Mechbuilds Posted March 21, 2019 Posted March 21, 2019 Hello! I need a tractor coupler that has two functions, the coupler arms go up and down, and there is an shaft in the middle for attachments. The problem is that the coupler + motors unit can only be 9 studs wide. I will be using 2 medium motors for this function. Can somebody help me with a compact and simple unit? Quote
Johnny1360 Posted March 21, 2019 Posted March 21, 2019 Are you talking about a standard 3 point hitch as is found on the back of most tractors? Quote
Maaboo the Witch Posted March 21, 2019 Posted March 21, 2019 Does one motor drive the hitch lift and another drive the shaft? Quote
Mechbuilds Posted March 21, 2019 Author Posted March 21, 2019 I built this system for testing.. It seems to fit barely after attaching the two M motors onto my current moc. I have one stud per side free room for a strong connection.. I accidentally just stumbled on this moc when trying to google lego tractor hitches. Quote
hpil Posted March 22, 2019 Posted March 22, 2019 Depends on how realistic you want it. For best realism, a 4 bar linkage small Las arranged off vertical with the driven end at the bottom, pushing up on a link which in lifts the arms up and down, but this would only give you 3L for the support frame and pto since the mini LAs are each 3L wide. @TeamThrifty's Claas Axion is a nice example but too wide for for your needs. You could use mini LAs directly between the structure and lift arms, at a 45 degree angle and the driven end at the top - like a tractor front linkage. @I_Igor's Fastrac has this, only 7L wide with motors further back in the chassis. Page 10 of this thread should give you some ideas: Your best bet for realism might be @kennywest's mf1250 - that is 9L wide and uses a worm gear to dive a linkage, but a mini LA could also do the same job, possibly more compact. Quote
