BrokenEye Posted December 22, 2023 Posted December 22, 2023 Hey, does anyone have a physical minifigure roller skate (11253) at home? I've got a hunch that the little holes in the hubs of the wheels might work as a connection for a "headgear accessory" pin, but I've got no way to check if its legal on my end. Quote
Stephan Posted December 28, 2023 Posted December 28, 2023 On 12/22/2023 at 6:17 AM, BrokenEye said: Hey, does anyone have a physical minifigure roller skate (11253) at home? I've got a hunch that the little holes in the hubs of the wheels might work as a connection for a "headgear accessory" pin, but I've got no way to check if its legal on my end. The easiest way to check this is by using Mecabricks. Those parts are super accurate to life. Quote
Takanuinuva Posted December 29, 2023 Posted December 29, 2023 On 12/21/2023 at 10:17 PM, BrokenEye said: Hey, does anyone have a physical minifigure roller skate (11253) at home? I've got a hunch that the little holes in the hubs of the wheels might work as a connection for a "headgear accessory" pin, but I've got no way to check if its legal on my end. Took a look. Said holes aren't deep enough for a headgear pin. Quote
BrokenEye Posted January 1, 2024 Posted January 1, 2024 On 12/29/2023 at 11:29 AM, Takanuinuva said: Took a look. Said holes aren't deep enough for a headgear pin. Well, it was worth a shot Quote
suenkachun Posted January 11, 2024 Posted January 11, 2024 On 11/26/2023 at 8:04 PM, suenkachun said: Since a few LDD Updates ago, I have put together a comprehensive PDF Guide regarding LDD Decoration Sizes. The aim was quite simple: to help everyone design the most accurate Decoration PNG images of common regular Bricks for use in LDD, whether they are custom creations or official images to be submitted here for future LDD updates. Simply use the relevant details when designing Decorations for any listed Brick and they will fit onto the relevant Brick surfaces perfectly, with each new LDD Update being released I check all of the newly decoratable Bricks and expand the PDF Guide with more Bricks under existing categories and brand-new entries. After a whole week of studying the latest LDD Update and the various UV Mapping PNG Images in the “UV maps” folder, I have finally completed the new version of the PDF Guide which can be downloaded here (same link as before). Stepping into 2024, I have had a few moments to revisit the comprehensive PDF Guide regarding LDD Decoration Sizes I wrote a while back. Last updated in late November 2023, that version of the Guide added new Bricks, updated UV Mappings and most importantly supplied selected entries with UV Mappings created as Vector Images (SVG) for exact Pixel measurements and better curves. Update contents this time include adding information regarding the UV Mapping of “Part 6179 Plate 4×4 W. 4 Knobs” which I finally figured out recently, rebuilding the two main tables to improve the overall layout and minor text fixes here and there. In addition, as mentioned near the end of the Guide, “Someone on DeviantArt kindly posted seven graphs regarding LEGO Slope (and Plate) Dimensions”, not realising before I could login and download the full versions for free I only relied on the full-size previews which meant one key measurement was completely omitted: the diameter of a LEGO Stud which is 0.48 cm. With this measurement obtained three Brick Entries are now updated with Pixel-perfect measurements since the enlarged Studs are now directly scaled up from the original, their new larger diameter being 307.2 Pixels but rounded up to 308 Pixels for the final PNG Image after output. One last change is updating the Vector UV Mapping of Part 3001 Brick 2×4 so that the four side surfaces have a precise Height of 307.2 Pixels after scaling up and the four vertical gaps modified to accommodate these changes, all adjusted accordingly in the final PNG Image after output. The latest version of the PDF Guide can be downloaded here (same link as before), hopefully it will continue to be useful for all and thanks for stopping by again. Quote
Stephan Posted January 20, 2024 Posted January 20, 2024 (edited) Custom LDD Update 20240120 has been released! This update includes 48 new parts, 8 updated original parts, 11 updated custom parts, 81 pre-colored/pre-decorated parts, and 4 new colors. See the update on Eurobricks, or on CustomLDDUpdates.com. Patrons got 20-day early access to this update. Interested in becoming a Patron? See my Patreon. Edited January 20, 2024 by Stephan Quote
suenkachun Posted January 20, 2024 Posted January 20, 2024 (edited) 3 hours ago, Stephan said: Custom LDD Update 20240120 has been released! This update includes 48 new parts, 8 updated original parts, 11 updated custom parts, 81 pre-colored/pre-decorated parts, and 4 new colors. See the update on Eurobricks, or on CustomLDDUpdates.com. Patrons got 20-day early access to this update. Interested in becoming a Patron? See my Patreon. Thanks for the second LDD Update in 2024! Just installed the “Complete LDD update package” or “LDD New Parts.rar” from Dropbox and it seems like this update was not incorporated into those complete files, unless new updates will be separate from the complete files from now on. This explains why I was unable to locate some of the new content, will report back for any issues after I install the “20240120.rar” file, sorry for the confusion in my first draft of this post. Anyways, during this period I manually updated the two current Colour Name Files and the German version has been further improved. Other than “Material155 Tr. Grün mit Glitzernd” changed to “Material155 Tr. Grün Mit Glitzernd”, there are currently 35 LDD Colours containing “-ish” (Reddish, Yellowish or Bluish) in their name but only five Colour Names with “Rötlich” (Reddish) in the German version. The rest do not use “-lich” (“-ish”) at all, so updated the German names of the remaining 30 Colours to make sure “-lich” (“-ish”) is always included (Rötlich=Reddish, Gelblich=Yellowish, Blaulich=Bluish). Hopefully, these fixes can be incorporated into the next LDD Update too. Edited January 20, 2024 by suenkachun Quote
