Ngoc Nguyen Posted March 9, 2019 Author Posted March 9, 2019 And I proudly present to you, the comparison of all Unimog-tyred models! I don't include the Unimog cabin because it's gonna block the view of other models. All models are aligned to their front axles. It's nice that all of them are 4x4 non-off-roaders. In terms of wheel base length, from smallest to largest, the order is 42030 A -> 42030 B -> 42082 -> 8110. Quote
keymaker Posted March 9, 2019 Posted March 9, 2019 I know that I am asking for much, but there is possibility, that someone has a Nico71's C model of 42082 and 42030 and can share a photo of them standing next to each other. Just like on the pictures above? Quote
Ngoc Nguyen Posted March 11, 2019 Author Posted March 11, 2019 (edited) What should I do next? I'm thinking of a 8110 A vs 42054 A, and also 8110 B vs 42054 B. Edited March 11, 2019 by Ngoc Nguyen Quote
Blakbird Posted March 12, 2019 Posted March 12, 2019 Interesting thread. Since there are LDraw files available for every model (and many B-models), it is pretty easy to make comparison pictures without even owning the sets. In the beginning of Technicopedia, I took photos much as you are doing. I would line up all the cranes, for example, and snap a photo. There were several drawbacks to this: You need to own all the models You need to have all the models assembled You need to have space not only to arrange them, but to get far enough back to take a photo and get them in frame You need to repeat all of that every time a new model is added to the category As time went on, it was no longer possible to take a photo that included all the models in a large group, so I switched to virtual pictures using LDraw. You might say this is cheating, but it does a good job of comparing all the sizes as long as you use the same camera for everything, and also makes it MUCH easier to add a new model. I owned all the models up to 2016 but don't have physical copies of anything since then. Quote
Ngoc Nguyen Posted May 7, 2019 Author Posted May 7, 2019 (edited) Deleted Edited January 2, 2021 by Ngoc Nguyen Quote
BrickbyBrickTechnic Posted May 7, 2019 Posted May 7, 2019 Funny how the cars become less impressive as you go through the years for least to most recent. Quote
arijitdas Posted May 7, 2019 Posted May 7, 2019 1 hour ago, Ngoc Nguyen said: 4 years of 1H Technic cars: 2013, 2015, 2018, 2019. I used to own a 8070 as well, but I gave it away because it's too ugly by modern standards. @arijitdas You may find what you request earlier in this post. Thanks mate. This is a great comparison. Quote
SuperChiefer84 Posted May 7, 2019 Posted May 7, 2019 (edited) My 42070 and 42043 Edited May 7, 2019 by SuperChiefer84 Quote
Ngoc Nguyen Posted June 23, 2019 Author Posted June 23, 2019 (edited) 42082 A vs 42082 B The superstructure of 42082 B is mounted 2 studs forward compared to that of 42082 A. Also, there are several differences in the rear of the two superstructures: 1. The middle switch in 42082 A can select forward or backward, but that in 42082 B can only open backward. The reason is that the stomping function only requires movement in one direction only. 2. The instruction stickers in 42082 A can't be reused in 42082 B, so the designer uses color codes instead. The red light stud is used to denote the winch, while the green light stud is used to denote the boom's pushing function. 3. The middle switch in 42082 B has a dedicated slot to go backward to. 4. Because of the walls of the slot, the engine cover opens forward in 42082 A, but backward in 42082 B. 5. The battery box cover opens upward in 42082 A, but detaches completely in 42082 B. 6. The two sides in 42082 B have different lengths. The one in the drive's side is one stud longer. Edited January 2, 2021 by Ngoc Nguyen Quote
Maaboo the Witch Posted June 23, 2019 Posted June 23, 2019 Looks like 42082-B would be easier to store. Quote
TeamThrifty Posted June 23, 2019 Posted June 23, 2019 21 minutes ago, Maaboo35 said: Looks like 42082-B would be easier to store. Store?!! Its lego old lad, take it to bits and build something with it!! Quote
