April 13, 20195 yr Here is the large actuator I designed awhile ago. I dont know if it will be helpful for you.
April 13, 20195 yr Author So, new changes are ready: The last time the front part was empty inside, there was only a frame. Now all the mechanisms are installed and ready for connection with the rear part. Also added a few external decorative parts. I could not make the front bumper like the original, which I would have liked. So while I changed it. Probably in the future I will change it. And a few photos of the inside: Starting the second half
April 13, 20195 yr Those weird angles in chassis will cause problems. Friction and similiar things will appear, have you tried straight frame, like this one? Edited April 13, 20195 yr by M_longer
April 13, 20195 yr Author 31 minutes ago, M_longer said: Those weird angles in chassis will cause problems. Friction and similiar things will appear, have you tried straight frame, like this one? I tried to repeat the outline of the original: Only external elements are fastened at such angles. All parts of gears and shafts are connected at a 90 degree angle. I already connected the motor, everything works correctly. But if something goes wrong, of course I will fix it. But what I worry about now - is the remaining amount of red parts) Edited April 13, 20195 yr by Akassin
September 29, 20195 yr Hey, How its going. Long time no updated, I hope see this model soon !! Edited September 29, 20195 yr by delta21
January 29, 20205 yr On 09/04/2019 at 16:12, Akassin said: Assassin, Tout dabord bonjour à toi. Cela fait maintenant plusieurs jours que j'essai de reproduire une chargeuse forestière en lego et je viens de tombé sur ton impressionnant moc. Je le trouves sublimes et tellement proche de la réalité que j'aimerai m'en inspiré pour faire le miens si tu n'y vois pas d'inconvénients. Si tu es d'accord penses qu'il serait possible de mettre quelques photos supplémentaires au vu du montage complexe que tu as du accomplir, c'est en outre difficile a reproduire avec une photo. Avec l'espérance que tu puisse me repondre favorablement, une bonne continuation a toi.
