April 9, 20195 yr Author Here is the beginning of the bodywork for the car. My Dad has helped a ton with the bodywork so that`s always a big help. I also printed the logos which I will be turning into stickers sometime this week. Model will be done by 23rd or 24th this month.
April 10, 20195 yr Here is a real car for 500 attempt, so it looks that you chose right colors you just need this panels for front wing https://www.bricklink.com/catalogItemIn.asp?P=11946&colorID=7&in=A
April 11, 20195 yr Author The model is effectively done and will receive very few changes from now until the end of the month. I will be getting two part orders in early June so that I can update the colors and make it more accurate but for now it is as done as it can be with the parts that I have. (Stickers going on to the car late next week) Most Wanted photo Edited April 11, 20195 yr by JackBloomer5 Stickers comment
April 11, 20195 yr Author 9 minutes ago, letsbuild said: The side panels look really flat. Is there a way to fix that? They are flat but there isn't much I can do to fix that. I had also thought of that and tried ways to fix it but I simply don't have the parts. Now that I think about it I could shorten the width of the side pods by a stud or two to make it seem more proportional, I'll see when I get home. Edited April 11, 20195 yr by JackBloomer5 Second Sentence
April 11, 20195 yr 23 minutes ago, JackBloomer5 said: They are flat but there isn't much I can do to fix that. I had also thought of that and tried ways to fix it but I simply don't have the parts. Now that I think about it I could shorten the width of the side pods by a stud or two to make it seem more proportional, I'll see when I get home. Okay, that's fair. Otherwise, your model looks awesome.
April 11, 20195 yr You seem to have set 42056. Part 18944 might be a good fit for the sides. Looks promising, following this thread with interest.
April 12, 20195 yr Author Thanks for the feedback, and now that I’m in the fine tuning stages of the model, I want to focus a little bit on the rear. The suspension ended up similar to the 42000, albeit unintentional, and I have several translucent red bricks, many 1x2 plates, several 2x2 bricks and two 1x4 bricks. I want to use these to make a rear brake light like in the real car but what I currently have looks kind of ugly and simply not great. Any ideas? I'll put picture of current design when I get home and work on it but I have been thinking about it for a couple days and I’m stuck. Edit: eventually a red light brick will take a place in that spot. Edited April 12, 20195 yr by JackBloomer5 Grammer
April 14, 20195 yr Author The model is completely done with the exception of stickers and pieces I won't get for a month and a half. I added rear view mirrors and overhauled the steering to make the steering wheel turn more within the cockpit, steering wheel is also sitting 1-2 studs higher. I also changed the rear light, not a true light yet, and I think it looks better. So this is it, no more changes will be made to the car and I do plan to publish instructions for it but that may take some time and lots of help (my computer is not very powerful).
April 19, 20195 yr Author Update: Started adding stickers. They are a little small but they make it look more or less like the actual car.
May 9, 20195 yr Author Unfortunately, there was a problem with the order and it never arrived. I emailed them and who knows what will happen. The most notable piece from that batch was the red light brick that I wanted to put in the rear of the vehicle. I put a picture here later of the model as it is now with stickers. Probably won't get my parts till late July or early August due to my current location. So yeah. By the way I did start my next model which is the Acura ARX-05 DPI.
