BrokenEye Posted May 11, 2021 Posted May 11, 2021 3 hours ago, M2m said: Good question. It was part of the Lego Unity pack - so its official from Lego. But on the other hand I can't seem to find a set or real version of it. Do sets ever get canceled? Maybe it's the LEGO brick equivalent of the character whose only scene got cut from the finished film. Quote
suenkachun Posted May 11, 2021 Posted May 11, 2021 On 5/10/2021 at 4:33 AM, Stephan said: All parts are fixed now! I reinstalled the latest files and all parts are now working fine. However, there still seems to be a problem with a few Decorations. As shown here, the three NASA Decorations are still not displayed correctly despite support already added to the DecorationMapping.xml file and are all present in the corresponding .lxfml file. I then tried using the Decoration Tool on Part 76798 and nothing showed up. Also, I compared the latest 21051 file with the Decorated Parts 21051 Image from Bricksafe and noticed that the four Part 60601 should all be decorated, but only the lower two are currently decorated and when using the Decoration Tool the top two Decorations seem to be missing. Keep up the good work! Quote
M2m Posted May 11, 2021 Posted May 11, 2021 20 minutes ago, BrokenEye said: Do sets ever get canceled? Maybe it's the LEGO brick equivalent of the character whose only scene got cut from the finished film. It might be more a "digital only" part maybe or a part which they have in the pipeline but not released yet or a cut character as you say. An example of a digital only part is the Bantha of which no physical version exists as of today - at least not officially released from LEGO. Quote
Stephan Posted May 11, 2021 Posted May 11, 2021 1 hour ago, suenkachun said: As shown here, the three NASA Decorations are still not displayed correctly despite support already added to the DecorationMapping.xml file and are all present in the corresponding .lxfml fil Do you also have the latest .g, .g1 and .g2 files? Quote
Kingsidorak Posted May 11, 2021 Posted May 11, 2021 (edited) Hello everyone, I am Kingsidorak, I make models for custom and official parts from scratch. I'm doing a pack for Stud.io replacing a ton of models as well as adding in a ton of models we don't yet have digitally. I was wondering if anyone could give me a bit of an explainer on how porting models to LDD works, so I may judge if it's something I'd want to do. Though it's outdated, here is an example of some of my more so recent work, rendered using Stud.io Edited May 11, 2021 by Kingsidorak Quote
suenkachun Posted May 11, 2021 Posted May 11, 2021 (edited) 34 minutes ago, Stephan said: Do you also have the latest .g, .g1 and .g2 files? I simply downloaded the latest Primitives.rar release file from Dropbox and copied everything over directly. I only had to manually update the DecorationMapping.xml file to preserve my own custom Decorations, but I made sure that everything new was copied over. Unless something went wrong here I think I did everything right, but the two other Part 60601 Decorations are definitely missing. EDIT: Apparently the version on Dropbox is missing the latest .g, .g1 and .g2 files for the three NASA Decorations, but the GitHub version finally worked. However, the two other Part 60601 Decorations are also missing on the GitHub version as well. EDIT 2: I found the issue regarding the two missing Part 60601 Decorations. All four Decorations are correctly applied in the DecorationMapping.xml file, but the Decoration PNG files for "24657" and "24414" are missing from the latest "Decorations" folder on both release platforms. In summary, the Dropbox release needs to be updated with the latest .g, .g1 and .g2 files for the three NASA Decorations, then both the Dropbox version and the GitHub version need to be updated with the missing "24657" and "24414" Decoration PNG files. Thanks in advance! Edited May 11, 2021 by suenkachun Quote
Stephan Posted May 11, 2021 Posted May 11, 2021 The decorations are added. The problem with the skirt is fixed. It was mainly an issue with the heigth of the 2nd attachment point of the hip parts. Download 16706, 41879, 3815 and 65753. Quote
suenkachun Posted May 11, 2021 Posted May 11, 2021 23 minutes ago, Stephan said: The decorations are added. The problem with the skirt is fixed. It was mainly an issue with the heigth of the 2nd attachment point of the hip parts. Download 16706, 41879, 3815 and 65753. Thanks a bunch, everything is working perfectly now! Quote
The Mugbearer Posted May 12, 2021 Posted May 12, 2021 Question to the knowing: are stud to technic pin hole connections considered legal or not? Quote