suenkachun Posted January 20, 2024 Posted January 20, 2024 (edited) 4 hours ago, Stephan said: This update includes 48 new parts, 8 updated original parts, 11 updated custom parts, 81 pre-colored/pre-decorated parts, and 4 new colors. Brickwise the update seems fine so far, but the latest “240120.lxf” file is missing the following three highlighted Decorations after I installed the “20240120.rar” file, it says one Brick removed so probably related to this. P.S., earlier I submitted the full set of Warning Tile Decorations here, just noticed that the 1×6 version was included in this update, so decided to quickly regenerate the Decoration from my base files using the updated UV Mapping of this Flat Tile. The following full version at 1024px times 1024px should be the most accurate so this can replace the version supplied in the latest update if necessary, the original squashed 1×4 Warning Tile Decoration used full Black (RGB: 0/0/0) instead of LDD Black (RGB: 2742/52) which is why all of my new variants use full Black too unlike the version supplied with the latest update (I can still change mine if this one does use LDD Black). Hoping to see the rest added at some point too, also please replace the existing 24075 and 58858 with the new versions included in that post. Thanks. Edited January 20, 2024 by suenkachun Quote
PicnicBasketSam Posted January 21, 2024 Posted January 21, 2024 Tested the new parts out, looking great so far; I was only able to find 2 connectivity problems - nothing can be attached to the antistuds on 5066, and no Technic wheel hub of any kind can be attached to 100943. Part 3803 isn't in the files; that's the one that gets removed when opening the .lxf containing all the new pieces. Finally, there's a serious collision error with 5405, it cannot mesh with the regular Technic knob wheel, defeating the piece's whole reason for existence. Quote
Stephan Posted January 21, 2024 Posted January 21, 2024 (edited) 6 hours ago, PicnicBasketSam said: Tested the new parts out, looking great so far; I was only able to find 2 connectivity problems - nothing can be attached to the antistuds on 5066, and no Technic wheel hub of any kind can be attached to 100943. Part 3803 isn't in the files; that's the one that gets removed when opening the .lxf containing all the new pieces. Finally, there's a serious collision error with 5405, it cannot mesh with the regular Technic knob wheel, defeating the piece's whole reason for existence. This should all be fixed now. 13 hours ago, suenkachun said: missing the following three highlighted Decorations This is fixed now. 14 hours ago, suenkachun said: Anyways, during this period I manually updated the two current Colour Name Files and the German version has been further improved. Other than “Material155 Tr. Grün mit Glitzernd” changed to “Material155 Tr. Grün Mit Glitzernd”, there are currently 35 LDD Colours containing “-ish” (Reddish, Yellowish or Bluish) in their name but only five Colour Names with “Rötlich” (Reddish) in the German version. The rest do not use “-lich” (“-ish”) at all, so updated the German names of the remaining 30 Colours to make sure “-lich” (“-ish”) is always included (Rötlich=Reddish, Gelblich=Yellowish, Blaulich=Bluish) Since the upcoming update contains 49 new colors, this will be updated in the upcoming update. 13 hours ago, suenkachun said: P.S., earlier I submitted the full set of Warning Tile Decorations here, just noticed that the 1×6 version was included in this update, so decided to quickly regenerate the Decoration from my base files using the updated UV Mapping of this Flat Tile. The following full version at 1024px times 1024px should be the most accurate so this can replace the version supplied in the latest update if necessary, the original squashed 1×4 Warning Tile Decoration used full Black (RGB: 0/0/0) instead of LDD Black (RGB: 2742/52) which is why all of my new variants use full Black too unlike the version supplied with the latest update (I can still change mine if this one does use LDD Black). Hoping to see the rest added at some point too, also please replace the existing 24075 and 58858 with the new versions included in that post. Sorry, I still have to look into this more detailed. You are doing an amazing job, I just need to allocate time to check and incorporate this. Edited January 21, 2024 by Stephan typo Quote
Takanuinuva Posted January 21, 2024 Posted January 21, 2024 Curious if/when the SCCBS parts will get added to LDD Quote
suenkachun Posted January 22, 2024 Posted January 22, 2024 On 1/20/2024 at 11:55 PM, Stephan said: This update includes 48 new parts, 8 updated original parts, 11 updated custom parts, 81 pre-colored/pre-decorated parts, and 4 new colors. Just noticed that this issue linked below seems to not have been fixed, at least the latest “240120.lxf” file can now be opened completely error-free. Thanks. Quote
