MichaelWareman Posted December 10, 2018 Posted December 10, 2018 I thought I would create this topic both for help building and program Danny’s humanoid robot — https://robotics.benedettelli.com/jaeg3r-humanoid-robot/ — as well as, enhancements that for it. I need some help. I am at step 168 and the motor piece with the two rubber pieces will not line up so that the movable joints can connect together I have rebuilt the arm twice and it still does not want to come together properly. Do I need to squeeze the motor down more? If so, what is the propose of the rubber pieces? Any help would be greatly appreciated. Mike Quote
NullCube Posted December 10, 2018 Posted December 10, 2018 Hi there Michael, could you share a couple of photos of the building process? E.g. what you have built and what the instructions show to build? That would greatly help in the diagnosis. Thank you! Quote
MichaelWareman Posted December 12, 2018 Author Posted December 12, 2018 I figured out the problem. I did not have the parts oriented properly. Also, there is a fair bit of pressure/squeezing to the rubber pieces to make the holes line up. The two arms are on, but need to be wired in. Then, onto the head. Mike, Quote
