Bartybum Posted August 10, 2018 Posted August 10, 2018 Can you use hard springs to help lift the boom so that it can start from a horizontal position? Quote
curakar Posted August 12, 2018 Posted August 12, 2018 hello folks.... i realy dont like the new crane hook....has someone bild a better looking hook? Quote
M_longer Posted August 12, 2018 Posted August 12, 2018 21 minutes ago, curakar said: has someone bild a better looking hook? There is nothing better than metal hook: https://www.bricklink.com/v2/catalog/catalogitem.page?P=70644&name=Technic Hook Large Metal&category=[Technic] Quote
curakar Posted August 12, 2018 Posted August 12, 2018 19 minutes ago, M_longer said: There is nothing better than metal hook: https://www.bricklink.com/v2/catalog/catalogitem.page?P=70644&name=Technic Hook Large Metal&category=[Technic] yes this is the right one.....but stil need to add some parts to make it bigger and more realistic Quote
suffocation Posted August 12, 2018 Posted August 12, 2018 Found this. Still have to figure out how to thread it. Quote
pleegwat Posted August 12, 2018 Posted August 12, 2018 The metal hook isn't that small. It's mostly thinner than the brick-built one in the model (only 1 stud thick). If you include the pulley wheel the metal hook is actually slightly taller. Looking at photo reference on GIS and in the other topic mostly turns up hooks more similar to the metal hook than to the thick, wide brick-built one in the model. And double hooks actually seem to be rare on this type of crane - most have simple hooks, like this: Quote
curakar Posted August 12, 2018 Posted August 12, 2018 i was thinking like that kind of hook... has enyone has parts list or instructions ? Quote
ctx1769 Posted August 12, 2018 Posted August 12, 2018 The metal hook does the trick, I fitted one to 42009, still got 2 left. One for the truck crane and one for this mobile crane Quote
efferman Posted August 13, 2018 Posted August 13, 2018 Does anyone has the left bevel gear too? interrestingly it has dimple at the crosshole, but not large enough for a axle stop now a small mod Quote
CraneDude401 Posted August 13, 2018 Posted August 13, 2018 5 hours ago, efferman said: Does anyone has the left bevel gear too? interrestingly it has dimple at the crosshole, but not large enough for a axle stop now a small mod What are you trying to do here? Im a little confused How do you upload pics? This 0.1mb cap sucks Quote
Bartybum Posted August 13, 2018 Posted August 13, 2018 26 minutes ago, CraneDude401 said: What are you trying to do here? Im a little confused How do you upload pics? This 0.1mb cap sucks Basically the way that the LA work in the original set is that they both angle upwards as the boom lifts. Since they’re set up opposite ways in the set, one LA screw will slightly extend as the boom rises whereas the other LA screw will slightly contract. This causes most of the load to be placed on a single LA rather than both. What @efferman has done is make both of the screws rotate in the same way, so that when the boom rises, both LA will change length the same amount, and the load of the boom will be evenly distributed across both of them. I’m amazed that the set designer didn’t see this. Quote
CraneDude401 Posted August 13, 2018 Posted August 13, 2018 12 minutes ago, Bartybum said: Basically the way that the LA work in the original set is that they both angle upwards as the boom lifts. Since they’re set up opposite ways in the set, one LA screw will slightly extend as the boom rises whereas the other LA screw will slightly contract. This causes most of the load to be placed on a single LA rather than both. What @efferman has done is make both of the screws rotate in the same way, so that when the boom rises, both LA will change length the same amount, and the load of the boom will be evenly distributed across both of them. I’m amazed that the set designer didn’t see this. Thats actually pretty damn geniuse! I just did a reaving mod, but i cant upload pics whats the trick to not have a too large of file Quote
Bartybum Posted August 13, 2018 Posted August 13, 2018 37 minutes ago, CraneDude401 said: Thats actually pretty damn geniuse! I just did a reaving mod, but i cant upload pics whats the trick to not have a too large of file Just upload it to imgur and drop a link Quote
CraneDude401 Posted August 14, 2018 Posted August 14, 2018 (edited) Did i do it right lmao?http://imgur.com/gallery/xHcLe66 Edited August 14, 2018 by CraneDude401 Quote
1gor Posted August 14, 2018 Posted August 14, 2018 9 hours ago, CraneDude401 said: Did i do it right lmao?http://imgur.com/gallery/xHcLe66 Just when in editor you see 'post link instead' do no choose it and it should work. Quote
Bartybum Posted August 14, 2018 Posted August 14, 2018 13 hours ago, CraneDude401 said: Did i do it right lmao?http://imgur.com/gallery/xHcLe66 Looks interesting, but your rollers are all on the same axle so they’re gonna rotate at the same speed, unless you’ve drilled out the axles into pinholes. Quote
CraneDude401 Posted August 14, 2018 Posted August 14, 2018 47 minutes ago, Bartybum said: Looks interesting, but your rollers are all on the same axle so they’re gonna rotate at the same speed, unless you’ve drilled out the axles into pinholes. They were drilled on a drill press. The boom head stock is too large to my liking but I will be updating it soon with different parts and configuration Quote
emielroumen Posted August 17, 2018 Posted August 17, 2018 (edited) On 8/13/2018 at 6:44 PM, efferman said: Does anyone has the left bevel gear too? interrestingly it has dimple at the crosshole, but not large enough for a axle stop now a small mod I applied your modification and the boom goes up without any problem. Btw, no gears left as spares in my set. Edited August 17, 2018 by emielroumen Quote
efferman Posted August 18, 2018 Posted August 18, 2018 9 hours ago, emielroumen said: Btw, no gears left as spares in my set. There are no left gears in the set. Only a left and a right gear on the Picture. Quote
emielroumen Posted August 18, 2018 Posted August 18, 2018 6 hours ago, efferman said: There are no left gears in the set. Only a left and a right gear on the Picture. Ok, I misread your comment. As far as I can see now my set came with the traditional gears only. Quote
WvG_853 Posted August 19, 2018 Posted August 19, 2018 Thank you very much @efferman for the mod. I have tried to decipher it. It concerns more or less the steps 667 and 820. Here are two pictures that show the mod alone. Let me know if I made a mistake. Step 667 Step 820 I have used a dark grey “axle and pin connector perpendicular” brick. It was the first I found. The other pieces are spares included in 42082. Quote
WvG_853 Posted August 19, 2018 Posted August 19, 2018 42 minutes ago, efferman said: This is exactly what i did I’m glad I nailed it ... :-) Quote
Metagross555 Posted August 25, 2018 Posted August 25, 2018 http://imgur.com/gallery/fKU5oUt My mods, lego purists beware :] http://imgur.com/gallery/D6A4kFO Quote
emielroumen Posted August 25, 2018 Posted August 25, 2018 3 hours ago, Metagross555 said: http://imgur.com/gallery/fKU5oUt My mods, lego purists beware :] http://imgur.com/gallery/D6A4kFO The multiple lever modification I like the most. Annoying to switch between boom rise, extend, winch every time. Quote