SylvainLS Posted May 12, 2021 Posted May 12, 2021 Yes, but only one stud (e.g., one 1x1 plate in one hole, not a 1x2 plate in two holes), and beware that the Technic holes are higher than a side stud, so there’s alignment problems (that means nothing should go past the technic brick and sit on the parts that uses the technic hole (“overhanging”) or that you shouldn’t mix technic holes + half pins and side studs.). Search for the PDF Stressing the Elements by Jamie Berard. Quote
Stephan Posted May 13, 2021 Posted May 13, 2021 (edited) On 5/11/2021 at 11:14 AM, Kingsidorak said: I was wondering if anyone could give me a bit of an explainer on how porting models to LDD works, so I may judge if it's something I'd want to do. You can import your *.dat file in Brick Studio and add colissions there. The only thing left to add after that is connections. That's it in a nut shell. Could someone with a bit more Blender abilities help me with these two parts: I have problems with the outlines. The parts should consist of an upper and a lower section and should have the separation line between those sections. If you think you can assist, please send me a message and I will send you the files I have for these parts. EDIT: fixed, thanks to @polymaker Edited May 13, 2021 by Stephan Quote
The Mugbearer Posted May 13, 2021 Posted May 13, 2021 15 hours ago, SylvainLS said: Yes, but only one stud (e.g., one 1x1 plate in one hole, not a 1x2 plate in two holes), and beware that the Technic holes are higher than a side stud, so there’s alignment problems (that means nothing should go past the technic brick and sit on the parts that uses the technic hole (“overhanging”) or that you shouldn’t mix technic holes + half pins and side studs.). Search for the PDF Stressing the Elements by Jamie Berard. So, that includes hollow studs. right? So jumpers, in theory, can be attached to a technic pin hole? I am asking because there's apparently a lot of that connectivity missing for multiple bricks with pin holes. Quote
SylvainLS Posted May 13, 2021 Posted May 13, 2021 15 minutes ago, The Mugbearer said: So, that includes hollow studs. right? So jumpers, in theory, can be attached to a technic pin hole? Yes. Quote
Stephan Posted May 13, 2021 Posted May 13, 2021 (edited) The new 1x5 Plate is already available for download from my Github. Search for 78329. Edited May 15, 2021 by Stephan Quote
The Mugbearer Posted May 13, 2021 Posted May 13, 2021 4 hours ago, Stephan said: The new 1x5 Plate is already available for download from my Github. Search for 18329. YO THAT WAS QUICK Quote
BrokenEye Posted May 13, 2021 Posted May 13, 2021 On 5/11/2021 at 9:18 AM, Stephan said: The decorations are added. The problem with the skirt is fixed. It was mainly an issue with the heigth of the 2nd attachment point of the hip parts. Download 16706, 41879, 3815 and 65753. Excellent, thanks. Quote
BrokenEye Posted May 13, 2021 Posted May 13, 2021 Would it be at all possible to get a version of MINI UPPER P. W/ARM COR.KNOB that's laterally flipped so that the robot arm is on the left rather than the right, or is that against the rules for not being a real part? Quote
Stephan Posted May 14, 2021 Posted May 14, 2021 4 hours ago, BrokenEye said: Would it be at all possible to get a version of MINI UPPER P. W/ARM COR.KNOB that's laterally flipped so that the robot arm is on the left rather than the right The robot arm on the left seems to appear in real life as well. I'll add it to my list. Quote
BrokenEye Posted May 14, 2021 Posted May 14, 2021 6 hours ago, Stephan said: The robot arm on the left seems to appear in real life as well. I'll add it to my list. Thanks Quote
Stephan Posted May 15, 2021 Posted May 15, 2021 On 5/13/2021 at 9:58 PM, The Mugbearer said: YO THAT WAS QUICK Please delete the 18329 files (xml and g) and download 78329 instead. Quote
Takanuinuva Posted May 16, 2021 Posted May 16, 2021 https://www.bricklink.com/v2/catalog/catalogitem.page?P=bb1170c01&idColor=13#T=C&C=13 Would it be possible to add this part? I'm working on improving the hydro mech and having the proper canopy piece would help greatly Quote
Stephan Posted May 16, 2021 Posted May 16, 2021 I think you are a bit too quick with that part. It is brand new and there is no 3D model available yet. Quote
Takanuinuva Posted May 16, 2021 Posted May 16, 2021 13 hours ago, Stephan said: I think you are a bit too quick with that part. It is brand new and there is no 3D model available yet. Gotcha. Guess I assumed these were made from scratch. Thanks for clarifying. Quote
Oliver 79 Posted May 16, 2021 Posted May 16, 2021 (edited) Message deleted. Sorry! Edited May 16, 2021 by Oliver 79 Quote
Takanuinuva Posted May 16, 2021 Posted May 16, 2021 On 5/13/2021 at 9:12 AM, Stephan said: The new 1x5 Plate is already available for download from my Github. Search for 78329. How do I download it? Quote
