Gray Gear Posted July 27, 2019 Posted July 27, 2019 15 minutes ago, paul_delahaye said: The was a little bit of me hoping we would have to assemble to cogs within the reduction hubs......and pop it together Its good we don't have to...there is probably a lot of lubricant in there to keep everything running smooth under high torque Quote
TeamThrifty Posted July 27, 2019 Posted July 27, 2019 13 hours ago, JonathanM said: 20% off the other two sets Thats the kind of starting point i want to see!! Once we get 30% off either this or 42100, i'm all over it!!! Quote
Akbalder Posted July 27, 2019 Posted July 27, 2019 It seems that the Control+ app can only shows the crawler. Do you think that it would work anyway to control any car? Quote
AVCampos Posted July 27, 2019 Posted July 27, 2019 Yes, as long as the same motors are connected in the same ports and are geared similarly (e.g. powering the motor forward doesn't make your car go backwards). It's the same situation as the Batmobile app. Quote
Akbalder Posted July 27, 2019 Posted July 27, 2019 Even if the gear ratio for the direction isn't the same? Quote
AVCampos Posted July 27, 2019 Posted July 27, 2019 In that case I'm not sure, as in the videos we saw it appears that, on initialisation, the 42099 calibrates its steering to determine the limits and/or the centre. Quote
Malek83 Posted July 27, 2019 Posted July 27, 2019 Crawler in Poland at the price of 750 zł (175 Euro) on Allegro.pl :) Quote
TeamThrifty Posted July 27, 2019 Posted July 27, 2019 £179 on ebay - what was the original guesstimate? I seem to think it was 250 euro's? 175 euro's in poland is starting to sound better.. Quote
Maaboo the Witch Posted July 27, 2019 Posted July 27, 2019 Smyth's will knock that price down in days. Quote
Malek83 Posted July 27, 2019 Posted July 27, 2019 999.99 zł/229.99 Euro/179.99 Pounds Starting price for the crawler:) Quote
jabz10 Posted July 28, 2019 Posted July 28, 2019 7 hours ago, Akbalder said: It seems that the Control+ app can only shows the crawler. Do you think that it would work anyway to control any car? What store are you seeing the app in? I can't find it in NZ App Store. Quote
Bricktrain Posted July 28, 2019 Posted July 28, 2019 4 hours ago, jabz10 said: What store are you seeing the app in? I can't find it in NZ App Store. https://play.google.com/store/apps/details?id=com.lego.technic.controlplus&fbclid=IwAR3bUskrSHzUPJFC2hW7awusWHAkD8GBQg_huCthNSueq83TXlLAlWf60-g Quote
jabz10 Posted July 28, 2019 Posted July 28, 2019 Ok build complete. And its past midnight the app has shown up in the NZ store. But its time to zzzz work tomorrow :| Quote
1gor Posted July 28, 2019 Posted July 28, 2019 Just now, jabz10 said: Ok build complete. And its past midnight the app has shown up in the NZ store. But its time to zzzz work tomorrow :| Good night (Thanks for photos) Quote
1963maniac Posted July 28, 2019 Posted July 28, 2019 I would like to see a picture of the box contents, if available; or an inventory picture. Quote
jabz10 Posted July 29, 2019 Posted July 29, 2019 (edited) Few observations: Works well, however I think it needs some more torque. Going over reasonable obstacles with 2 wheels is easy enough, i.e. right side or left side. However both front or rear wheels, it will struggle and then motor cut out kicks in. The most annoying thing is with the app, I keep inadvertently activating one touch mode since its just a swipe left. If you aren’t watching your finger placement on the steering, it can happen easily. Wish I could turn it off in settings. When you do use one touch mode, it takes a while to get the hang of it, however initially I was confused how it worked due to their description "Drag a path with your finger in the One-touch screen and watch your model follow it with razor-sharp precision" I thought you could draw a path and lift you finger off for it to follow the path, not quite, you drag your finger on the screen and it will follow the path as long as you don't run out of screen realestate or lift your finger off the screen. The second most annoying thing is with the app, once in one touch mode, its just as easy to inadvertently switch back to on screen controls mode with a right swipe. Edited July 29, 2019 by jabz10 Quote
Maaboo the Witch Posted July 29, 2019 Posted July 29, 2019 (edited) Sounds like a pain in the a.r.s.e. They might update it when the Liebherr is released. Edited July 29, 2019 by Maaboo35 Quote
Lucio Switch Posted July 29, 2019 Posted July 29, 2019 6 hours ago, jabz10 said: Few observations: Works well, however I think it needs some more torque. Going over reasonable obstacles with 2 wheels is easy enough, i.e. right side or left side. However both front or rear wheels, it will struggle and then motor cut out kicks in. The most annoying thing is with the app, I keep inadvertently activating one touch mode since its just a swipe left. If you aren’t watching your finger placement on the steering, it can happen easily. Wish I could turn it off in settings. When you do use one touch mode, it takes a while to get the hang of it, however initially I was confused how it worked due to their description "Drag a path with your finger in the One-touch screen and watch your model follow it with razor-sharp precision" I thought you could draw a path and lift you finger off for it to follow the path, not quite, you drag your finger on the screen and it will follow the path as long as you don't run out of screen realestate or lift your finger off the screen. The second most annoying thing is with the app, once in one touch mode, its just as easy to inadvertently switch back to on screen controls mode with a right swipe. I swapped the gears that you can see in your last pic (on both axles), now it's a bit slower, but it climbs a lot better. Quote
Jim Posted July 29, 2019 Posted July 29, 2019 On 7/28/2019 at 3:07 PM, jabz10 said: Ok build complete. And its past midnight the app has shown up in the NZ store. But its time to zzzz work tomorrow :| I will be that guy....one of your tired (edit: tires) is mounted incorrectly. Probably because it was past midnight Quote
efferman Posted July 29, 2019 Posted July 29, 2019 Why the heck someone destroying something not by accident? Quote
kbalage Posted July 29, 2019 Posted July 29, 2019 59 minutes ago, Ngoc Nguyen said: This is just too much... I have no clue what are they teasing but I really don't like pointless destruction. Quote
Maaboo the Witch Posted July 29, 2019 Posted July 29, 2019 1 hour ago, Ngoc Nguyen said: This is just too much... Doubleyoo tee effing eff? "Hey people, let's do a video where we wreck our latest product." Solid marketing there, TLG.... Quote
Philo Posted July 29, 2019 Posted July 29, 2019 1 hour ago, Jim said: one of your tired Maybe @jabz10 is not alone to be tired Quote
Jim Posted July 29, 2019 Posted July 29, 2019 2 minutes ago, Philo said: Maybe @jabz10 is not alone to be tired LoL Quote