mon-o-mat Posted January 22, 2024 Posted January 22, 2024 Is it normal that I had to manually rewrite the LDDExtended.lif to get the new colours in my palette? Quote
SylvainLS Posted January 22, 2024 Posted January 22, 2024 45 minutes ago, mon-o-mat said: Is it normal that I had to manually rewrite the LDDExtended.lif to get the new colours in my palette? Yes and no. LDD reads everything that’s in the directory, files and subdirectories. So you just needed to move the older LDDExtended.lif away. Otherwise, it’s you and your luck which info LDD’s reading last: the old lif file or the new files in the extracted folder. Quote
Stephan Posted January 23, 2024 Posted January 23, 2024 (edited) On 1/22/2024 at 12:35 AM, Takanuinuva said: Curious if/when the SCCBS parts will get added to LDD --What does the 'S' stand for here?-- Nevermind. System CCBS. The new 1x2 Brick will be in the next update. Which parts are you missing? 23 hours ago, suenkachun said: Just noticed that this issue linked below seems to not have been fixed, Oops, I checked this one and didn't find an error on my side, but I didn't include the files... will be next update. Edited January 23, 2024 by Stephan Quote
mon-o-mat Posted January 23, 2024 Posted January 23, 2024 19 hours ago, SylvainLS said: Yes and no. LDD reads everything that’s in the directory, files and subdirectories. So you just needed to move the older LDDExtended.lif away. Otherwise, it’s you and your luck which info LDD’s reading last: the old lif file or the new files in the extracted folder. Thanks, I already wondered why there were two very similiar files xD Quote
Takanuinuva Posted January 23, 2024 Posted January 23, 2024 5 hours ago, Stephan said: --What does the 'S' stand for here?-- Nevermind. System CCBS. The new 1x2 Brick will be in the next update. Which parts are you missing? The armor shell and chest piece Quote
Stephan Posted January 24, 2024 Posted January 24, 2024 21 hours ago, shitmaster3001 said: would be neat if all the pieces needed to build the toa mata are inculded At some point they will be. Quote
suenkachun Posted January 24, 2024 Posted January 24, 2024 On 1/11/2024 at 9:11 AM, suenkachun said: Stepping into 2024, I have had a few moments to revisit the comprehensive PDF Guide regarding LDD Decoration Sizes I wrote a while back. Last updated in late November 2023, that version of the Guide added new Bricks, updated UV Mappings and most importantly supplied selected entries with UV Mappings created as Vector Images (SVG) for exact Pixel measurements and better curves. Since the release of the latest LDD Update, the comprehensive PDF Guide regarding LDD Decoration Sizes must be updated again around two weeks later. The most important change to the Guide is due to the UV Mapping of Part 6636 Flat Tile 1×6 being updated, so this Brick now requires its own entry after the two tables. Since the page arrangements became slightly harder to manage after adding this, the tables were further adjusted and improved, then most of the existing entries were simplified into single paragraphs instead of multiple steps, selected ones rearranged and all sub-headings now start with “How To” instead of “Steps To”. Part 3567 Tile, 2×2, Inv., Round and Part 3395 Flat Tile 2×4, Inv. are newly mentioned within existing entries since they use the same UV Mappings, while Part 4515 Ramp 6×8 is now an independent entry, two more new entries being Part 4569 Roof Tile 1×6×1, No. 1 and Part 6178 Plate 6×12 W. 22 Knobs supplied with a Vector UV Mapping. The latest version of the PDF Guide can be downloaded here (same link as before), hopefully it will continue to be useful for all and thanks for stopping by again. Quote
Jason C. Hand Posted January 26, 2024 Posted January 26, 2024 Good evening, friends! Hope you have been well. Just wanted to share my latest adventures in LDD. I was able to import the following four hairpieces into LDD this week. I used my Hermione minifig to model the wigs. Other than that, she is complete! Please feel free to check out the photos at your leisure. Quote
Yangster Posted February 5, 2024 Posted February 5, 2024 (edited) @Stephan Part 27925 bottom surface error Edited February 5, 2024 by Yangster Quote
Yangster Posted February 5, 2024 Posted February 5, 2024 (edited) @Stephan Apparently didn't take me very long to figure out how to map decorations lol so I made these decor for the dots alphabet pack (77486) but basically they just a bunch of 98138 with prints. I made 512x512 as per other existing 98138 decorations. Please let me know if they are good or not. Download them here Edited February 5, 2024 by Yangster Quote
Mobieus69 Posted February 9, 2024 Posted February 9, 2024 (edited) Question for @Stephan or anyone else who knows; what program do you guys use to actually edit and add part surfaces for decorations (mapping, number of surfaces, etc.)? Edited February 9, 2024 by Mobieus69 Quote
Mobieus69 Posted February 10, 2024 Posted February 10, 2024 4 hours ago, shitmaster3001 said: i use brick editior Can you use that to actually change and manipulate the meshes for decoration surfaces? Quote
Stephan Posted February 10, 2024 Posted February 10, 2024 On 2/9/2024 at 11:03 AM, Mobieus69 said: Question for @Stephan or anyone else who knows; what program do you guys use to actually edit and add part surfaces for decorations (mapping, number of surfaces, etc.)? Blender and after that Brick Studio. Quote
