The Mugbearer Posted February 10, 2021 Posted February 10, 2021 Spoiler 35480 PL. ROUND 1x2 W/THROUGHG. HOLE lacks connectivity for its middle pip, not allowing me to attach anything with a hollow stud to it. Quote
Stephan Posted February 10, 2021 Posted February 10, 2021 55 minutes ago, The Mugbearer said: 35480 PL. ROUND 1x2 W/THROUGHG. HOLE lacks connectivity for its middle pip, not allowing me to attach anything with a hollow stud to it. I have to check this, but I think it was fixed in the last parts pack. If not it will be released in the next pack and is already available in my Pre-Release Github. Quote
Stephan Posted February 10, 2021 Posted February 10, 2021 1 hour ago, The Mugbearer said: 35480 PL. ROUND 1x2 W/THROUGHG. HOLE lacks connectivity for its middle pip, not allowing me to attach anything with a hollow stud to it. It can be found here. Quote
The Mugbearer Posted February 10, 2021 Posted February 10, 2021 (edited) 3 hours ago, Stephan said: It can be found here. Splendid! Everything works! EDIT: Can I request x1192px1 Technic, Axle Connector 2 x 3 with Ball Joint Socket and Axle Socket with Light Bluish Gray Rubber Insert and its variant with black rubber insert to be added to LDD? Stud.Io has those so it shouldn't be a problem to extract and put in, right? Edited February 11, 2021 by The Mugbearer Added a part request. Quote
Stephan Posted February 11, 2021 Posted February 11, 2021 14 hours ago, The Mugbearer said: Stud.Io has those so it shouldn't be a problem to extract and put in, right? Well, not that easy, but it shouldn't be a problem :) Quote
M2m Posted February 11, 2021 Posted February 11, 2021 (edited) 16 hours ago, The Mugbearer said: Splendid! Everything works! EDIT: Can I request x1192px1 Technic, Axle Connector 2 x 3 with Ball Joint Socket and Axle Socket with Light Bluish Gray Rubber Insert and its variant with black rubber insert to be added to LDD? Stud.Io has those so it shouldn't be a problem to extract and put in, right? 1 hour ago, Stephan said: Well, not that easy, but it shouldn't be a problem :) Is this part 90611or 90612 in the Unity pack ? It looks to me, but I can't verify right now. Edited February 11, 2021 by M2m Quote
Stephan Posted February 11, 2021 Posted February 11, 2021 1 hour ago, M2m said: Is this part 90611or 90612 in the Unity pack ? It looks to me, but I can't verify right now. These two parts are different parts. Quote
Stephan Posted February 11, 2021 Posted February 11, 2021 On 2/8/2021 at 11:27 AM, suenkachun said: I guess the correct collision boundaries need to be added to this Brick which prevents any incorrect Bricks placed beside it Fixed! Quote
Stephan Posted February 12, 2021 Posted February 12, 2021 14 hours ago, Stephan said: Well, not that easy, but it shouldn't be a problem :) I have added it and will add the parts to my Pre-Release Github this afternoon. Quote
The Mugbearer Posted February 12, 2021 Posted February 12, 2021 24 minutes ago, Stephan said: I have added it and will add the parts to my Pre-Release Github this afternoon. Thanks alot! Quote
syclone Posted February 12, 2021 Posted February 12, 2021 (edited) Good day, any chance to add 2986? After reading this topic had fun messing around (added a collision box&connections) but copied the bottom studs connection from 3003 and top stud from 30151, therefore on the bottom there's an impossible connection in the middle of the brick. The model itself is from Ldraw library, exported via LDView and then resaved in Blender (for some reason it wouldn't render correctly in LDD unless viewed from under the "baseplate"). In case someone finds it useful: download Huge thanks to everyone involved in keeping LDD alive! Edited February 12, 2021 by syclone Quote
M2m Posted February 13, 2021 Posted February 13, 2021 On 2/12/2021 at 1:20 AM, Stephan said: These two parts are different parts. You are right. I would however suggest to align to these parts, as in case Lego ever release this part it is likely to be placed similar to these 2 parts. Quote
Stephan Posted February 13, 2021 Posted February 13, 2021 5 hours ago, M2m said: You are right. I would however suggest to align to these parts, as in case Lego ever release this part it is likely to be placed similar to these 2 parts. I used the collision data from one of these parts, so the new part is alligned equally :) Quote
Anton Posted February 13, 2021 Posted February 13, 2021 (edited) I am unable to achieve success following the steps in the "Accessing the new parts" section. Could you please make a clearer instruction "for an idiot"? So far, I've read this section like "Unpack files from "library" to the "LOD0" folder. Edited February 13, 2021 by Anton Quote
M2m Posted February 15, 2021 Posted February 15, 2021 On 2/14/2021 at 3:32 AM, Anton said: I am unable to achieve success following the steps in the "Accessing the new parts" section. Could you please make a clearer instruction "for an idiot"? So far, I've read this section like "Unpack files from "library" to the "LOD0" folder. I made a video Quote
Zerobricks Posted February 15, 2021 Posted February 15, 2021 I would kindly like to ask for Power Functions and Powered Up LED lights with correct plugs: 61930c01: 22168c01 Thank you Quote
Stephan Posted February 15, 2021 Posted February 15, 2021 3 hours ago, Zerobricks said: I would kindly like to ask for Power Functions and Powered Up LED lights with correct plugs: We might be able to add them if the parts are available in LDraw or the Unity MicroGame. Quote
M2m Posted February 16, 2021 Posted February 16, 2021 7 hours ago, Stephan said: We might be able to add them if the parts are available in LDraw or the Unity MicroGame. These numbers are not part of Unity MicroGame. They might have different numbers but I don't remember having seen parts like those. Quote
Stephan Posted February 17, 2021 Posted February 17, 2021 I am still working on new parts and prints! I am currently building NINJAGO City Gardens and I am adding the new parts and printed non-minifigure parts as well. After I have finished the set, I will create a new parts pack. In the mean time, pre-release parts are available from my Pre-Release Github. Quote
Jason C. Hand Posted February 20, 2021 Posted February 20, 2021 May I add another suggestion? #37697, Minifig Hair, Mid-Length and Wavy with Bangs Quote
Eggyslav Posted February 22, 2021 Posted February 22, 2021 The new flight mask piece (39796) should have the same collision as beard pieces, so the head piece could "sink" into it. Quote
C3technic Posted February 25, 2021 Posted February 25, 2021 On 2/15/2021 at 7:22 AM, M2m said: I made a video It works perfectly, but now how to make the new db.lif file to use it in Blueprint? Quote
Graham-S Posted February 27, 2021 Posted February 27, 2021 There's a tool to re-pack an extracted set of files back as a db.lif file mentioned in this earlier post . . . https://www.eurobricks.com/forum/index.php?/forums/topic/170286-custom-ldd-bricks-and-fixes/&do=findComment&comment=3340006 Quote
