M2m Posted May 19, 2020 Posted May 19, 2020 I’m using the new parts in LDD on OSX / macOS and it works smoothly. There is LIF extractor on macOS in form of a python program. Quote
Takanuinuva Posted May 20, 2020 Posted May 20, 2020 (edited) 18 hours ago, jester94 said: Did you rename db.lif? Check that all .xml files are in in Primitives folder and .g files are in the the LOD0 folder If you mean the folder yes I did. If you mean the file. No I named it xxdb.lif Oh wait I think I see the problem. I downloaded the 64 bit version when I have the 32 bit version. Nope still didn't work. .xml files are in primatives and .g files are in LOD0 does the db.lif folder need to be in the same folder that library groups are? Edited May 20, 2020 by Takanuinuva Quote
The Mugbearer Posted May 20, 2020 Posted May 20, 2020 18 hours ago, jester94 said: Check that all .xml files are in in Primitives folder and .g files are in the the LOD0 folder How can I check? I dragged and dropped the entire Primitives folder into the "db" folder and told it to replace all the conflicting files. Don't think I can do any more than that? Quote
Takanuinuva Posted May 20, 2020 Posted May 20, 2020 Ok found out what the problem was. My antivirus was preventing the folders from being changed. That and I needed the 32bit version. Quote
Jason C. Hand Posted May 20, 2020 Posted May 20, 2020 10 hours ago, jester94 said: Added 50018 Weapon Pack Silly question: Is this real? Quote
Stephan Posted May 20, 2020 Posted May 20, 2020 16 minutes ago, Jason C. Hand said: Silly question: Is this real? Why wouldn't it be real? It is used in a lot of Batman sets. Quote
Jason C. Hand Posted May 20, 2020 Posted May 20, 2020 2 minutes ago, Stephan said: Why wouldn't it be real? It is used in a lot of Batman sets. I was curious because I saw no download url or whatnot. Quote
Stephan Posted May 20, 2020 Posted May 20, 2020 1 hour ago, Jason C. Hand said: I was curious because I saw no download url or whatnot. Parts pack will follow shortly. It contains a lot of parts ;) Quote
Cyberfounder Posted May 20, 2020 Posted May 20, 2020 17 hours ago, Stephan said: We don't know ? Hahaha, no problem. I sure someone will figure it out. Quote
Toitoine Posted May 20, 2020 Posted May 20, 2020 Thanks Jester94 & M2m for you answers but I don't understand how to proceed on OS X. Quote
Jason C. Hand Posted May 20, 2020 Posted May 20, 2020 6 hours ago, Stephan said: Parts pack will follow shortly. It contains a lot of parts ;) Ok, thank you. Quote
Stephan Posted May 20, 2020 Posted May 20, 2020 Parts pack 200520v1 is available for download. It includes 42 new or updated pieces with 10 multi-colorable ones. Quote
Jason C. Hand Posted May 20, 2020 Posted May 20, 2020 2 hours ago, Stephan said: Parts pack 200520v1 is available for download. It includes 42 new or updated pieces with 10 multi-colorable ones. Sweet, thanks! Quote
SylvainLS Posted May 20, 2020 Posted May 20, 2020 2 hours ago, Stephan said: Parts pack 200520v1 is available for download. It includes 42 new or updated pieces with 10 multi-colorable ones. 36036: underside is missing connectivity. 3671: typo in the list, it’s 367 for BL and LDraw, not 361. 18934, 20603, and 30329: why renumbering? why aren’t they modifications of 18932, 20601, 30327? (none are in LDraw anyway) Quote
jester Posted May 20, 2020 Posted May 20, 2020 (edited) 3 minutes ago, SylvainLS said: 36036: underside is missing connectivity. 18934, 20603, and 30329: why renumbering? why aren’t they modifications of 18932, 20601, 30327? (none are in LDraw anyway) 36036 - i'll take a look For others - LDD has wrong numbers, check Brickset for this parts Upd. 36036 corrected and reloaded on drive (@Stephan) Edited May 20, 2020 by jester Quote
SylvainLS Posted May 20, 2020 Posted May 20, 2020 14 minutes ago, jester said: LDD has wrong numbers, check Brickset for this parts Yes, it happens with LDD. It’s just that it makes two almost identical parts in LDD (one colourable with the correct number, the other not). 2 minutes ago, jester said: Almost 3 hours of coding Where one finds their fun is their business Quote
Stephan Posted May 20, 2020 Posted May 20, 2020 23 minutes ago, jester said: Upd. 36036 corrected and reloaded on drive Will be added in 200520v2. Quote
jester Posted May 20, 2020 Posted May 20, 2020 1 minute ago, SylvainLS said: Yes, it happens with LDD. It’s just that it makes two almost identical parts in LDD (one colourable with the correct number, the other not). If you'd like, you can delete the old one (not colourable) 11 minutes ago, Stephan said: Will be added in 200520v2. i'll add some new parts Quote
SylvainLS Posted May 20, 2020 Posted May 20, 2020 15 minutes ago, jester said: If you'd like, you can delete the old one (not colourable) I was thinking of the less savvy users. Quote
Takanuinuva Posted May 20, 2020 Posted May 20, 2020 20603 —— Minifigure, Headgear Extended Head with Goggles and Messy Hair Isn't fixed for me. It is still only 1 color Also would it be possible to fix the menus for decorations? Like zooming in on them to see them better? Quote
jester Posted May 20, 2020 Posted May 20, 2020 Just now, Takanuinuva said: 20603 —— Minifigure, Headgear Extended Head with Goggles and Messy Hair Isn't fixed for me. It is still only 1 color Also would it be possible to fix the menus for decorations? Like zooming in on them to see them better? I don't think it's possible For 20603 - I don't know what's the problem Because I uploaded all files (20603.xml 20603.g 20603.g1 20603.g2) Quote
Takanuinuva Posted May 20, 2020 Posted May 20, 2020 (edited) Maybe it's cause I don't have the latest one? I don't yet have the batman accessory pack. Waiting on a PM for that. Yea don't have the latest one. Missing 20603. Edited May 20, 2020 by Takanuinuva Quote
