular rear suspension* Easily remove the battery box by pulling the red pushpin on either white curved panel, pulling the smokestacks out, lifting the roof, pulling the two axle/lift assemblies keeping the BB from sliding around, and pull the BB out. Openable hood LDraw, and Stud.i files available here Notes: I have assembled this physically, didn't take any pictures though. The LDraw file is wonky in spots, such as the rear from the motors, back, and how I couldn't get the back axle tilted to connect the top rods, you should be able to fgure it out though. *not sprung, couldn't fit them on nicely, this this is made to go fast, not rock climb anyways
June 15, 20186 yr Author On 6/14/2018 at 8:24 AM, Aventador2004 said: It is pretty good, could be better with regular suspension on back. Thanks, and I do agree, it would have been better with proper suspension, I just couldn't figure out how to make it work, without having 2 big springs sticking up behind it.
