Rustinidiel Posted May 19, 2019 Posted May 19, 2019 (edited) Hi all, this is my creation for the Landspeeder contest.. His name is U8-3R and is not only a speeder driven by a droid.. the speeder itself is the droid and the robotic torso is mounted and connected by a wire... is a hybrid fusion by a machine with... another machine.... this speeder was created to have an automatic transport system during the Empire era and can be used by officers and troops for reach various location and base... but it can allow the "touristic" function and the piblic transport... U8-3R by Rusty B. U8-3R by Rusty B. The shape is like a sidecar, with a main speederbike driven by the mechanical droid torso, and the passenger cockpit with an openable glass dome.. there are two laser cannon for protect the passengers and an headlight.. an ntenna on the back for data transmission and the green light for show the speeder's aviability U8-3R by Rusty B. the glass dome can be opened and inside there are two confortable seats for passengers U8-3R by Rusty B. the space inside the dome is enough to fit two minifig with hat or helmet and the glass easly slide from open to close to open U8-3R by Rusty B. next to the pilot droid there is an holographic control screen and inside the passenger cockpit there is an holographic Emperor avatar as interactive tourist guide U8-3R by Rusty B. the dome can be closed with inside the two minifig and the Emperor hologram activated U8-3R by Rusty B. behind the laser cannons there are the computers and they are the brain of the entire speeder... the droid torso is only an avatar to allow the use of mechanical function of the speeder because the speeder was created for a human use and adapted with a droid brain afterward U8-3R by Rusty B. the holographic control screen show a map or data about passengers U8-3R by Rusty B. behind the seats there are space for the passengers baggage, like a suitcase or blaster rifle U8-3R by Rusty B. U8-3R by Rusty B. the holographic Emperor avatar let the passengers to have communication with the imperial bases or can be used as a virtual assistant or touristic guide U8-3R by Rusty B. U8-3R by Rusty B. U8-3R by Rusty B. the passenger seats can be reclined to access to the baggage space the render of LDD is not perfect with colors... the main body is in metallic silver and the exhaust of the speeder is in flat silver and the flexible hose in in light gray.. I've used only existing parts in existing colors I hope you like this creation and good luck to all for the contest! Edit: without change any part and mantaining the clean look, theese are the possible combinations of color: U8-3R by Rusty B. Edited May 19, 2019 by Rustinidiel Quote
Cylo Posted May 19, 2019 Posted May 19, 2019 Nice build! I like the use of the transparent cockpit piece! Quote
