TheBuildingBlock Posted September 24, 2018 Posted September 24, 2018 I've modified the motorcycle (part 52035), used since 2005, in three different ways - basic, long axle, and reverse trike. Expect an instruction video for the reverse trike to follow. Quote
TheBuildingBlock Posted September 27, 2018 Author Posted September 27, 2018 Here is the instruction video for the reverse trike chassis so that you can build your own. Here is the parts list: No. Color Part no. Part name ------------------------------------------------------------------------------- 1 Black 32013.dat Technic Angle Connector #1 3 Black 4519.dat Technic Axle 3 1 Black 3705.dat Technic Axle 4 2 Light_Gray 3749.dat Technic Axle Pin 2 White 6632.dat Technic Beam 3 x 0.5 Liftarm 2 Black 2825.dat Technic Beam 4 x 0.5 Liftarm with Boss 2 White 2825.dat Technic Beam 4 x 0.5 Liftarm with Boss 2 Light_Gray 4265c.dat Technic Bush 1/2 Smooth 1 Black 32556.dat Technic Pin Long 4 Black 92409.dat Tyre 17.5mm x 6mm with Shallow Staggered Threads 4 Light_Gray 42610.dat Wheel Hub 8 x 11.2 with Centre Groove Quote
