Posted January 30, 20196 yr The catalyst behind me making this was simple- I had a pair of Imperial Hovertanks that I wanted to use in a more combat-oriented context. Therefore, I needed to make something that was a low level hauler (i.e. something like a flatbed truck, at most a few studs off the ground) capable of holding two of Lego's Kyber crystal containers. I remembered from some older books that in the EU, they had 'floats'- basically small speeders capable of even going inside buildings. This inspired me to make a small cab attached to a low flat bed, going back to the 'truck' mentioned above. While the bed is exposed except for the side railings and the rear ramp, I wanted the bed to have at least nominal protection, hence putting heavy doors when doors aren't particularly needed. I also forwent a wide open windscreen for a smaller enclosed one for similar reasons. The idea behind this is that A) the pilot/driver would be protected from rocks and debris, and perhaps even shrapnel (protection from small arms is up in the air); and B) the cab area can be separated from the rest of the speeder (specifically the bed) and be used on other vehicles. SW Imperial Cargo Speeder #1 by Jonathan Wallace, on Flickr SW Imperial Cargo Speeder #3 by Jonathan Wallace, on Flickr SW Imperial Cargo Speeder #5 by Jonathan Wallace, on Flickr SW Imperial Cargo Speeder #2 by Jonathan Wallace, on Flickr SW Imperial Cargo Speeder #4 by Jonathan Wallace, on Flickr Another function is as a small squad transport (Filing Out at Bay 10). Other uses could be placing a crane or some kind of weapon in the back. I'm not sure if a communications center would be a good fit or not. Also, with other things besides cargo or troops in the back, the rear ramp can be removed. I'm sure the bed can also be extended without it be overly long as well. SW Imperial Cargo Speeder #6 by Jonathan Wallace, on Flickr A rough picture of the ICS being ambushed by the Scorpius MRV (coming soon). SW Rebel Scorpius MRV (Multi-Role Vehicle) #3(R) by Jonathan Wallace, on Flickr Any feedback/comments would be appreciated.
February 3, 20196 yr Author If anyone wants to build this, here's the instructions: https://drive.google.com/file/d/1pPEG-t0oeNBDl0hfCpn5kx2zuIsZbC13/view?usp=sharing