Maaboo the Witch Posted June 23, 2019 Posted June 23, 2019 4 minutes ago, TeamThrifty said: Store?!! Its lego old lad, take it to bits and build something with it!! Old lad?! I'm probably younger than you! Quote
Ngoc Nguyen Posted June 23, 2019 Author Posted June 23, 2019 (edited) Deleted Edited January 2, 2021 by Ngoc Nguyen Quote
Maaboo the Witch Posted June 23, 2019 Posted June 23, 2019 Aww, why you hatin' on 42080-B? Utility is the true essence of beauty. Those flippin' hoses in the boom just won't stay in place though... Quote
Ngoc Nguyen Posted July 4, 2019 Author Posted July 4, 2019 (edited) Two generation of medium sized helicopters. 8068 B vs 42092. 8068 A is too similar to 42092, and I like the bubble canopy more. The biggest improvement is the design of the winch. In 8068, when I swoosh it, there's a chance that the string will go backwards due to gravity and unspool. But that cant happen in 42092, which is a big plus. Putting the rotor knob under the model also helps. In 8068, the knob is right under the rotor, so my hand can interfere with the blades. That doesnt happen in 42092. Edited July 4, 2019 by Ngoc Nguyen Quote
Vectormatic Posted July 4, 2019 Posted July 4, 2019 regarding the H1 cars, i have all of those myself, yet i cant bring myself to put 42077 on display, it is just too damn ugly 42000 and 42039 were quite impressive at the time, and i really enjoyed messing around with them (both are modified), but compared to the Chiron, which i just added to the lineup, they suddenly seem insignificant, and im wondering if i shouldnt replace them with something more impressive. Quote
Ngoc Nguyen Posted July 5, 2019 Author Posted July 5, 2019 Uwe's truck vs Markus's truck. Both trucks have the same wheel base. Quote
dabo Posted July 5, 2019 Posted July 5, 2019 I remember wanting the red truck badly when it was new but never bought it. :( Quote
Maaboo the Witch Posted July 5, 2019 Posted July 5, 2019 I think the 8258 resembles an Iveco Stralis, circa 2009 of course. Quote
nerdsforprez Posted July 5, 2019 Posted July 5, 2019 I mean no disrespect by the following post. In fact, I think this thread is a great idea. It is one of the few that I actually took the time to look at all the pages and read the content! Great to see the real-life comparisons of all the models. However, if the purpose is to compare the models, a little more time and effort in the pictures would be nice. Most are pretty blurry by today's standards, and there is much clutter in the background. Most pictures one has difficulty distinguishing where one model begins and when the other ends. Defining boundaries of the sets is very difficult. Perhaps it would be good to invest in a better camera. Doesn't have to be anything expensive. Nowadays, pretty much anything will at least take clear pics. Or for a no-cost solution, at least remove all the background stuff, and place like a white sheet or something as the background and floor. But overall, great idea of a thread. My recommendations only serve as a reflection of my interest in the post. Quote
Anio Posted July 5, 2019 Posted July 5, 2019 On 5/7/2019 at 10:17 PM, BrickbyBrickTechnic said: Funny how the cars become less impressive as you go through the years for least to most recent. 42039 was certainely an impressive design. But not for good reasons. Quote
Ngoc Nguyen Posted July 6, 2019 Author Posted July 6, 2019 2 hours ago, nerdsforprez said: Perhaps it would be good to invest in a better camera. Doesn't have to be anything expensive. Nowadays, pretty much anything will at least take clear pics. Or for a no-cost solution, at least remove all the background stuff, and place like a white sheet or something as the background and floor. But overall, great idea of a thread. My recommendations only serve as a reflection of my interest in the post I'll see what I can do. Quote
Ngoc Nguyen Posted July 18, 2019 Author Posted July 18, 2019 Crane Sr. vs Crane Jr. Default state With all outriggers deployed With boom fully erected The spider crane has a really poor lifting angle. Quote
Ngoc Nguyen Posted July 18, 2019 Author Posted July 18, 2019 The crane bros: Tracked Crane vs Spider Crane vs Crawler Crane Quote
