Posted May 22, 20195 yr When I discoved the existance of this part (24014), I was really curious what uses it could possibly have. But when looking up the models that make use of it, I was disappointed: it's only used as a decorative element. Now I'm planning to build a MOC with a mechanism that actually makes use of this part (already have an idea how). I don't know if I'll succeed, but I was wondering if anyone has ever used this part as a functional element in some mechanism? Edited May 22, 20195 yr by ozacek
May 22, 20195 yr There are six used in the Akiyuki Catch & Spin GBC robots Check out the GBC forum pages. Edited May 22, 20195 yr by Doug72
May 22, 20195 yr Author 2 hours ago, Doug72 said: There are six used in the Akiyuki Catch & Spin GBC robots Nice! Very clever use of those parts.
May 23, 20195 yr It's not Technic, but..... Also used in creator turbo track racer 31070 For the door mechanism. (one of my favorite sets!)
May 23, 20195 yr 20 hours ago, ozacek said: But when looking up the models that make use of it, I was disappointed: it's only used as a decorative element. What do you mean ? Every set that has this part uses it for a mechanism, even if it's always a simple one.
May 23, 20195 yr Author 3 hours ago, Leewan said: What do you mean ? Every set that has this part uses it for a mechanism, even if it's always a simple one. My bad, I actually only looked at technic sets, and only bionicle makes use of those parts (if that can be considered technic...), so I assumed they were only used as decorative parts.
May 24, 20195 yr They can be used when you only want a certain rotation that is not 360 degrees I guess using its axle as a limiter.
June 4, 20195 yr Author On 5/22/2019 at 4:51 PM, Doug72 said: There are six used in the Akiyuki Catch & Spin GBC robots I'm normally not at all into GBC, but this particular module's mechanism looks like quite something, and I have to build it :) I don't really like yellow though, and I also barely have any yellow parts, so I'm planning to change it for blue, and I finally got my hands on a couple of those hard-to-come-by 'Axle and Pin Connector Perpendicular 3L with 2 Pin Holes' in blue, so now I'm all set!
June 4, 20195 yr 3 hours ago, ozacek said: and I finally got my hands on a couple of those hard-to-come-by 'Axle and Pin Connector Perpendicular 3L with 2 Pin Holes' in blue, so now I'm all set! Woah, those are really pretty! Did you get them via BrickLink?
