Posted October 18, 20186 yr In this video, I show you how to make a tank with an Arduino board and 360° RC servos.
October 18, 20186 yr Very nice! I have been using servo motors driven by an Arduino as well. I am using 3D printed enclosures to hold the motor and a 3D printed adapter to allow attachment of an axle. I think I'm going to try you method on my next build. It look like it could make things more compact. Edited October 18, 20186 yr by Larry Andersen
October 18, 20186 yr Neat. Something to do with the ultrasonic sensor I just received in the mail from China. There are also various LEGO to servo adapters for 3D printing on Thingiverse.com.
October 19, 20186 yr Author Thank you all. It is not so easy to couple RC servo to Lego. That is why I used chain at 4'25". Thank you to give the links in Thingiverse.
October 21, 20186 yr Very nice project - I like that you showed everything: building, connections and code.
November 5, 20186 yr Awesome project! Have you ever thought to make an Arduino adapter and controller for the lego PF motors ?
November 5, 20186 yr Author Lego motors have nothing special. You can implement them with a driver like any motor. Here is an example, but there are many others. Edited November 5, 20186 yr by oracid
November 6, 20186 yr 12 hours ago, oracid said: Lego motors have nothing special. You can implement them with a driver like any motor. Here is an example, but there are many others. Thank you for your reply, but this part I find easy, the hardest part is making an adapter so that we don't have to cut the lego connector from the motor cables :)
November 6, 20186 yr Author 3 hours ago, cristi1337 said: Thank you for your reply, but this part I find easy, the hardest part is making an adapter so that we don't have to cut the lego connector from the motor cables :) Yes, I understand. You can find connector adapter for EV3 wire, but I have never seen for PF. Here, https://fr.aliexpress.com/item/Dupond-Fil-Jumper-C-ble-Femelle-6-p-Connecteur-Cristal-T-te-pour-Pour-BBC-micro/32891042475.html?spm=a2g0w.search0104.3.2.7b1ad6adLZ10Wd&ws_ab_test=searchweb0_0%2Csearchweb201602_4_10065_10068_319_10892_317_5728815_10696_453_10084_454_10083_10618_10304_10307_10820_10821_537_10302_536_5730115_5733215_5733315_10843_328_10059_10884_5733115_10887_5732715_100031_5733415_321_322_10103_10913_5729115_10912_5733515_5733615%2Csearchweb201603_55%2CppcSwitch_0&algo_pvid=8a2d6047-7b68-4efc-a0a8-5c7241f4422d&algo_expid=8a2d6047-7b68-4efc-a0a8-5c7241f4422d-0
November 6, 20186 yr 13 hours ago, cristi1337 said: Thank you for your reply, but this part I find easy, the hardest part is making an adapter so that we don't have to cut the lego connector from the motor cables :) I desoldered the cable from my burnt out LEGO motors (from too much Great Ball Contraptioning), then I crimped some Dupont connectors on the ends. It works pretty good connecting to header pins.
November 7, 20186 yr Author Yes, this is the best way. One more thing, I have notice that only the two wires in the middle are used. I don't understand why there are 4 wires.
November 7, 20186 yr 1 hour ago, oracid said: Yes, this is the best way. One more thing, I have notice that only the two wires in the middle are used. I don't understand why there are 4 wires. Hello for the standard motors they only use the two, but they use all 4 for servo motors
