barneius Posted August 24, 2018 Posted August 24, 2018 (edited) It is my second try at creating a model the way Lego does but at the same time being as sleek and faithful to original as possible. It is not a 100% MOC, because it incorporates some basic structure techniques of 75101 mixed with 75211. 759 pieces plus 56 for a display stand. Imperial TIE Fighter Lego MOC / MOD by Barney Markowski, on Flickr Imperial TIE Fighter Lego MOC / MOD by Barney Markowski, on Flickr Imperial TIE Fighter Lego MOC / MOD by Barney Markowski, on Flickr Imperial TIE Fighter Lego MOC / MOD by Barney Markowski, on Flickr Imperial TIE Fighter Lego MOC / MOD by Barney Markowski, on Flickr Imperial TIE Fighter Lego MOC / MOD by Barney Markowski, on Flickr Imperial TIE Fighter Lego MOC / MOD by Barney Markowski, on Flickr Imperial TIE Fighter Lego MOC / MOD by Barney Markowski, on Flickr Imperial TIE Fighter Lego MOC / MOD by Barney Markowski, on Flickr Imperial TIE Fighter Lego MOC / MOD by Barney Markowski, on Flickr Imperial TIE Fighter Lego MOC / MOD by Barney Markowski, on Flickr Imperial TIE Fighter Lego MOC / MOD by Barney Markowski, on FlickrImperial TIE Fighter Lego MOC / MOD by Barney Markowski, on Flickr Edited August 24, 2018 by barneius Quote
Enforcer Zer0 Posted August 24, 2018 Posted August 24, 2018 (edited) That looks incredible! Is there a rough estimate on how many extra pieces you used? I would love to do something similar to 75211 when I get it! Edited August 24, 2018 by Enforcer Zer0 Quote
barneius Posted August 24, 2018 Author Posted August 24, 2018 (edited) 7 minutes ago, Enforcer Zer0 said: That looks incredible! Is there a rough estimate on how many extra pieces you used? Thx. There is absolutely no point in buying 75211 to build this, unless of course you already have one (I've checked all parts before deciding). If I remember correctly, you would not use even half of the pieces (I am not certain though). Edited August 24, 2018 by barneius Quote
Enforcer Zer0 Posted August 24, 2018 Posted August 24, 2018 13 minutes ago, barneius said: Thx. There is absolutely no point in buying 75211 to build this, unless of course you already have one (I've checked all parts before deciding). If I remember correctly, you would not use even half of the pieces (I am not certain though). I have not bought one yet and probably won't unless the price is right for me, bummer that your mod only uses about half the pieces but I might keep the original core of the set and do some of your mods to the wings. Quote
Kristof Posted August 24, 2018 Posted August 24, 2018 Looks really nice! It almost giver me similar vibe as Jerac mocs, while it seems quite a bit more conventional and hence user and swoosh friendly. Good job! Quote
Cylo Posted August 24, 2018 Posted August 24, 2018 I already have a 75211 but would definitely give that up for this. Is there an lxf file for this? Quote
barneius Posted August 24, 2018 Author Posted August 24, 2018 29 minutes ago, krisandkris12 said: as Jerac mocs Now that is a compliment. Credits for Jerac. 31 minutes ago, krisandkris12 said: quite a bit more conventional and hence user and swoosh friendly That is exactly what I meant writing "the way Lego does". It is indeed as stable as last Lego sets. Thx for appreciation. 34 minutes ago, JarJarBonks said: I already have a 75211 but would definitely give that up for this. Is there an lxf file for this? Yes. I have designed it in LDD. Still have to tweak it just a little bit, but there is a plan I put it (also divided into main parts) together with BL xml file on bricklink for couple of euros. I want to dig into it soon. I am totally fresh in these matters at the moment. Quote
Makin Bacon Posted August 24, 2018 Posted August 24, 2018 (edited) the way you designed the cockpit area reminds me a lot of the UCS set. I think this looks miles better than any of the official system scale sets Edited August 24, 2018 by Makin Bacon Quote
Kim-Kwang-Seok Posted August 26, 2018 Posted August 26, 2018 this is the Tie we should have gotten with Solo. I wanted to purchase the latest one and thought "ok I'll just modify this and this..", but after seeing a few reviews of it... I found myself wondering "ok I will have to pretty much redesign the whole thing". Often I think bad sets are made due to limitations given to very capable designers. But with the latest Tie, I thought after one point: "wow, I can't understand any of the design choices at all. Like the blocky sections at the top. Quote
