1gor Posted September 25, 2019 Posted September 25, 2019 (edited) @suffocation thanks for image As time passes by I like dark bluish gray XL sprockets more and more. BTW never new that there is something like farcebook or I'm not the only one with autocorrect issue Edited September 25, 2019 by I_Igor Quote
suffocation Posted September 25, 2019 Posted September 25, 2019 Ha ha, no autocorrect (don't even have it), I just like screwing around with names Anyone remember this? Granted, it has four XLs but they're only geared down 5:1 and still have no trouble with an 8 kg model. Quote
1gor Posted September 25, 2019 Posted September 25, 2019 Honest is great virtue. I personally try to make it perfect and check and double check everything and at the end autocorrect screws all my effort. (Hope that It did not screw something in my topic). About lots of gears look at the bright side; one-day if you get enough of that set it will be still great parts pack. Quote
Ngoc Nguyen Posted September 25, 2019 Author Posted September 25, 2019 34 minutes ago, Erik Leppen said: use 8:40 and then 8:28 8z doesnt mesh with 28z horizontally though Quote
Zerobricks Posted September 25, 2019 Posted September 25, 2019 Just now, Ngoc Nguyen said: 8z doesnt mesh with 28z horizontally though It does with a stud offset, like 20:16, 12:24, etc... Quote
Maaboo the Witch Posted September 25, 2019 Posted September 25, 2019 1 hour ago, msk6003 said: Gear ratio is 1:18 Wait, why need linear clutch there? Probably to counteract an ungodly amount of friction... Quote
kbalage Posted September 25, 2019 Posted September 25, 2019 59 minutes ago, suffocation said: Not sure what the speed and torque stats of the new XL motors are but two PF XLs geared down 5:1 would be plenty to move that model around. Same characteristics but different internal gearing, if you gear down the PU XL motor with a 12T/20T you'll get a similar speed. Quote
Snorrowitz Posted September 25, 2019 Posted September 25, 2019 (edited) Found this on youtube. It has a whopping 100 cilinder pieces to dig up. Edited September 25, 2019 by Snorrowitz Quote
Ngoc Nguyen Posted September 25, 2019 Author Posted September 25, 2019 (edited) 100 pieces of rocks! Part inflation is real!!! Edited September 25, 2019 by Ngoc Nguyen Quote
RussianGuy Posted September 25, 2019 Posted September 25, 2019 1 minute ago, Ngoc Nguyen said: 100 pieces of rocks! Part inflation is real!!! Not really, 42055 had 112 :) Quote
Bartybum Posted September 25, 2019 Posted September 25, 2019 2 hours ago, suffocation said: From farcebook. Talk about an inefficient design. How else do you expect them to gear down all the way? Quote
suffocation Posted September 25, 2019 Posted September 25, 2019 1 minute ago, Bartybum said: How else do you expect them to gear down all the way? Using some common sense would be a good start. Quote
Jaromir Posted September 25, 2019 Posted September 25, 2019 Hi guys. Did Sariel say that the video review of a 42100 should be released today? Quote
Ngoc Nguyen Posted September 25, 2019 Author Posted September 25, 2019 Biscuit piece in yellow!!! Quote
Aerolight Posted September 25, 2019 Posted September 25, 2019 big t'chungus destroyer of bank accounts Looking at the part list it looks like a great source of parts for someone one does not have much resent technic (me). Quote
suffocation Posted September 25, 2019 Posted September 25, 2019 (edited) @Aerolight True, and if you live in England then you're likely to find it at Argos for a good 35% off. I believe they were letting 42083 go for £200 today. Edited September 25, 2019 by suffocation Quote
Aerolight Posted September 25, 2019 Posted September 25, 2019 I remember getting the Unimog on release for less than lego direct from argos Quote
Zerobricks Posted September 25, 2019 Posted September 25, 2019 (edited) 3 hours ago, suffocation said: From farcebook. Talk about an inefficient design. Sorry for quiting the pic, but yeah. Seems to me the designers wanted to keep the XL motors dead center in the construction, probably used as a load bearing element. This of course means there's a massive power train gping to the sprockets. I think they also had problems with the torque of the 17,85X geared down XL motor caused the tracks to snap, so they added the new clutch. But all in all, it's not THAT bad, there are only 10 gears in total, 9398 had approximately the same to get from motor to the wheel. One thing they could do is to use a combination of a 40Z and 24Z gear instead of 36Z and 28Z, which would allow for even higher gearing. Edited September 25, 2019 by Zerobricks Quote
pleegwat Posted September 25, 2019 Posted September 25, 2019 First we're afraid of not enough gears in this set, now we're complaining there's too many? Quote
suffocation Posted September 25, 2019 Posted September 25, 2019 2 minutes ago, pleegwat said: First we're afraid of not enough gears in this set, now we're complaining there's too many? Lots of gears are cool when they're used efficiently. Quote
allanp Posted September 26, 2019 Posted September 26, 2019 (edited) The gear train actually looks pretty good to me. Besides the linear clutch the gears are all right next to each other on the axles so there's no room for axles to twist, which should cut down on the jerky movement of past sets. The final gear reduction stage of 28:36 was clearly done so that the axle could clear the new large sprocket, so that the axle could be supported easily at both ends. I also like how the 28 tooth gear is pinned directly to the 36 tooth gear to prevent any twisting of the axle there. I think this is going to move very smoothly. Also I think this gear train is much more interesting than endless 16 tooth gears all turning slowly at the same speed. With a solid structure that doesn't allow for much twisting I think this won't have that much friction because of not having bevel gears (in the real world bevel gears are not a problem when you have tapered roller bearings) or worm gears. @suffocation sure that much larger model used 4 XL motors geared down 1:5, but so what? If those XL motors weren't being bogged down by the weight then that excavator would be moving way too fast for scale. So either the motors are under too much stress or the model moves way too fast, neither of which is desirable for a scale model. Maybe the designers of this set wanted a slower speed to be more scale accurate (to be fair the movement of the arm on 42100 is much too slow!). Edited September 26, 2019 by allanp Quote
Bartybum Posted September 26, 2019 Posted September 26, 2019 8 hours ago, suffocation said: Using some common sense would be a good start. ...that’s not an answer. How would you do it? Quote
mpj Posted September 26, 2019 Posted September 26, 2019 Looking at the part list I noticed there are only 4 brackets for the LAs . The 2 central LAs are connected in an unusual way, you can partially see it from this photo. Quote