SquirrelArmy Posted September 1, 2018 Posted September 1, 2018 How many studs wide is the TIE? I'm looking at potentially adding two TIE's to an MOC I'm building and the width of each one is fairly critical. Quote
barneius Posted September 2, 2018 Author Posted September 2, 2018 On 9/1/2018 at 12:38 PM, SquirrelArmy said: How many studs wide is the TIE? I'm looking at potentially adding two TIE's to an MOC I'm building and the width of each one is fairly critical. It is 22 studs wide on these photographs but I have narrowed it to 20 as in official sets. Proportions are much better when it's 20. On 8/26/2018 at 3:53 AM, Kim-Kwang-Seok said: But with the latest Tie, I thought after one point: "wow, I can't understand any of the design choices at all. 100% agree. This latest TIE Fighter looks like they just wanted to use strange techniques instead of designing a nice model. THANKS EVERYBODY for your positive feedback. As I've written above - I've narrowed it to 20 studs and done some minor tweaks as well. Brick count is 732 at the moment and the LDD file is ready. I will be putting it on Rebrickable in couple of weeks. Quote
SquirrelArmy Posted September 2, 2018 Posted September 2, 2018 8 minutes ago, barneius said: It is 22 studs wide on these photographs but I have narrowed it to 20 as in official sets. Proportions are much better when it's 20. A pair of the new versions would fit nicely in my MOC. You say you've incorporated methods from 75101 and 75211, which of the two sets would you recommend starting with? There's a lot of TIE specific elements such as the cockpit cover and pilot as well as other printed pieces that I'd need to purchase so it does make sense to start with an existing set and mod it to match your design Quote
barneius Posted September 2, 2018 Author Posted September 2, 2018 (edited) 10 minutes ago, SquirrelArmy said: You say you've incorporated methods from 75101 and 75211, which of the two sets would you recommend starting with? There's a lot of TIE specific elements such as the cockpit cover and pilot as well as other printed pieces that I'd need to purchase so it does make sense to start with an existing set and mod it to match your design It was designed in LDD first. Originally I planed to buy 75211 but after counting pieces I could have used, it appeared there is absolutely no point. Buying original set + needed elements would be much more expensive than just buying parts I needed on BL. If you want original set anyway buy 75211 but for instance the panels build resembles more 75101 (there is critical difference in connection_to_fuselage part of the build). Edited September 2, 2018 by barneius Quote
GariLecelt Posted June 5, 2019 Posted June 5, 2019 On 8/24/2018 at 11:57 PM, barneius said: Now that is a compliment. Credits for Jerac. That is exactly what I meant writing "the way Lego does". It is indeed as stable as last Lego sets. Thx for appreciation. Yes. I have designed it in LDD. Still have to tweak it just a little bit, but there is a plan I put it (also divided into main parts) together with BL xml file on bricklink for couple of euros. I want to dig into it soon. I am totally fresh in these matters at the moment. Hi First of all congrats for this amazing moc /mod, I'm loving it. It was my birthday last Saturday and I 've received the 75211. I' ll like to customized it with some of your ideas. Will it be possible to post the lxf file? Thank you Quote
barneius Posted June 5, 2019 Author Posted June 5, 2019 22 minutes ago, GariLecelt said: Hi First of all congrats for this amazing moc /mod, I'm loving it. It was my birthday last Saturday and I 've received the 75211. I' ll like to customized it with some of your ideas. Will it be possible to post the lxf file? Thank you Thank you. First of all you may find updated version here: Sorry, I do not provide LDD files, yet PDF step-by-step instructions are abailable at rebrickable for 6,99 Euro here: https://rebrickable.com/mocs/MOC-19900/barneius/fighter-imperial-twin-ion-engine/#comments Quote
GariLecelt Posted June 5, 2019 Posted June 5, 2019 7 hours ago, barneius said: Thank you. First of all you may find updated version here: Sorry, I do not provide LDD files, yet PDF step-by-step instructions are abailable at rebrickable for 6,99 Euro here: https://rebrickable.com/mocs/MOC-19900/barneius/fighter-imperial-twin-ion-engine/#comments Yeah, that's already great and cheap for what it represent to me. Thank you Quote
